查看: 2924|回復: 4
DS18B20應用程序 對數碼管的顯示里的P0口賦值不懂
ID:236816 發表于 2017-9-30 21:41 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
/*====================================函數:void Display(unsigned long Value)參數:Value,顯示值 32位描述:====================================*/void Display(unsigned long Value)                {        uchar i=0;//第一位數碼管//------------------------------        if(s == 0);                                                           //如果為負數則不顯示        else        {                                DU = 0;                                                        //關閉段選                P0 = s;                                DU = 1;                                                        //打開段選                DU = 0;                                                        //關閉段選                        WE = 0;                                                //關閉位選                P0 = T_COM[i++];                                        WE = 1;                                                //打開位選                WE = 0;                                                //關閉位選                Delay_Ms(1);        }//第二位數碼管//------------------------------        if(Value < 1000000);                           //如果溫度值百位為0則不顯示        else        {                DU = 0;                                                        //關閉段選                P0 = table[Value/1000000];                        DU = 1;                                                        //打開段選                DU = 0;                                                        //關閉段選                        WE = 0;                                                //關閉位選                P0 = T_COM[i++];                                                WE = 1;                                                //打開位選                WE = 0;                                                //關閉位選                Delay_Ms(1);        }//第三位數碼管//------------------------------        if(Value < 100000);                                                else        {                DU = 0;                                                        //關閉段選                P0 = table[Value%1000000/100000];                //數碼管顯示百位                DU = 1;                                                        //打開段選                DU = 0;                                                        //關閉段選                        WE = 0;                                                //關閉位選                P0 = T_COM[i++];                                                WE = 1;                                                //打開位選                WE = 0;                                                //關閉位選                Delay_Ms(1);        }//第四位數碼管//-------------------------------        DU = 0;        P0 = table[Value%100000/10000]|0x80;//顯示溫度小數點,溫度值個位顯示        DU = 1;        DU = 0;        WE = 0;        P0 = T_COM[i++];                        WE = 1;        WE = 0;        Delay_Ms(1);//第五位數碼管//-------------------------------        DU = 0;                                                        //關閉段選        P0 = table[Value%10000/1000];                DU = 1;                                                        //打開段選        DU = 0;                                                        //關閉段選        WE = 0;                                                //關閉位選        P0 = T_COM[i++];                                        WE = 1;                                                //打開位選        WE = 0;                                                //關閉位選        Delay_Ms(1);//第六位數碼管//-------------------------------        if((Value%100/10) == 0 && (Value%1000/100) == 0 );         else        {                DU = 0;                                                        //關閉段選                P0 = table[Value%1000/100];                        DU = 1;                                                        //打開段選                DU = 0;                                                        //關閉段選                        WE = 0;                                                //關閉位選                P0 = T_COM[i++];                                                WE = 1;                                                //打開位選                WE = 0;                                                //關閉位選                Delay_Ms(1);        }//第七位數碼管//-------------------------------        if((Value%10) == 0 && (Value%100/10) == 0);        else        {                DU = 0;                                                        //關閉段選                P0 = table[Value%100/10];                        DU = 1;                                                        //打開段選                DU = 0;                                                        //關閉段選                        WE = 0;                                                //關閉位選                P0 = T_COM[i++];                                                WE = 1;                                                //打開位選                WE = 0;                                                //關閉位選                Delay_Ms(1);        }//第八位數碼管//-------------------------------        if((Value%10) == 0 );        else        {                DU = 0;                                                        //關閉段選                P0 = table[Value%10];                        DU = 1;                                                        //打開段選                DU = 0;                                                        //關閉段選                        WE = 0;                                                //關閉位選                P0 = T_COM[i++];                                                WE = 1;                                                //打開位選                WE = 0;                                                //關閉位選                Delay_Ms(1);        }}
ID:82765 發表于 2017-9-30 22:10 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
ID:111634 發表于 2017-10-1 21:36 | 只看該作者
本帖最后由 zl2168 于 2017-10-1 21:37 編輯
實例97  一線式DS18B20測溫
Proteus仿真一下,確認有效。
實例97 DS18B20測溫.rar (51.78 KB, 下載次數: 4)
以上摘自張志良編著《80C51單片機仿真設計實例教程——基于Keil CProteus》清華大學出版社ISBN 978-7-302-41682-1內有常用的單片機應用100案例,用于仿真實驗操作,電路與程序真實可靠可信可行。仿真電路和Hex文件能在清華出版社網站免費下載,程序源代碼只能到書上看了。到圖書館借,或到新華書店翻閱,或到網上書店打折購買。
ID:474670 發表于 2019-2-6 22:07 | 只看該作者
暈,你自己上個代碼都不認真,誰還幫你咯
參與人數 3黑幣 +37 收起 理由
春風十里吹 + 10 很給力!
zhengchong60 + 15
鉆牛尖滴劉尖尖 + 12
ID:472325 發表于 2019-2-7 00:06 | 只看該作者
說的也是,什么玩意兒嘛?一團遭!
參與人數 3黑幣 +60 收起 理由
areyouok + 10
Sawardeakar + 35
#include51.h + 15
