#include <reg52.h>
#include <intrins.h>
#include"24C0x.h"
#include"LCD12864.h"
#define buffer1ID 0x01
#define buffer2ID 0x02
#define queren 0x88
#define tuichu 0x86
#define shanchu 0x84
#define User 1
void fan();
sbit B0=B^0;
sbit B7=B^7;
sbit k2=P3^7;
sbit jidianqi=P3^6;
sbit Feng=P2^0;
extern unsigned char times[];
uchar Member=1,sec;
uchar ErrorCount;
//////////////////////////紅外相關(guān)//////////////////////////
//時(shí)間計(jì)算
#define Imax 14000 //此處為晶振為11.0592時(shí)的取值,
#define Imin 8000 //如用其它頻率的晶振時(shí),
#define Inum1 1450 //要改變相應(yīng)的取值。
#define Inum2 7000
#define Inum3 3000
//解碼變量
unsigned char Im[4]={0x00,0x00,0x00,0x00};
//全局變量
uchar f;
unsigned long m,Tc;
unsigned char IrOK;
uchar code buffer[User][6]=
{"000000"}
uchar dz[4];
uchar time[4];
uchar mima[6];
uchar mimag[6];
uchar mimaID[6]={1,2,3,4,5,6};
uchar Address1=20,tempx=20;
uchar Address2=20;
uchar data K;
uchar data Key;
uint PageID;
uchar data querenma=11;
uchar sum[2];
int summaf,summas;
uchar xdata UserPassword[7]={0};//密碼
uchar xdata DSY_BUFFER[16] ={0};//緩存
void Red_Init(void);
#include "zhiwen.h"
//檢測脈沖寬度
unsigned char check(void);
unsigned char redchange(unsigned char rednum);
void delayms(unsigned int z)
unsigned int x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
* 名稱 : Chack(uchar User_Number)
* 功能 : 單一用戶密碼檢測
* 輸入 : User_Number
* 輸出 : 密碼正確與錯(cuò)誤,錯(cuò)誤返回0,正確返回1
uchar Chack(uchar User_Number)
uchar flag, i,temp[6],Address;
Address=User_Number*10;
for(i=0;i<6;i++)
temp=x24c02_read(Address);
delayms(10);
Address++;
for(i=0;i<6;i++)
if(temp==UserPassword)
flag=1;
flag=0;
return flag;
* 名稱 : PassWord_Chack()
* 功能 : 所有用戶密碼檢測
* 輸入 : 無
uchar PassWord_Chack()
uchar i=0;
while(i<User)
if(Chack(i)==1)
Member=i+1;
return 1;
i++;
return 0;
void delay(uchar tt)
{ uchar i;
while(tt--)
for(i=0;i<125;i++);
* 名稱 : UART_Init()
* 功能 : 單片機(jī)串口初始化
* 單片機(jī):晶振11.0592MHz 波特率為9600bps
* 指紋模塊:波特率為9600bps,
void UART_Init()
SCON= 0x50; //串口方式1 //REN=1; 允許接收
PCON=0x00; //SMOD=0
IT1=1;
EX1=1;
TH0=0;
TL0=0;
TR0=0;
TMOD= 0x21; //定時(shí)器1定時(shí)方式2
TH1= 0xFD; //11.0592MHz 模塊默認(rèn)波特率為9600bps
TL1= 0xFD;
TR1= 1; //啟動(dòng)定時(shí)器
EA=1;
unsigned char Keycan(void) //按鍵掃描程序 P1.0--P1.3為行線 P1.4--P1.7為列線
unsigned char rcode, ccode;
P1 = 0x0f; // 發(fā)全0行掃描碼,列線輸入
if((P1&0x0f) != 0x0f) // 若有鍵按下
delay(1);// 延時(shí)去抖動(dòng)
{ rcode = 0xFE; // 逐行掃描初值
while((rcode&0x10) != 0)
P1 = rcode; // 輸出行掃描碼
if((P1&0x0f) != 0x0f) // 本行有鍵按下
ccode = (P1&0x0f)|0x0f;
//do{;}
while((P1&0x0f) != 0x0f); //等待鍵釋放
Feng=0;
delay(100);
Feng=1;
return ((~rcode) + (~ccode)); // 返回鍵編碼
rcode = (rcode<<1)|0x01; // 行掃描碼左移一位
if(IrOK==1)
IrOK=0;
Feng=0;
delay(100);
Feng=1;
switch (Im[2])
case 0x16: return 0x28;break; //0
case 0x0c: return 0x11;break; //1
case 0x18: return 0x71;break; //2
case 0x5e: return 0x41;break; //3
case 0x08: return 0x12;break; //4
case 0x1c: return 0x22;break; //5
case 0x5a: return 0x42;break; //6
case 0x42: return 0x14;break; //7
case 0x52: return 0x24;break; //8
case 0x4a: return 0x44;break; //9
case 0x47: return 0x81;break; //a
case 0x43: return 0x82;break; //b
case 0x0d: return 0x74;break; //c
case 0x15: return 0x88;break; //d
case 0x19: return 0x48;break;
return 0; // 無鍵按下,返回值為0
void KeyDeal(unsigned char Key)
{ //unsigned char n;
if(Key!=0)
switch(Key)
case 0x11: K=1; break;
case 0x21: K=2; break;
case 0x71: K=3; break;
case 0x81: break;
case 0x12: K=4; break;
case 0x22: K=5; break;
case 0x42: K=6; break;
case 0x82: K=34;break;
case 0x14: K=7; break;
case 0x24: K=8; break;
case 0x44: K=9; break;
case 0x74: break;
case 0x18: break;
case 0x28: K=0; break;
case 0x48: K=11; break;
case 0x88: break;
default: break;
void shuazhiwen()
uchar IDs1,IDs2,IDs3;
LcmClearTXT();
PutStr(1,1,"請(qǐng)按手指開鎖");
SFG_identify();
while(querenma==2)
SFG_identify();
if(querenma==0)
LcmClearTXT();
PutStr(1,2,"門已打開");
IDs1=PageID/100;
IDs2=PageID/10%10;
IDs3=PageID%10;
PutStr(2,1,"編號(hào)為:");
WriteCommand(0x8D); //指定第三行顯示位置
WriteData(0x30+IDs1);
WriteData(0x30+IDs2);
WriteData(0x30+IDs3);
ErrorCount=0;
Feng=1;
jidianqi=0;
delay(2500);
jidianqi=1;
else if(querenma==9)
LcmClearTXT();
PutStr(1,1,"沒搜索到指紋");
PutStr(2,1,"請(qǐng)重新按手指");
ErrorCount=3;
Feng=0;
LcmClearTXT();
PutStr(1,1,"接收包出錯(cuò)");
delay(2000);
// while(Keycan()==0);
void addfinger()
uchar IDa1,IDa2,IDa3;
LcmClearTXT();
PutStr(1,2,"請(qǐng)按手指");
SFG_getimage();
while(querenma!=0)
SFG_getimage();
SFG_genchar(buffer1ID);
UART_Init();
SFG_fastsearch(buffer1ID);
while(querenma==1)
if(querenma==0)
LcmClearTXT();
PutStr(1,1,"該指紋已存儲(chǔ)");
PutStr(3,0," 按任意鍵繼續(xù)");
while(Keycan()==0);
LcmClearTXT();
PutStr(1,1,"請(qǐng)?jiān)俅伟词种?quot;);
SFG_enroll();
while(querenma==2)
SFG_enroll();
LcmClearTXT();
if(querenma==0)
IDa1=PageID/100;IDa2=PageID/10%10;IDa3=PageID%10;
PutStr(1,1,"指紋采集成功");
WriteCommand(0x8D);
WriteData(0x30+IDa1);WriteData(0x30+IDa2);WriteData(0x30+IDa3);
else if(querenma!=0)
PutStr(1,1,"指紋采集失敗");
PutStr(2,1,"請(qǐng)重新操作");
while(Keycan()==0);
LcmClearTXT();
PutStr(0,0,"按鍵1 : 增加指紋");
PutStr(1,0,"按鍵2 : 刪去指紋");
PutStr(2,0,"按鍵3 : 手動(dòng)開鎖");
PutStr(3,0,"按鍵4 : 修改密碼");
void deletfinger()
uchar i,j=0;
LcmClearTXT();
PutStr(1,0,"輸入刪去的指紋號(hào)");
for(i=0;i<5;i++)dz=0;
Key=Keycan();
while(Key!=queren)
Key=Keycan();
KeyDeal(Key);
delay(30); //按鍵有抖動(dòng)@@@
if(Key==0)K=10;
if((K>=0)&&(K<=9))
dz[j]=K;
if(j<3)
WriteCommand(0x88+j); //指定第三行顯示位置
WriteData(0x30+dz[j]);
++j;
if(j==4)
j=3; //@@#yinhuang
} //顯示LCD12864并行顯示
if(K==34) //按了刪除鍵
if(j==0)
WriteCommand(0x88); //指定第三行顯示位置
WriteData(0x20);
--j;
WriteData(0x20);
if(j>=2)
PageID=dz[2]+dz[1]*10+dz[0]*100;
if(j==1)
PageID=dz[1]+dz[0]*10;
if(j==0)
PageID=dz[0];
SFG_deletchar(PageID);
if(querenma==0)
LcmClearTXT();
PutStr(1,1,"刪去指紋號(hào)成功!");
LcmClearTXT();
PutStr(1,2,"刪去指紋號(hào)失敗!");
PutStr(2,0," 按任意鍵繼續(xù)");
while(Keycan()==0);
LcmClearTXT();
void gaimima()
uchar i,j=0,mima1[6],mima2[6];
uchar k,temp;
LcmClearTXT();
PutStr(1,1,"請(qǐng)輸入新密碼");
for(i=0;i<6;i++)mima1=0;
Key=Keycan();
while(Key!=queren)
Key=Keycan();
KeyDeal(Key);
delay(30);
if(Key==0)K=10;
if((K>=0)&&(K<=9))
mima1[j]=K;
if(j<6)
WriteCommand(0x89+j); //指定第三行顯示位置
WriteData(0x0f);
++j;
if(j==7)
j=6; //@@#yinhuang
} //顯示LCD12864并行顯示
if(K==34) //按了刪除鍵
if(j==0)
WriteCommand(0x89); //指定第三行顯示位置
WriteData(0x20);
--j;
WriteData(0x20);
LcmClearTXT();
LcmClearTXT();
j=0;
PutStr(1,0,"請(qǐng)?jiān)俅屋斎胄旅艽a");
for(i=0;i<6;i++)mima2=0;
Key=Keycan();
while(Key!=queren)
Key=Keycan();
KeyDeal(Key);
delay(30);
if(Key==0)K=10;
if((K>=0)&&(K<=9))
mima2[j]=K;
if(j<6)
WriteData(0x0f);
++j;
if(j==7)
j=6; //@@#yinhuang
} //顯示LCD12864并行顯示
if(K==34) //按了刪除鍵
if(j==0)
WriteData(0x20);
--j;
WriteData(0x20);
LcmClearTXT();
if((mima1[0]==mima2[0])&&(mima1[1]==mima2[1])&&(mima1[2]==mima2[2])&&(mima1[3]==mima2[3])&&(mima1[4]==mima2[4])&&(mima1[5]==mima2[5]))
for(i=0;i<6;i++)
mimaID=mima1;
for(i=0;i<6;i++) //密碼限制在6位以內(nèi)
UserPassword=mima1+0x30;
temp=(Member-1)*10;
delayms(5);
for(k=0;k<6;k++)
x24c02_write(temp,UserPassword[k]);
delayms(10);
temp++;
PutStr(0,1,"密碼修改成功");
ErrorCount=0;
while(Keycan()==0);
PutStr(0,0," 密碼修改失敗 ");
PutStr(1,0,"兩次輸入的密碼不");
PutStr(2,0,"一致,請(qǐng)重新操作");
while(Keycan()==0);
LcmClearTXT();
void zhu()
LcmClearTXT();
PutStr(1,2,"門已打開");
jidianqi=0;
delay(2500);
jidianqi=1;
while(Keycan()==0);
void guanliyuan()
uchar i,j=0,x=1;
uchar Right_flag;
LcmClearTXT();
PutStr(1,1,"請(qǐng)輸入密碼:");
for(i=0;i<6;i++)mima=0;
Key=Keycan();
while(Key!=queren)
Key=Keycan();
KeyDeal(Key);
delay(30);
if(Key==0)K=10;
if((K>=0)&&(K<=9))
mima[j]=K;
if(j<6)
WriteData(0x0f);
++j;
if(j==7)
j=6;
} //顯示LCD12864并行顯示
if(K==34) //按了刪除鍵
if(j==0)
WriteData(0x20);
--j;
WriteData(0x20);
LcmClearTXT();
for(i=0;i<6;i++)
UserPassword=mima+0x30;
if(j==6)
if(mima[0]==1&&mima[1]==3&&mima[2]==1&&mima[3]==4&&mima[4]==2&&mima[5]==0)
Right_flag=1;
Right_flag=0;
if (Right_flag==1)
Right_flag=0;
while(i!=tuichu)
i=Keycan();
KeyDeal(i);
switch(K)
case 1: addfinger();K=6; break;
case 2: deletfinger(); break;
case 3: zhu(); K=8; break;
case 4: gaimima(); break;
default: break;
PutStr(1,2,"密碼錯(cuò)誤");
PutStr(2,0," 請(qǐng)重新操作!");
while(Keycan()==0);
Key=0;
void mimakaisuo()
uchar i,j=0,x=1;
uchar Right_flag;
LcmClearTXT();
PutStr(1,0,"請(qǐng)輸入密碼開鎖:");
Key=Keycan();
while(Key!=queren)
Key=Keycan();
KeyDeal(Key);
delay(30);
if(Key==0)K=10;
if((K>=0)&&(K<=9))
mima[j]=K;
if(j<6)
WriteData(0x0f);
++j;
if(j==7)
j=6;
} //顯示LCD12864并行顯示
if(K==34) //按了刪除鍵
if(j==0)
WriteData(0x20);
--j;
WriteData(0x20);
LcmClearTXT();
for(i=0;i<6;i++)
if(j==6){Right_flag=PassWord_Chack(); }
if (Right_flag==1&&ErrorCount<3)
Right_flag=0;
zhu();ErrorCount=0;
Feng=1;
if(ErrorCount<3)
ErrorCount++;
if(ErrorCount==3)
Feng=0;
PutStr(2,0," 還有 次機(jī)會(huì)");
WriteCommand(0x8a);
WriteData(' ');
WriteData(3-ErrorCount+0x30);
delay(1000);
Key=0;
LcmClearTXT();
void fan()
// PutStr(1,2,"請(qǐng)先按鍵");
// PutStr(2,2,"再刷指紋");
if(Key!=0x81) //管理員操作
PutStr(0,2,"歡迎使用");
PutStr(1,0,"指紋密碼門禁系統(tǒng)");
PutStr(2,0,"密碼開鎖請(qǐng)按 C鍵");
PutStr(3,1,"請(qǐng)按手指開鎖");
Key=Keycan();
if(k2==1) //指紋刷機(jī)
LcmClearTXT();
shuazhiwen();
LcmClearTXT();
if(Key==0x81) //管理員操作
LcmClearTXT();
guanliyuan();
LcmClearTXT();
if(Key==0x84&&ErrorCount<3) //密碼開鎖
LcmClearTXT();
mimakaisuo();
LcmClearTXT();
//PSB=0;
UART_Init(); //串口初始化
x24c02_init(); //24C02初始化
LcmInit(); //LCD12864初始化
LcmClearTXT(); //LCD12864清屏
fan();
delay(100);
//外部中斷解碼程序_外部中斷1
void intersvr1(void) interrupt 2
TR0=1;
Tc=TL0*256+TH0;//提取中斷時(shí)間間隔時(shí)長
TH0=0;
TL0=0; //定時(shí)中斷重新置零
if((Tc>Imin)&&(Tc<Imax))
m=0;
f=1;
return;
} //找到啟始碼
if(f==1)
if(Tc>Inum1&&Tc<Inum3)
Im[m/8]=Im[m/8]>>1|0x80; m++;
if(Tc>Inum2&&Tc<Inum1)
Im[m/8]=Im[m/8]>>1; m++; //取碼
if(m==32)
m=0;
f=0;
if(Im[2]==~Im[3])
IrOK=1;
TR0=0;
else IrOK=0; //取碼完成后判斷讀碼是否正確
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件………… |
