參數(shù) AT89S52MCS-51 12MHZ
//程序部分開始//
//頭文件
//#include <AT89X52.h>
#include <string.h>
#include<reg52.h>
//燈與揚(yáng)聲器定義
sbit led_back = P1^0;//
sbit led_b = P2^3;//秒閃爍燈
sbit led_r = P2^4;
sbit led_g1 = P2^5;//
sbit led_g2 = P2^5;
sbit led_g3 = P2^5;
sbit led_g4 = P2^5;
sbit beep = P1^1;//
//溫度傳感器定義
sbit DQ = P1 ^ 6;//ds18B20
//鍵盤引腳定義
sbit KEY_1 = P3^0; //左上
sbit KEY_2 = P3^1; //左下
sbit KEY_3 = P3^2; //右上
sbit KEY_4 = P3^3; //右下
sbit KEY_I = P3^4; //
//LCD接口定義
sbit RS = P2^0;//模式位為0輸入指令為1輸入數(shù)據(jù)
sbit RW = P2^1;//讀寫位為0讀為1寫
sbit E = P2^2;//使能位
#define Lcd_Bus P0 //數(shù)據(jù)總線
//定義DS1302時(shí)鐘接口
sbit clock_clk = P3 ^ 7;//ds1302_clk時(shí)鐘線
sbit clock_dat = P3 ^ 6;//ds1302_dat?dāng)?shù)據(jù)線
sbit clock_Rst = P3 ^ 5;//ds1302_Rst復(fù)位線
//定義累加器A中的各位
sbit a0 = ACC ^ 0;
sbit a1 = ACC ^ 1;
sbit a2 = ACC ^ 2;
sbit a3 = ACC ^ 3;
sbit a4 = ACC ^ 4;
sbit a5 = ACC ^ 5;
sbit a6 = ACC ^ 6;
sbit a7 = ACC ^ 7;
//定義全局變量
unsigned char yy,mo,dd,xq,hh,mm,ss;//定義時(shí)間映射全局變量專用寄存器
bit w = 0; //調(diào)時(shí)標(biāo)志位
static unsigned char menu = 0;//定義靜態(tài)小時(shí)更新用數(shù)據(jù)變量
static unsigned char keys = 0;//定義靜態(tài)小時(shí)更新用數(shù)據(jù)變量
static unsigned char timecount = 0;//定義靜態(tài)軟件計(jì)數(shù)器變量
void DelayM(unsigned int a){//延時(shí)函數(shù) 1MS/次
unsigned char i;
while( --a != 0){
for(i = 0; i < 125; i++); //一個(gè) ; 表示空語句,CPU空轉(zhuǎn)。
} //i 從0加到125CPU大概就耗時(shí)1毫秒
//LCD驅(qū)動(dòng)
void chk_busy(){//檢查忙位底層
RS=0;
RW=1;
E=1;
Lcd_Bus=0xff;
while((Lcd_Bus&0x80)==0x80);
E=0;
void write_com(unsigned char cmdcode){//寫命令到LCD底層
chk_busy();
RS=0;
RW=0;
E=1;
Lcd_Bus=cmdcode;
E=0;
void write_data(unsigned char Dispdata){ //寫數(shù)據(jù)到LCD底層
chk_busy();
RS=1;
RW=0;
E=1;
Lcd_Bus=Dispdata;
E=0;
void lcm_init(){//初始化LCD屏被調(diào)用層
write_com(0x30); //選擇8bit數(shù)據(jù)流
write_com(0x0c); //開顯示(無游標(biāo)、不反白)
write_com(0x01); //清除顯示并且設(shè)定地址指針為00H
void lcm_w_word(unsigned char *s){//向LCM發(fā)送一個(gè)字符串,長度64字符之內(nèi)。被調(diào)用層
while(*s>0){ //應(yīng)用lcm_w_word("您好");
write_data(*s);
s++;
void lcm_w_test(bit i,unsigned char word){//寫指令或數(shù)據(jù)被調(diào)用層
if(i == 0){
write_com(word);//寫指令或數(shù)據(jù)0指令
}else{
write_data(word);//寫指令或數(shù)據(jù)1數(shù)據(jù)
void lcm_clr(void){//清屏函數(shù)
lcm_w_test(0,0x01);
//公歷節(jié)日數(shù)據(jù)庫表
void days (void) { //公歷節(jié)日數(shù)據(jù)庫
lcm_w_test(0,0x80);//在屏幕第一行
lcm_w_word("[Dis] [Set]");//顯示菜單操作注釋
lcm_w_test(0,0x98);//在屏幕第四行
if ( mo == 0x01 && dd == 0x01 ){ lcm_w_word("Happy New Year!!"); }//1月
if ( mo == 0x02 && dd == 0x02 ){ lcm_w_word(" 世界濕地日 "); }//2月
if ( mo == 0x02 && dd == 0x13 ){ lcm_w_word(" 明天情人節(jié)了 "); }
if ( mo == 0x02 && dd == 0x14 ){ lcm_w_word(" 今天是情人節(jié) "); }
if ( mo == 0x03 && dd == 0x01 ){ lcm_w_word(" 國際海豹日 "); }//3月
if ( mo == 0x03 && dd == 0x03 ){ lcm_w_word(" 全國愛耳日 "); }
if ( mo == 0x03 && dd == 0x08 ){ lcm_w_word(" 3.8婦女節(jié) "); }
if ( mo == 0x03 && dd == 0x12 ){ lcm_w_word(" 植樹節(jié) "); }
if ( mo == 0x03 && dd == 0x14 ){ lcm_w_word(" 國際警察日 "); }
if ( mo == 0x03 && dd == 0x15 ){ lcm_w_word(" 消費(fèi)者權(quán)益日 "); }
if ( mo == 0x03 && dd == 0x17 ){ lcm_w_word(" 國際航海日 "); }
if ( mo == 0x03 && dd == 0x21 ){ lcm_w_word(" 世界森林日 "); }
if ( mo == 0x03 && dd == 0x22 ){ lcm_w_word(" 世界水日 "); }
if ( mo == 0x03 && dd == 0x23 ){ lcm_w_word(" 世界氣象日 "); }
if ( mo == 0x03 && dd == 0x24 ){ lcm_w_word("世界防治結(jié)核病日"); }
if ( mo == 0x04 && dd == 0x01 ){ lcm_w_word("愚人節(jié) 小心上當(dāng)"); }//4
if ( mo == 0x04 && dd == 0x07 ){ lcm_w_word(" 世界衛(wèi)生日 "); }
if ( mo == 0x04 && dd == 0x08 ){ lcm_w_word(" 復(fù)活節(jié) "); }
if ( mo == 0x04 && dd == 0x13 ){ lcm_w_word(" 黑色星期五 "); }
if ( mo == 0x05 && dd == 0x01 ){ lcm_w_word(" 勞動(dòng)節(jié) 放假 "); }//5
if ( mo == 0x05 && dd == 0x04 ){ lcm_w_word(" 青年節(jié) "); }
if ( mo == 0x05 && dd == 0x08 ){ lcm_w_word(" 世界紅十字日 "); }
if ( mo == 0x05 && dd == 0x12 ){ lcm_w_word(" 國際護(hù)士節(jié) "); }
if ( mo == 0x05 && dd == 0x05 ){ lcm_w_word("近日注意母親節(jié) "); }
if ( mo == 0x05 && dd == 0x15 ){ lcm_w_word(" 國際家庭日 "); }
if ( mo == 0x05 && dd == 0x31 ){ lcm_w_word(" 世界無煙日 "); }
if ( mo == 0x06 && dd == 0x01 ){ lcm_w_word(" 國際兒童節(jié) "); }//6
if ( mo == 0x06 && dd == 0x05 ){ lcm_w_word(" 世界環(huán)境日 "); }
if ( mo == 0x06 && dd == 0x26 ){ lcm_w_word(" 國際禁毒日 "); }
if ( mo == 0x06 && dd == 0x06 ){ lcm_w_word(" 全國愛眼日 "); }
if ( mo == 0x06 && dd == 0x13 ){ lcm_w_word("近日注意父親節(jié) "); }
if ( mo == 0x06 && dd == 0x15 ){ lcm_w_word("近日注意父親節(jié) "); }
if ( mo == 0x07 && dd == 0x01 ){ lcm_w_word("香港回歸記念日 "); }//7
if ( mo == 0x07 && dd == 0x07 ){ lcm_w_word("抗日戰(zhàn)爭記念日 "); }
if ( mo == 0x07 && dd == 0x11 ){ lcm_w_word(" 世界人口日 "); }
if ( mo == 0x08 && dd == 0x01 ){ lcm_w_word(" 八一建軍節(jié) "); }//8
if ( mo == 0x08 && dd == 0x08 ){ lcm_w_word(" 中國男子節(jié) "); }
if ( mo == 0x08 && dd == 0x15 ){ lcm_w_word("抗戰(zhàn)勝利記念日 "); }
if ( mo == 0x09 && dd == 0x10 ){ lcm_w_word(" 中國教師節(jié) "); }//9
if ( mo == 0x09 && dd == 0x18 ){ lcm_w_word("九·一八事變記念"); }
if ( mo == 0x09 && dd == 0x20 ){ lcm_w_word(" 國際愛牙日 "); }
if ( mo == 0x09 && dd == 0x27 ){ lcm_w_word(" 世界旅游日 "); }
if ( mo == 0x10 && dd == 0x01 ){ lcm_w_word(" 中國國慶節(jié) "); }//10
if ( mo == 0x10 && dd == 0x04 ){ lcm_w_word(" 世界動(dòng)物日 "); }
if ( mo == 0x10 && dd == 0x24 ){ lcm_w_word(" 聯(lián)合國日 "); }
if ( mo == 0x10 && dd == 0x12 ){ lcm_w_word("明天國際教師節(jié) "); }
if ( mo == 0x10 && dd == 0x13 ){ lcm_w_word(" 國際教師節(jié) "); }
if ( mo == 0x11 && dd == 0x10 ){ lcm_w_word(" 世界青年節(jié) "); }//11
if ( mo == 0x11 && dd == 0x17 ){ lcm_w_word(" 世界學(xué)生節(jié) "); }
if ( mo == 0x12 && dd == 0x01 ){ lcm_w_word(" 世界艾滋病日 "); }//12
if ( mo == 0x12 && dd == 0x23 ){ lcm_w_word(" 明晚平安夜 "); }
if ( mo == 0x12 && dd == 0x24 ){ lcm_w_word(" 今晚平安夜 "); }
if ( mo == 0x12 && dd == 0x25 ){ lcm_w_word(" 圣誕快樂 "); }
if ( mo == 0x12 && dd == 0x31 ){ lcm_w_word(" 明日新年 "); }
else{//非節(jié)日時(shí)顯示時(shí)晨信息
if ( hh >= 0x04 && hh < 0x06 ){ lcm_w_word("★★__▲▲__凌晨"); }
if ( hh >= 0x06 && hh < 0x08 ){ lcm_w_word("☆○__▲△__早晨"); }
if ( hh >= 0x08 && hh < 0x12 ){ lcm_w_word("__●__▲▲__上午"); }
if ( hh == 0x12) { lcm_w_word("____▲●▲__中午"); }
if ( hh >= 0x13 && hh < 0x18 ){ lcm_w_word("__▲▲__●__下午"); }
if ( hh >= 0x18 && hh < 0x22 ){ lcm_w_word("△▲__●☆__晚上"); }
if ( hh >= 0x22 && hh <= 0x23 ){ lcm_w_word("△▲__★☆__夜里"); }
if ( hh >= 0x00 && hh < 0x04 ){ lcm_w_word("__★▲▲★__深夜"); }
//DS18B20溫度傳感器驅(qū)動(dòng)顯示0至60度
void Delay(int num){//延時(shí)函數(shù)
while(num--) ;
void Init_DS18B20(void){//初始化ds1820
unsigned char x=0;
DQ = 1; //DQ復(fù)位
Delay(8); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
Delay(80); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線
Delay(14);
x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
Delay(20);
unsigned char ReadOneChar(void){//讀一個(gè)字節(jié)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--){
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
Delay(4);
return(dat);
void WriteOneChar(unsigned char dat){//寫一個(gè)字節(jié)
unsigned char i=0;
for (i=8; i>0; i--){
DQ = 0;
DQ = dat&0x01;
Delay(5);
DQ = 1;
dat>>=1;
unsigned int ReadTemperature(void){//讀取溫度
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0xBE); //讀取溫度寄存器
a=ReadOneChar(); //讀低8位
b=ReadOneChar(); //讀高8位
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5; //放大10倍輸出并四舍五入
return(t);
//聲明當(dāng)各函數(shù)的排列適當(dāng)時(shí)可不用聲明
void lcm_w_ss(void);
void lcm_w_mm(void);
void lcm_w_hh(void);
void lcm_w_dd(void);
void lcm_w_mo(void);
void lcm_w_yy(void);
void lcm_w_xq(void);
unsigned char clock_in(void);
void clock_out(unsigned char dd);
void Init_1302(void);
unsigned char read_clock(unsigned char ord);
void read_clockS(void);
void Set_time(unsigned char sel);
void write_clock(unsigned char ord, unsigned char dd);
void updata (void);
//DS1302時(shí)鐘芯片驅(qū)動(dòng)程序
//常用時(shí)鐘數(shù)據(jù)讀取
void read_clockS(void){
ss = read_clock(0x81);//讀取秒數(shù)據(jù)
mm = read_clock(0x83);//讀取分鐘數(shù)據(jù)
hh = read_clock(0x85);//小時(shí)
dd = read_clock(0x87);//日
mo = read_clock(0x89);//月
xq = read_clock(0x8b);//星期
yy = read_clock(0x8d);//年
//調(diào)時(shí)用加1程序
void Set_time(unsigned char sel){ //根據(jù)選擇調(diào)整的相應(yīng)項(xiàng)目加1并寫入DS1302
signed char address,item;
signed char max,mini;
lcm_w_test(0,0x9a);
lcm_w_word("調(diào)整");
//if(sel==6) {lcm_w_word("秒鐘");address=0x80; max=0;mini=0;} //秒7
if(sel==5) {lcm_w_word("分鐘");address=0x82; max=59;mini=0;} //分鐘6
if(sel==4) {lcm_w_word("小時(shí)");address=0x84; max=23;mini=0;} //小時(shí)5
if(sel==3) {lcm_w_word("星期");address=0x8a; max=7;mini=1;} //星期4
if(sel==2) {lcm_w_word("日期");address=0x86; max=31;mini=1;} //日3
if(sel==1) {lcm_w_word("月份");address=0x88; max=12;mini=1;} //月2
if(sel==0) {lcm_w_word("年份");address=0x8c; max=99; mini=0;} //年1
//讀取1302某地址上的數(shù)值轉(zhuǎn)換成10進(jìn)制賦給item
item=((read_clock(address+1))/16)*10 + (read_clock(address+1))%16;
if(KEY_2 == 0){
item++;//數(shù)加 1
if(KEY_4 == 0){
item--;//數(shù)減 1
if(item>max) item=mini;//查看數(shù)值有效范圍
if(item<mini) item=max;
write_clock(0x8e,0x00);//允許寫操作
write_clock(address,(item/10)*16+item%10);//轉(zhuǎn)換成16進(jìn)制寫入1302
write_clock(0x8e,0x80);//寫保護(hù)禁止寫操作
updata (); //刷新數(shù)據(jù)
lcm_w_mm();//刷新 分
//設(shè)置1302的初始時(shí)間自動(dòng)初始化
void Init_1302(void){//-設(shè)置1302的初始時(shí)間2007年1月1日00時(shí)00分00秒星期一
unsigned char f;
if(read_clock(0xc1) != 0xaa){
write_clock(0x8c,0x07);//年
write_clock(0x8a,0x01);//星期
write_clock(0x88,0x01);//月
write_clock(0x86,0x01);//日
write_clock(0x84,0x00);//小時(shí)
write_clock(0x82,0x00);//分鐘
write_clock(0x80,0x00);//秒
write_clock(0x90,0xa5);//充電
write_clock(0xc0,0xaa);//寫入初始化標(biāo)志RAM第00個(gè)RAM位置
for(f=0;f<60;f=f+2)
{//清除鬧鐘RAM位為0
write_clock(0xc2+f,0x00);
write_clock(0x8e,0x80);//禁止寫操作
//DS1302寫數(shù)據(jù)底層協(xié)議
void write_clock(unsigned char ord, unsigned char dd){
clock_clk=0;
clock_Rst=0;
clock_Rst=1;
clock_out(ord);
clock_out(dd);
clock_Rst=0;
clock_clk=1;
//1302驅(qū)動(dòng)程序底層協(xié)議
void clock_out(unsigned char dd){
ACC=dd;
clock_dat=a0; clock_clk=1; clock_clk=0;
clock_dat=a1; clock_clk=1; clock_clk=0;
clock_dat=a2; clock_clk=1; clock_clk=0;
clock_dat=a3; clock_clk=1; clock_clk=0;
clock_dat=a4; clock_clk=1; clock_clk=0;
clock_dat=a5; clock_clk=1; clock_clk=0;
clock_dat=a6; clock_clk=1; clock_clk=0;
clock_dat=a7; clock_clk=1; clock_clk=0;
//DS1302寫入字節(jié)底層協(xié)議
unsigned char clock_in(void){
clock_dat=1;
a0=clock_dat;
clock_clk=1; clock_clk=0; a1=clock_dat;
clock_clk=1; clock_clk=0; a2=clock_dat;
clock_clk=1; clock_clk=0; a3=clock_dat;
clock_clk=1; clock_clk=0; a4=clock_dat;
clock_clk=1; clock_clk=0; a5=clock_dat;
clock_clk=1; clock_clk=0; a6=clock_dat;
clock_clk=1; clock_clk=0; a7=clock_dat;
return(ACC);
//DS1302讀數(shù)據(jù)底層協(xié)議
unsigned char read_clock(unsigned char ord){
unsigned char dd=0;
clock_clk=0;
clock_Rst=0;
clock_Rst=1;
clock_out(ord);
dd=clock_in();
clock_Rst=0;
clock_clk=1;
return(dd);
void Beep(void){//BELL-揚(yáng)聲器--整點(diǎn)報(bào)時(shí)
unsigned char a;//定義變量用于發(fā)聲的長度設(shè)置
for(a=60;a>0;a--){//第一個(gè)聲音的長度
beep = ~beep;//取反揚(yáng)聲器驅(qū)動(dòng)口以產(chǎn)生音頻
Delay(100);//音調(diào)設(shè)置延時(shí)
for(a=100;a>0;a--){//同上
beep = ~beep;
Delay(80);//
beep = ~beep;
Delay(30);//
beep = 1;//音樂結(jié)束后揚(yáng)聲器拉高關(guān)閉
void Beep_set(void){//BELL -揚(yáng)聲器--確定設(shè)置
for(a=50;a>0;a--){//第一個(gè)聲音的長度
beep = ~beep;
Delay(50);//
for(a=50;a>0;a--){//同上
beep = ~beep;
Delay(100);//
void Beep_key(void){//-揚(yáng)聲器--按鍵音
for(a=100;a>0;a--){//聲音的長度
beep = ~beep;
Delay(50);//音調(diào)設(shè)置延時(shí)
//向LCM中填寫 年 數(shù)據(jù)
void lcm_w_yy(void){
//if(read_clock(0x8d) != yy){
lcm_w_test(0,0x83);
lcm_w_word("20");
lcm_w_test(0,0x84);
lcm_w_test(1,(yy/16)+0x30);
lcm_w_test(1,yy%16+0x30);
//向LCM中填寫 月 數(shù)據(jù)
void lcm_w_mo(void){
//if(read_clock(0x89) != mo){
lcm_w_test(0,0x90);
if(mo/16 != 0){lcm_w_test(1,(mo/16)+0x30);} //十位消隱
else{lcm_w_test(1,0x20);}//同上
lcm_w_test(1,mo%16+0x30);
lcm_w_test(0,0x91);
lcm_w_word("月");
//星期處理并送入LCM的指定區(qū)域
void lcm_w_xq(void){
unsigned char sel;
//if(read_clock(0x8b) != xq){
sel = (read_clock(0x8b))%16; //字節(jié)低4位的BCD碼放入sel
lcm_w_test(0,0x97);//寫入指定區(qū)域97H 第二行第8個(gè)字
if(sel==7) {lcm_w_word("日");} //
if(sel==6) {lcm_w_word("六");} //
if(sel==5) {lcm_w_word("五");} //
if(sel==4) {lcm_w_word("四");} //
if(sel==3) {lcm_w_test(1,0xc8);lcm_w_test(1,0xfd);} //此指令等于lcm_w_word("三"); 因?yàn)椤叭钡膬?nèi)碼失效。
if(sel==2) {lcm_w_word("二");} //
if(sel==1) {lcm_w_word("一");} //星期一
lcm_w_test(0,0x95);
lcm_w_word("星期");
//向LCM中填寫 日 數(shù)據(jù)
void lcm_w_dd(void){
// if(read_clock(0x87) != dd){
lcm_w_test(0,0x92);
if(dd/16 != 0){lcm_w_test(1,(dd/16)+0x30);} //十位消隱
lcm_w_test(1,dd%16+0x30);
lcm_w_test(0,0x93);
lcm_w_word("日 ");
//向LCM中填寫 小時(shí) 數(shù)據(jù)
void lcm_w_hh(void){
if(read_clock(0x85) != hh){
if (hh > 0x07 && hh < 0x22 && w == 0){
Beep();//整點(diǎn)報(bào)時(shí)音
lcm_w_test(0,0x88);
lcm_w_test(1,(hh/16)+0x30);
lcm_w_test(1,hh%16+0x30);
//向LCM中填寫 分鐘 數(shù)據(jù)
void lcm_w_mm(void)
if(read_clock(0x83) != mm){
if(w == 0)
days();//節(jié)日顯示
lcm_w_test(0,0x89);
lcm_w_test(1,0x3a); //":"
lcm_w_test(1,(mm/16)+0x30);
lcm_w_test(1,mm%16+0x30);
lcm_w_test(1,0x2e); //"."
//刷新數(shù)據(jù)
void updata (void){
lcm_w_mm();//刷新 分
lcm_w_hh();//刷新 小時(shí)
lcm_w_dd();//刷新 日
lcm_w_xq();//更新星期值
lcm_w_mo();//刷新 月
lcm_w_yy();//刷新 年
//向LCM中填寫 秒 數(shù)據(jù)
void lcm_w_ss(void){
unsigned int i=0;
unsigned char a=0,b=0,c=0;
if(read_clock(0x81) != ss){ //判斷是否需要更新
ss = read_clock(0x81); //更新數(shù)據(jù)
lcm_w_test(0,0x8b); //秒值在LCM上的寫入位置
lcm_w_test(1,(ss/16)+0x30); //寫十位
lcm_w_test(1,ss%16+0x30); //寫個(gè)位
lcm_w_word(" ");
led_b = ~led_b; //LED閃爍
lcm_w_test(0,0x8d); //溫度在LCM上的寫入位置
i=ReadTemperature();//讀溫度并送顯
a=i/100;
lcm_w_test(1,a+0x30); //顯示溫度十位
b=i/10-a*10;
lcm_w_test(1,b+0x30); //個(gè)位
c=i-a*100-b*10;
lcm_w_test(1,c+0x30); //小位1位
lcm_w_word("℃"); //度C
void welcome(void){
lcm_w_word(" 0123456789 ABCDEFG ");//
//----------|-------1-------|-------3-------|-------2-------|-------4-------|-----//標(biāo)尺
//---主程序---//
main() {
unsigned char e=0;
KEY_I = 0;KEY_1 = 1;KEY_2 = 1;KEY_3 = 1;KEY_4 = 1;//初始鍵盤
yy=0xff;mo=0xff;dd=0xff;xq=0xff;hh=0xff;mm=0xff;ss=0xff; //各數(shù)據(jù)刷新
Beep();
led_back = 0;
Init_1302();
lcm_init();//初始化液晶顯示器
lcm_clr();//清屏
welcome();//顯示歡迎信息
DelayM(3000); //顯示等留3秒
while(1){//主循環(huán)
if (w == 0){ //正常走時(shí)
lcm_w_ss();//刷新 秒
else { //啟動(dòng)調(diào)時(shí)
if (KEY_3 == 0) // 設(shè)置時(shí)間
DelayM(20); //去抖
led_g3 = 0;led_r = 1;
if(KEY_3 == 0 && w == 1) //當(dāng)是調(diào)時(shí)狀態(tài) 本鍵用于調(diào)整下一項(xiàng)
Beep_key();//按鍵音
e++;
if (e >= 6 ){e = 0;}
Set_time(e);//調(diào)整
if(KEY_3 == 0 && w == 0) //當(dāng)是正常狀態(tài)時(shí)就進(jìn)入調(diào)時(shí)狀態(tài)
Beep_set();//確定按鍵音
led_b = 1;//
lcm_clr();//清屏
w=1; //進(jìn)入調(diào)時(shí)
lcm_w_test(0,0x9e);
lcm_w_word(" [-]");
lcm_w_test(0,0x80);
lcm_w_word("[Esc]");
lcm_w_test(0,0x85);
lcm_w_word("[Next]");
lcm_w_test(0,0x98);
lcm_w_word("[+]");
while(KEY_3 == 0);//等待鍵松開
led_g3 = 1; led_r = 0;//紅燈亮表示調(diào)時(shí)
if (KEY_1 == 0) // 當(dāng)在調(diào)時(shí)狀態(tài)時(shí)就退出調(diào)時(shí)
DelayM(20);
led_g1 = 0;led_r = 1;
if(KEY_1 == 0 && w == 1){
Beep_set();//確定按鍵音
w = 0; //退出調(diào)時(shí)
e = 0; //“下一項(xiàng)”計(jì)數(shù)器清0
if(KEY_1 == 0 && w == 0){
lcm_clr();//清屏
lcm_w_test(0,0x80);
welcome();//顯示歡迎信息
while(KEY_1 == 0);//等待鍵松開
lcm_clr();//清屏
lcm_w_mm();//刷新 分
led_g1 = 1;
if (KEY_2 == 0 && w == 1) // 加減調(diào)整{
DelayM(20);
led_g2 = 0;led_r = 1;
if(KEY_2 == 0 && w == 1){
Beep_key();//按鍵音
while(KEY_2 == 0);//等待鍵松開
led_g2 = 1; led_r = 0;
if (KEY_4 == 0 && w == 1){ // 加減調(diào)整
DelayM(20);
led_g4 = 0;led_r = 1;
if(KEY_4 == 0 && w == 1){
Beep_key();//按鍵音
while(KEY_4 == 0);
led_g4 = 1; led_r = 0;
