查看: 3960|回復: 3
想在避障模塊多完善一些 就是讓小車停止一會兒然后向后轉再向左轉,怎么改寫比較好?
回帖獎勵 50 黑幣 回復本帖可獲得 5 黑幣獎勵! 每人限 1 次
ID:229453 發表于 2017-9-2 23:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include " LCD1602.h "
sbit zuo = P1^0;
sbit you = P1^1;
sbit zhong = P1^2;
sbit IN1 = P2^1;           //P2.0到P2.3是電機驅動輸出控制端
sbit IN2 = P2^2;
sbit IN3 = P2^3;
sbit IN4 = P2^4;
sbit Trig = P2^0;      //產生脈沖引腳
sbit Echo = P3^3;      //回波引腳
uint distance[4];      //測距接收緩沖區
unsigned char code ASCII[16]  = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
unsigned char disbuff[4]= { 0,0,0,0,};
uint distance1;
bit succeed_flag;      //測量成功標志
void chaoshengbo();
void delay_20us();
void delay_ms(uint x);
void delay(uint t);
void Tracking();
void shunback();
//延時程序1
void delay(uint t)
        uchar j;
    while(t--)
        {for(j=5;j>0;j--);}
//微妙延時程序
void delay_us(uint x)
do {
     x--;
while(x>1);
//毫秒延時
        while(x!=0)
                delay_us(500);
                x--;
//20微妙延時
void delay_20us()
        uchar bt ;
    for(bt=0;bt<100;bt++);
void Init()
    Trig=0;
        TMOD = 0x11;        //T/C1采用16位定時器/計數器
        ET1  = 1;                //定時器1開中斷
    ET0  = 1;
        TH0 = 0x00;
    TL0 = 0x00;
        TH1 = 0xff;
    TL1 = 0xce;
        TR1=1;
    TR0        = 1;                //定時計數器啟動計數
        EX0         = 1;                //外部中斷0關中斷
        PT1  = 1;
        EA         = 1;                //CPU開中斷
//超聲波測距
void chaoshengbo()
        uint distance_data,S;
        Trig=1;
    delay_20us();
    Trig=0;         //產生一個20us的脈沖,在Trig引腳
    while(!Echo);   //等待Echo回波引腳變高電平
    TR0=1;          //啟動定時器1
        while(Echo);
        TR0=0;
        delay_ms(7);
        distance_data=TH0*256+TL0;
        TH0=0;
        TL0=0;
        S=(distance_data*1.7)/100;
        if(succeed_flag==1)
                distance1=S;
        disbuff[0]=((S/100)%10);
          disbuff[1]=((S/10)%10);
          disbuff[2]=(S%10);
          DisplayOneChar(9, 0, ASCII[disbuff[0]]);
          DisplayOneChar(10, 0, ASCII[10]);               //顯示點
          DisplayOneChar(11, 0, ASCII[disbuff[1]]);
          DisplayOneChar(12, 0, ASCII[disbuff[2]]);
          DisplayOneChar(13, 0, ASCII[12]);               //顯示M
//左轉
void comeleft()
        IN1=0;
        IN2=1;
        IN3=1;
        IN4=1;
//右轉
void comeright ()
        IN1=1;
        IN2=1;
        IN3=1;
        IN4=0;
//前進加速;
void comeon()
        IN1=0;
        IN2=1;
        IN3=0;
        IN4=1;
void stop()
                   IN1=0;
                IN2=0;
                IN3=0;
                IN4=0;
void backward()
                IN1=1;
                IN2=0;
                IN3=1;
                IN4=0;
//紅外尋跡
void Tracking()
     if(zuo==1&&zhong==1&&you==1)   //0是接受到黑線,1是白線
                comeon();
         else if(zuo==1&&zhong==0&&you==1)
              comeon();
         else if(zuo==0&&zhong==1&&you==1)
                  comeleft();
         else if(zuo==0&&zhong==0&&you==1)
              comeleft();
         else if(zuo==1&&zhong==1&&you==0)
             comeright();
         else if(zuo==1&&zhong==0&&you==0)
             comeright();
                stop();
//避障
void shunback()
        chaoshengbo();
        delay_ms(50);
    Tracking();// 避障運行
        if(distance1<8)                //當超聲波測距距離小于8則
                stop();                        //小車停止運動
                delay_ms(50);
//                backward();
//                delay_ms(100);
//                comeleft();
//                delay_ms(60);
                 TR1=1;
                 delay_ms(50);
                 TR1=0;
            Tracking();
        }     //否則小車直走
//主函數
void main(void)
    Init();                   //初始化
        LCMInit();             //LCM初始化
        TMOD=0x01;
        TH0=0;          //定時器1清零
    TL0=0;          //定時器1清零
        ET0=1;                        //打開外部中斷
        EA=1;
        succeed_flag=0; //清測量成功標志
        displayfun();
        chaoshengbo();
        shunback();                  //循環調用超聲波測距
        Tracking();
//外部中斷0,用做判斷回波電平
INTO_()  interrupt 0  // 外部中斷是0號
    succeed_flag=1;   //至成功測量的標志
#ifndef __lcd1602__
#define __lcd1602__
//定義引腳
sbit LCM_RS = P2^6;
sbit LCM_RW = P2^5;
sbit LCM_E  = P2^7;
//數據口定義
#define LCM_Data P0
sbit BF=LCM_Data^7;                //忙信號線
//數組變量
unsigned char code  yuyiny[18]={
        0x00,0x10,0x18,0x20,0x28,0x30,0x38,0x40,
        0x48,0x50,0x58,0x60,0x68,0x70,0x78,0x80,0x88,0x98};
unsigned char inittime[7]={0x00,0x00,0x12,0x03,0x04,0x06,0x10};         //初始化時間
//變量
#define uint  unsigned int
函 數 名:unsigned char ReadStatusLCM(void)
功    能:忙檢測
說    明:
入口參數:無
返 回 值:無
        bit busy =0;
        LCM_Data = 0xFF;
        LCM_RS   = 0;
        LCM_RW   = 1;
        LCM_E    = 1;
        LCM_E    = 1;
        busy     = BF;
        LCM_E    = 0;
        return(busy);
函 數 名:void WriteCommandLCM(unsigned char WCLCM,BuysC)
功    能:寫命令
說    明:
入口參數:WCLCM
                   BuysC 需要忙檢測
返 回 值:無
void WriteCommandLCM(unsigned char WCLCM,BuysC)  //BuysC為0時忽略忙檢測
        if (BuysC) ReadStatusLCM();                  //根據需要檢測忙
        while (ReadStatusLCM());
        LCM_RS = 0;
        LCM_RW = 0;
        LCM_Data = WCLCM;
        LCM_E = 1;
        LCM_E = 0;
函 數 名:void WriteDataLCM(unsigned char WDLCM
功    能:寫數據
說    明:
入口參數:WDLCM
返 回 值:無
void WriteDataLCM(unsigned char WDLCM)
        while(ReadStatusLCM());                      //檢測忙
        LCM_RS = 1;
        LCM_RW = 0;
        LCM_Data = WDLCM;
        LCM_E = 1;
        LCM_E = 0;
函 數 名:void LCMInit(void)
功    能:LCM初始化
說    明:
入口參數:無
返 回 值:無
void LCMInit(void)
        WriteCommandLCM(0x38,1);                     //顯示模式設置,開始要求每次檢測忙信號
        WriteCommandLCM(0x0C,1);                     //顯示開及光標設置
        WriteCommandLCM(0x06,1);                     //顯示光標移動設置
        WriteCommandLCM(0x01,1);                     //顯示清屏
函 數 名:void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
功    能:按指定位置顯示一個字符
說    明:
入口參數:X 一行顯示個數限制
           Y 上下行限制
                   DData 數據
返 回 值:無
        Y &= 0x1;
        X &= 0xF;                         //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40;                 //當要顯示第二行時地址碼 0x40;
        X |= 0x80;                        // 算出指令碼
        WriteCommandLCM(X, 0);            //這里不檢測忙信號,發送地址碼
        WriteDataLCM(DData);
函 數 名:void displayfun(void)
功    能:界面顯示
說    明:
入口參數:無
返 回 值:無
        WriteCommandLCM(0x0c,1);                                    //顯示屏打開,光標不顯示,不閃爍,檢測忙信號
        /*顯示 鬧鐘 設置*/
        DisplayOneChar(0,0,'D');
        DisplayOneChar(1,0,'i');
        DisplayOneChar(2,0,'s');
        DisplayOneChar(3,0,'t');
        DisplayOneChar(4,0,'a');
        DisplayOneChar(5,0,'n');
        DisplayOneChar(6,0,'c');
        DisplayOneChar(7,0,'e');
        DisplayOneChar(8,0,':');
#endif
ID:198530 發表于 2017-9-3 11:16 | 只看該作者
可以判斷超聲波距離小于一定大小時小車停止延時一定時間在執行其他操作
ID:229453 發表于 2017-9-3 13:14 | 只看該作者
king_zxt 發表于 2017-9-3 11:16
我也是這樣想的不過當我在避障模塊加入其它指令,實測小車就一直執行我加的命令,比如先停止,然后后退最后左轉,就一直這樣循環執行,超聲波測的顯示的數據變化不準,如果不加直stop,就會執行尋跡指令...
ID:219796 發表于 2017-9-6 01:43 來自觸屏版 | 只看該作者
轉彎前加個延遲
