#include<reg52.h>
sbit beep=P2^4;
uchar num,num1,flag,a;
void init()
TMOD=0X21;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=0XFD;
TL1=0XFD;
ET1=0;
TR1=1;
SM0=0;
SM1=1;
REN=1;
EA=1;
ET0=1;
ES=1;
init();
if(flag==1)//到這不時(shí)卡住了,調(diào)試后看到flag=0的
TR0=1;
ES=0;
switch(a)
case 1:num=4;break;
case 2:num=2;break;
ES=1;
flag=0;
void ser() interrupt 4
RI=0;
a=SBUF;
P1=SBUF;//驗(yàn)證串口是否能接收到數(shù)據(jù)用
flag=1;
void time() interrupt 1
num1++;
if(num1=num)
num1=0;
beep=~beep;
