查看: 1535|回復(fù): 1
時鐘程序
ID:228134 發(fā)表于 2017-9-8 14:35 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <STC12C5A60S2.H>
#include <intrins.h>
#define                ulong        unsigned long
#define                uint        unsigned int
#define                uchar        unsigned char
#define NOP4 _nop_();_nop_();_nop_();_nop_()
#define CHAR 0xab
#define ES_ON AUXR |= 0x10; ES=1
#define ES_OFF AUXR &= 0xEF; ES=0
#include "zimo2.h"
#include "DS3231 + AT24C32.h"        // μ¼èëDS3231 + AT24C32Çy¶ˉ3ìDò
sbit KEYS=P2^0;            //μ÷Õû¼ü£¬°′ò»′ÎéèÖÃ×′ì¬Î»¼ó1,ÂÖá÷ÇD»»μ½éèÖÃÄê,ÔÂ,èÕ,ê±,·Ö,Ãë,DÇÆú,Õy3£×′ì¬.
sbit KEYA=P2^1;            //¼óò»¼ü£¬ÔúéèÖÃ×′ì¬ê±°′ò»′ÎÏàó|éèÖÃλ¼ó1
sbit KEYD=P2^2;            //¼õò»¼ü£¬ÔúéèÖÃ×′ì¬ê±°′ò»′ÎÏàó|éèÖÃλ¼õ1
sbit KEYM=P2^3;            //ÏÔê¾Ä£ê½¼ü£¬ÔúéèÖÃèyDD»ò¶tDDÏÔê¾
uchar MODE=0;               //ÏÔê¾Ä£ê½Ö¸ê¾£¬0Îa¶tDDÏÔê¾£¬1ÎaèyDDÏÔê¾
#include <set.h> //¼ü¿Øéèê±¼äí·Îļt
//Ô-3ìDòÖDμÄáa½ó
sbit G1=P0^4;
sbit G2=P0^5;
sbit R1=P2^6;
sbit R2=P2^7;
sbit LS=P0^6;
sbit CK=P0^7;
sbit OE=P2^5;
sbit IA  =P0^0;  //DD¿ØÖÆÏßA
sbit IB  =P0^1;  //DD¿ØÖÆÏßB
sbit IC  =P0^2;  //DD¿ØÖÆÏßC
sbit ID  =P0^3;  //DD¿ØÖÆÏßD
#define  ABCD P0                   //ABCD½óμ½P2.0-P2.3
#define  scan0    {IA=0;IB=0;IC=0;ID=0;}
#define  scan1    {IA=1;IB=0;IC=0;ID=0;}
#define  scan2    {IA=0;IB=1;IC=0;ID=0;}
#define  scan3    {IA=1;IB=1;IC=0;ID=0;}
#define  scan4    {IA=0;IB=0;IC=1;ID=0;}
#define  scan5    {IA=1;IB=0;IC=1;ID=0;}
#define  scan6    {IA=0;IB=1;IC=1;ID=0;}
#define  scan7    {IA=1;IB=1;IC=1;ID=0;}
#define  scan8    {IA=0;IB=0;IC=0;ID=1;}
#define  scan9    {IA=1;IB=0;IC=0;ID=1;}
#define scan10    {IA=0;IB=1;IC=0;ID=1;}
#define scan11    {IA=1;IB=1;IC=0;ID=1;}
#define scan12    {IA=0;IB=0;IC=1;ID=1;}
#define scan13    {IA=1;IB=0;IC=1;ID=1;}
#define scan14    {IA=0;IB=1;IC=1;ID=1;}
#define scan15    {IA=1;IB=1;IC=1;ID=1;}
bit  SHAN;               //éá˸±ê־λ,
uchar TC=0,TC1=0;                //Ñóê±¼ÆêyóÃ
uchar con=1;                       //Ãë¼ÆêyÆ÷,óÃóú1.5ÃëÂÖÏÔ1«Å©àúèÕÆú,·Öê±ÏÔê¾1«Å©àú
uchar CKTIME_1=0;                   //ê±¼ä¿ìÂyμ÷Õû±êÖ¾
sbit GPS_POW=P3^6;                                  //gpsμçÔ′¿ØÖÆ
uchar data row;                                        //DDé¨Ãè±äá¿
uchar data RD1[8];                                //êy¾Y»o′æ
uchar data GD1[8];
ID:167337 發(fā)表于 2017-9-8 16:27 | 只看該作者
樓主這是32*64雙色點陣GPS效時程序嗎?亂碼、無頭、無尾?
