需要的拿去吧
ADF4351單片機驅動源程序如下(c語言代碼,請自行移植到各個嵌入式平臺.):
- #include "ADF4351.h"
- #include "delay.h"
- //#define
- #define ADF4351_R0 ((u32)0X2C8018)
- #define ADF4351_R1 ((u32)0X8029)
- #define ADF4351_R2 ((u32)0X10E42)
- #define ADF4351_R3 ((u32)0X4B3)
- #define ADF4351_R4 ((u32)0XEC803C)
- #define ADF4351_R5 ((u32)0X580005)
- #define ADF4351_R1_Base ((u32)0X8001)
- #define ADF4351_R4_Base ((u32)0X8C803C)
- #define ADF4351_R4_ON ((u32)0X8C803C)
- #define ADF4351_R4_OFF ((u32)0X8C883C)
- #define ADF4351_RF_OFF ((u32)0XEC801C)
- #define ADF4351_PD_ON ((u32)0X10E42)
- #define ADF4351_PD_OFF ((u32)0X10E02)
- void ADF_Output_GPIOInit(void)
- GPIO_InitTypeDef GPIO_InitStruct;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOA, &GPIO_InitStruct);
- void ADF_Input_GPIOInit(void)
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6;
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING ;
- void delay (int length)
- while (length >0)
- length--;
- void WriteToADF4351(u8 count, u8 *buf)
- u8 ValueToWrite = 0;
- u8 i = 0;
- u8 j = 0;
- // ADF_Output_GPIOInit();
- ADF4351_CE = 1;
- delay_us(1);
- ADF4351_CLK = 0;
- ADF4351_LE = 0;
- delay_us(1);
- for(i = count; i>0; i--)
- ValueToWrite = *(buf+i-1);
- for(j=0; j<8; j++)
- if(0x80 == (ValueToWrite & 0x80))
- ADF4351_OUTPUT_DATA = 1;
- else
- ADF4351_OUTPUT_DATA = 0;
- delay_us(1);
- ADF4351_CLK = 1;
- delay_us(1);
- ValueToWrite <<= 1;
- ADF4351_CLK = 0;
- delay_us(1);
- ADF4351_LE = 1;
- delay_us(1);
- ADF4351_LE = 0;
- void ReadToADF4351(u8 count, u8 *buf)
- u8 i = 0;
- u8 j = 0;
- u8 iTemp = 0;
- u8 RotateData = 0;
- ADF_Input_GPIOInit();
- ADF4351_CE = 1;
- delay_us(1);
- ADF4351_CLK = 0;
- ADF4351_LE = 0;
- delay_us(1);
- for(j = 0; j<8; j++)
- RotateData <<=1;
- delay_us(1);
- iTemp = ADF4351_INPUT_DATA;
- ADF4351_CLK = 1;
- if(0x01 == (iTemp&0x01))
- RotateData |= 1;
- delay_us(1);
- ADF4351_CLK = 0;
- *(buf+i-1) = RotateData;
- delay_us(1);
- ADF4351_LE = 1;
- delay_us(1);
- ADF4351_LE = 0;
- void ADF4351Init(void)
- u8 buf[4] = {0,0,0,0};
- ADF_Output_GPIOInit();
- buf[3] = 0x00;
- buf[2] = 0x58; //R5
- buf[1] = 0x00; //write communication register 0x00580005 to control the progress
- buf[0] = 0x05; //to write Register 5 to set digital lock detector
- WriteToADF4351(4,buf);
- buf[3] = 0x00; //R4
- buf[2] = 0xec; //(DB23=1)The signal is taken from the VCO directly;(DB22-20:4H)the RF divider is 16;(DB19-12:C8H)R is 200
- buf[1] = 0x80; //(DB11=0)VCO powerd up;
- buf[0] = 0x3C; //(DB5=1)RF output is enabled;(DB4-3=3H)Output power level is 5
- buf[3] = 0x00;
- buf[2] = 0x00; //R3
- buf[1] = 0x04; //(DB14-3:96H)clock divider value is 150.
- buf[0] = 0xB3;
- buf[3] = 0x00; //R2
- // buf[2] = 0x01; //(DB6=1)set PD polarity is positive;(DB7=1)LDP is 6nS;
- // buf[1] = 0x0E; //(DB8=0)enable fractional-N digital lock detect;
- buf[2] = 0x00;
- buf[1] = 0x4E;
- buf[0] = 0x42; //(DB12-9:7H)set Icp 2.50 mA;
- WriteToADF4351(4,buf); //(DB23-14:1H)R counter is 1
- buf[3] = 0x00;
- buf[2] = 0x00; //R1
- buf[1] = 0x80; //(DB14-3:6H)MOD counter is 6;
- buf[0] = 0x29; //(DB26-15:6H)PHASE word is 1,neither the phase resync
- WriteToADF4351(4,buf); //nor the spurious optimization functions are being used
- //(DB27=1)prescaler value is 8/9
- buf[3] = 0x00;
- buf[2] = 0x2c;
- buf[1] = 0x80; //R0
- buf[0] = 0x18; //(DB14-3:0H)FRAC value is 0;
- WriteToADF4351(4,buf); //(DB30-15:140H)INT value is 320;
- // WriteOneRegToADF4351(ADF4351_R0);
- // WriteOneRegToADF4351(ADF4351_R1);
- // WriteOneRegToADF4351(ADF4351_R2);
- // WriteOneRegToADF4351(ADF4351_R3);
- // WriteOneRegToADF4351(ADF4351_R4);
- // WriteOneRegToADF4351(ADF4351_R5);
- void WriteOneRegToADF4351(u32 Regster)
- buf[3] = (u8)((Regster>>24)&(0X000000FF));
- buf[2] = (u8)((Regster>>16)&(0X000000FF));
- buf[1] = (u8)((Regster>>8) &(0X000000FF));
- buf[0] = (u8)((Regster)&(0X000000FF));
- void ADF4351_Init_some(void)
- WriteOneRegToADF4351(ADF4351_R2);
- WriteOneRegToADF4351(ADF4351_R3);
- WriteOneRegToADF4351(ADF4351_R5);
- void ADF4351WriteFreq(float Fre) // (xx.x) M Hz
- u16 Fre_temp, N_Mul = 1, Mul_Core = 0;
- u16 INT_Fre, Frac_temp, Mod_temp, i;
- u32 W_ADF4351_R0 = 0, W_ADF4351_R1 = 0, W_ADF4351_R4 = 0;
- float multiple;
- if(Fre < 35.0)
- Fre = 35.0;
- if(Fre > 4400.0)
- Fre = 4400.0;
- Mod_temp = 250;
- Fre = ((float)((u32)(Fre*10)))/10;
- Fre_temp = Fre;
- for(i = 0; i < 10; i++)
- if(((Fre_temp*N_Mul) >= 2199.9) && ((Fre_temp*N_Mul) <= 4400.1))
- break;
- Mul_Core++;
- N_Mul = N_Mul*2;
- multiple = (Fre*N_Mul)/25; //帶寬出已固定為參考25M,若改參考頻率,則應修改R4低字節
- INT_Fre = (u16)multiple;
- // if(((u32)(multiple*10000)%10)> 5)
- // multiple += 0.001;
- Frac_temp = ((u32)(multiple*250))%250;
- while(((Frac_temp%5) == 0) && ((Mod_temp%5) == 0))
- Frac_temp = Frac_temp/5;
- Mod_temp = Mod_temp/5;
- while(((Frac_temp%2) == 0)&&((Mod_temp%2) == 0))
- Frac_temp = Frac_temp/2;
- Mod_temp = Mod_temp/2;
- Mul_Core %= 7;
- W_ADF4351_R0 = (INT_Fre<<15)+(Frac_temp<<3);
- W_ADF4351_R1 = ADF4351_R1_Base + (Mod_temp<<3);
- W_ADF4351_R4 = ADF4351_R4_ON + (Mul_Core<<20);
- // WriteOneRegToADF4351(ADF4351_PD_OFF); //ADF4351_RF_OFF
- // WriteOneRegToADF4351((u32)(ADF4351_R4_OFF + (6<<20)));
- WriteOneRegToADF4351(ADF4351_RF_OFF);
- WriteOneRegToADF4351(W_ADF4351_R1);
- WriteOneRegToADF4351(W_ADF4351_R0);
- WriteOneRegToADF4351(W_ADF4351_R4);
- // WriteOneRegToADF4351(ADF4351_PD_ON);
- // WriteOneRegToADF4351((u32)(ADF4351_R4_ON + (Mul_Core<<20)));
復制代碼- #ifndef _ADF4351_H_
- #define _ADF4351_H_
- #include "sys.h"
- #define ADF4351_CLK PAout(7)
- #define ADF4351_OUTPUT_DATA PAout(6)
- #define ADF4351_LE PAout(5)
- #define ADF4351_CE PAout(4)
- #define ADF4351_INPUT_DATA PAin(1)
- void ADF4351Init(void);
- void ReadToADF4351(u8 count, u8 *buf);
- void WriteToADF4351(u8 count, u8 *buf);
- void WriteOneRegToADF4351(u32 Regster);
- void ADF4351_Init_some(void);
- void ADF4351WriteFreq(float Fre); // (xx.x) M Hz
- void ADF_Output_GPIOInit(void);
- #endif
2017-8-13 22:06 上傳
c語言代碼,請自行移植到各個嵌入式平臺
