包含程序和仿真
功能:按鍵或串口發送字符指令,控制步進電機正轉、反轉、停止、加速、減速動作
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- //------8拍-----
- uchar code zz[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //正轉
- uchar code fz[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; //反轉
- sbit K1=P3^0; //停止
- sbit K2=P3^1; //正轉
- sbit K3=P3^2; //反轉
- sbit K4=P3^3; //加速
- sbit K5=P3^4; //減速
- uchar state=0; //狀態變量
- uint Time=60; //延時時間,用于調速
- unsigned char receiveData='0';
- void UsartConfiguration(); //初始化串口
- void delay(uint ms) //延時,用于調速
- uint t;
- while(ms--)
- for(t=0;t<120;t++);
- void motor_zz() //正傳函數
- uint j;
- for(j=0;j<8;j++)
- if(P3==0xfb)
- break;
- P1=zz[j];
- delay(Time);
- void motor_fz() //反轉函數
- uint j;
- for(j=0;j<8;j++)
- if(P3==0xfb)
- break;
- P1=fz[j];
- delay(Time);
- void main()
- UsartConfiguration();
- while(1)
- while(state==0) //狀態0,停止
- if((K2==0)||(receiveData=='z')) //按下K2或串口接收到'z',電機正轉
- state=1;
- receiveData='0';
- break;
- if((K3==0)||(receiveData=='f')) //按下K3或串口接收到'f',電機反轉
- state=2;
- receiveData='0';
- break;
- P0=0xfb;
- P1=0x03;
- while(state==1) //狀態1,正轉
- if((K1==0)||(receiveData=='t')) //按下K1或串口接收到'f',電機反轉
- state=0;
- receiveData='0';
- break;
- state=1;
- receiveData='0';
- break;
- state=2;
- receiveData='0';
- break;
- if((K4==0)||(receiveData=='+')) //按下K4或串口接收到'+',電機加速
- Time=Time-5;
- if(Time<20)
- Time=20;
- while(K4==0);
- if((K5==0)||(receiveData=='-')) //按下K5或串口接收到'-',電機減速
- Time=Time+5;
- if(Time>100)
- Time=100;
- while(K5==0);
- motor_zz(); //狀態1,正轉
- while(state==2) //狀態2,反轉
- state=0;
- receiveData='0';
- break;
- state=1;
- receiveData='0';
- break;
- state=2;
- receiveData='0';
- break;
- Time=Time-5;
- if(Time<20)
- Time=20;
- while(K4==0);
- Time=Time+5;
- if(Time>100)
- Time=100;
- while(K5==0);
- motor_fz(); //狀態2,反轉
- * 函數名 :UsartConfiguration()
- * 函數功能 :設置串口
- * 輸入 : 無
- * 輸出 : 無
- SCON=0X50; //設置為工作方式1
- //TMOD=0X20; //設置計數器工作方式2
- TMOD=0X21; //設置計數器工作方式2 和定時器0
- PCON=0X80; //波特率加倍
按鍵&串口控制步進電機正反轉調速.zip
(163.03 KB, 下載次數: 644)
2017-8-11 08:40 上傳
