利用89c52,用DHT11,將溫濕顯示到LCD1602屏幕上
- #include <reg52.h>
- #include <intrins.h>
- typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
- typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
- typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
- typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
- typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
- typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
- typedef float F32; /* single precision floating point variable (32bits) 單精度浮點數(shù)(32位長度) */
- typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點數(shù)(64位長度) */
- #define uchar unsigned char
- #define uint unsigned int
- #define Data_0_time 4
- U8 str1[]={" "};
- U8 str2[]={" "};
- //----------------IO口定義區(qū)--------------------//
- sbit P2_0 = P2^0 ;
- sbit RS = P2^6; //定義端口
- sbit RW = P2^5;
- sbit EN = P2^7;
- #define RS_CLR RS=0
- #define RS_SET RS=1
- #define RW_CLR RW=0
- #define RW_SET RW=1
- #define EN_CLR EN=0
- #define EN_SET EN=1
- #define DataPort P0
- //----------------定義區(qū)--------------------//
- U8 TH_data,TL_data,RH_data,RL_data,CK_data;
- U8 U8FLAG,k;
- U8 U8count,U8temp;
- U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- U8 U8comdata;
- void delayms(U16 xms)
- U16 i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void Delay(U16 j)
- { U8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- void Delay_10us(void)
- U8 i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- mS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
- unsigned char 是定義無符號字符變量,其值的范圍是
- 0~255 這里使用晶振12M,精確延時請使用匯編
- 判忙函數(shù)
- bit LCD_Check_Busy(void)
- DataPort= 0xFF;
- RS_CLR;
- RW_SET;
- EN_CLR;
- _nop_();
- EN_SET;
- return (bit)(DataPort & 0x80);
- 寫入命令函數(shù)
- void LCD_Write_Com(unsigned char com)
- while(LCD_Check_Busy()); //忙則等待
- RS_CLR;
- RW_CLR;
- EN_SET;
- DataPort= com;
- _nop_();
- EN_CLR;
- 寫入數(shù)據(jù)函數(shù)
- void LCD_Write_Data(unsigned char Data)
- RS_SET;
- RW_CLR;
- EN_SET;
- DataPort= Data;
- _nop_();
- EN_CLR;
- 清屏函數(shù)
- void LCD_Clear(void)
- LCD_Write_Com(0x01);
- delayms(1);
- 寫入字符串函數(shù)
- void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
- if (y == 0)
- LCD_Write_Com(0x80 + x); //表示第一行
- else
- LCD_Write_Com(0xC0 + x); //表示第二行
- while (*s)
- LCD_Write_Data( *s);
- s ++;
- 寫入字符函數(shù)
- void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
- if (y == 0)
- else
- LCD_Write_Data( Data);
- 初始化函數(shù)
- void LCD_Init(void)
- LCD_Write_Com(0x38); /*顯示模式設(shè)置*/
- delayms(5);
- delayms(5);
- delayms(5);
- LCD_Write_Com(0x08); /*顯示關(guān)閉*/
- LCD_Write_Com(0x01); /*顯示清屏*/
- LCD_Write_Com(0x06); /*顯示光標移動設(shè)置*/
- delayms(5);
- LCD_Write_Com(0x0C); /*顯示開及光標設(shè)置*/
- void COM(void)
- U8 i;
- for(i=0;i<8;i++)
- U8FLAG=2;
- while((!P2_0)&&U8FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- U8temp=0;
- if(P2_0)U8temp=1;
- U8FLAG=2;
- while((P2_0)&&U8FLAG++);
- //超時則跳出for循環(huán)
- if(U8FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
- U8comdata<<=1;
- U8comdata|=U8temp; //0
- }//rof
- //-----濕度讀取子程序 ------------
- //----以下變量均為全局變量--------
- //----溫度高8位== U8T_data_H------
- //----溫度低8位== U8T_data_L------
- //----濕度高8位== U8RH_data_H-----
- //----濕度低8位== U8RH_data_L-----
- //----校驗 8位 == U8checkdata-----
- //----調(diào)用相關(guān)子程序如下----------
- //---- Delay();, Delay_10us();,COM();
- void RH(void)
- //主機拉低18ms
- P2_0=0;
- Delay(180);
- P2_0=1;
- //總線由上拉電阻拉高 主機延時20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機設(shè)為輸入 判斷從機響應(yīng)信號
- P2_0=1;
- //判斷從機是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運行
- if(!P2_0) //T !
- U8FLAG=2;
- //判斷從機是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
- U8FLAG=2;
- //判斷從機是否發(fā)出 80us 的高電平,如發(fā)出則進入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- U8RH_data_H_temp=U8comdata;
- COM();
- U8RH_data_L_temp=U8comdata;
- COM();
- U8T_data_H_temp=U8comdata;
- COM();
- U8T_data_L_temp=U8comdata;
- COM();
- U8checkdata_temp=U8comdata;
- P2_0=1;
- //數(shù)據(jù)校驗
- U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
- if(U8temp==U8checkdata_temp)
- U8RH_data_H=U8RH_data_H_temp;
- U8RH_data_L=U8RH_data_L_temp;
- U8T_data_H=U8T_data_H_temp;
- U8T_data_L=U8T_data_L_temp;
- U8checkdata=U8checkdata_temp;
- }//fi
- }//fi
- void main()
- LCD_Init();
- LCD_Clear();//清屏
- LCD_Write_String(0,0,"shidu:");
- LCD_Write_String(0,1,"wendu:");
- LCD_Write_Char(9,0,'%');
- LCD_Write_String(10,1,"C");
- LCD_Write_String(10,0,"RH");
- Delay(1); //延時100US(12M晶振)
- while(1)
1602DHT11工程文件.zip
(35.13 KB, 下載次數(shù): 68)
2017-8-30 13:00 上傳
下載積分: 黑幣 -5
