//-------------------------------------------------------------------------------TM1638.c-------------------------------------------------------------------
#include "TM1638.h"
#include "stdint.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,
0x66,0x6D,0x7D,0x07,
0x7F,0x6F,0x77,0x7C,
0x39,0x5E,0x79,0x71};
#define ADD 10
#define MINUS 11
#define EQUAL 12
#define CLEAR 13
#define PLUS 14
#define DIVIDE 15
unsigned int flag;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void TM1638_Write(unsigned char DATA) //寫(xiě)數(shù)據(jù)函數(shù)
unsigned char i;
DIO_OUT;
for(i=0;i<8;i++)
CLK_low;
if(DATA & 0x01){
DIO_high;
}else{
DIO_low;
CLK_high;
DATA>>=1;
unsigned char TM1638_Read(void) //讀數(shù)據(jù)函數(shù)
unsigned char i;
unsigned char temp=0;
DIO_IN;
STB_low;
for(i=0;i<8;i++)
temp>>=1;
CLK_low;
_delay_us(100);
if(DIO_READ)
temp |= 0x80;
temp &= 0x7f;
CLK_high;
return temp;
void Write_COM(unsigned char cmd) //發(fā)送命令字
CLK_high;
STB_high;
STB_low;
TM1638_Write(cmd);
STB_high;
*函數(shù)功能:讀取按鍵值
*輸入?yún)?shù):無(wú)
*輸出參數(shù):無(wú)
*返回值: 無(wú)
unsigned char Read_key(void)
unsigned char c[4];
unsigned int key_value=0x00;
unsigned int i;
STB_high;
STB_low;
TM1638_Write(0x42);
_delay_us(1);
for(i=0;i<4;i++)
c[i]=TM1638_Read();
STB_high;
if(c[0]&BIT2)
key_value |= BIT1;
else if(c[0]&BIT6)
key_value |= BIT4;
else if(c[0]&BIT0)
key_value |= BIT2;
else if(c[0]&BIT1)
key_value |= BIT3;
else if(c[0]&BIT5)
key_value |= BIT6;
else if(c[0]&BIT4)
key_value |= BIT5;
else if(c[1]&BIT0)
key_value |= BITB;
else if(c[1]&BIT4)
key_value |= BITC;
else if(c[1]&BIT1)
key_value |= BITA;
else if(c[2]&BIT0)
key_value |= BITD;
else if(c[2]&BIT4)
key_value |= BIT8;
else if(c[2]&BIT5)
key_value |= BIT9;
else if(c[2]&BIT6)
key_value |= BIT7;
else if(c[3]&BIT0)
key_value |= BITF;
else if(c[3]&BIT1)
key_value |= BITE;
else if(c[3]&BIT2)
key_value |= BIT0;
//特殊符號(hào)‘AC’ ‘+’ ‘-’ ‘=’
else if(c[1]&BIT2)
flag<=CLEAR;
Write_allLED(0);//按下AC,清除所有顯示
else if(c[1]&BIT6)
flag<=ADD;//按下+,清除所有顯示
else if(c[2]&BIT1)
flag<=EQUAL;//按下=,清除所有顯示
else if(c[2]&BIT2)
flag<=MINUS;//按下-,清除所有顯示
for(i=0;i<16;i++)
if((0x01<<i)==key_value)
break;
return i;
void Write_DATA(unsigned char add,unsigned char DATA) //指定地址寫(xiě)入數(shù)據(jù)
Write_COM(0x44);
STB_low;
TM1638_Write(0xc0|add);
TM1638_Write(DATA);
STB_high;
void init_TM1638(void)
Write_allLED(0xff);
_delay_ms(100);
Write_allLED(0);
void Write_allLED(unsigned char DATA){
unsigned char i;
Write_COM(0x8F);//顯示控制
Write_COM(0x40); //數(shù)據(jù)命令
STB_low;
TM1638_Write(0xc0);
for(i=0;i<16;i++)
TM1638_Write(DATA);
STB_high;
//---------------------------------------------------------------------------TM1638.h------------------------------------------------------------------------------
#ifndef _TM1638_H
#define _TM1638_H
#include "msp430f6638.h"
#include <stdint.h>
#define CPU_F ((double)20000000)
#define _delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define _delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define DIO_high (P3OUT |= BIT5)
#define DIO_low (P3OUT &= ~BIT5)
#define CLK_high (P3OUT |= BIT4)
#define CLK_low (P3OUT &= ~BIT4)
#define STB_high (P3OUT |= BIT2)
#define STB_low (P3OUT &= ~BIT2)
#define DIO_IN (P3DIR &= ~BIT5) //輸入狀態(tài)
#define DIO_OUT (P3DIR |= BIT5) //輸出狀態(tài)
#define DIO_READ (P3IN & BIT5) //讀引腳電平
void TM1638_Write(unsigned char DATA); //寫(xiě)數(shù)據(jù)函數(shù)
unsigned char TM1638_Read(void); //讀數(shù)據(jù)函數(shù)
void Write_COM(unsigned char cmd); //發(fā)送命令字
unsigned char Read_key(void);
void Write_DATA(unsigned char add,unsigned char DATA); //指定地址寫(xiě)入數(shù)據(jù)
void Write_allLED(unsigned char flag); //控制全部LED函數(shù),flag表示LED狀態(tài)
void init_TM1638(void);
#endif
