** 紅龍開發(fā)板
** 實驗名: 紅龍板_基定時器(帶視頻)
** KEIL MDK-ARM Standard Version:4.11
** 軟件庫(keil) Version: unused
** 固件庫(ST) Version: V3.5
** 使用外設(shè): 基定時器
程序測試說明: #define TEST_1 TEST_1 LED燈測試
#define TEST_2 TEST_2 按鍵測試
LED 測試說明:注釋掉 TEST_2 按鍵測試 //#define TEST_2
初始化系統(tǒng)時鐘
LED燈的IO口初始化
測試現(xiàn)象: JLINK下載運行后,三個LED燈輪番閃爍。
TIM 測試說明:TIM定時器定時點燈(高級定時器TIM1,通用定時器TIM2 均可設(shè)置,
其他定時器以此為例,均能快速掌握)
步驟:初始化系統(tǒng)時鐘
中斷初始化
TIM初始化
注意:中斷使能(NVIC)
中斷函數(shù)調(diào)用(STM32F10X_IT.C)
實驗現(xiàn)象:
JLINK下載運行后
軟件:定時時間到,發(fā)生一次更新事件Update;
硬件:LED1燈按設(shè)置閃爍。打開和關(guān)閉LED3由亮漸滅控制。
*函數(shù)名稱:void RCC_Configuration(void)
*功能說明:系統(tǒng)時鐘初始化配置
* RCC_HSICmd(ENABLE);//使能內(nèi)部高速晶振 ;
* RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//選擇內(nèi)部高速時鐘作為系統(tǒng)時鐘SYSCLOCK=8MHZ
* RCC_HCLKConfig(RCC_SYSCLK_Div1); //選擇HCLK時鐘源為系統(tǒng)時鐘SYYSCLOCK
* RCC_PCLK1Config(RCC_HCLK_Div4); //APB1時鐘為2M
* RCC_PCLK2Config(RCC_HCLK_Div4); //APB2時鐘為2M
* RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);//使能APB2外設(shè)GPIOB時鐘
void RCC_Configuration(void);
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
while (RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08);
#define GPIO_IN GPIOB
#define GPIO_PWM GPIOA
#define GPIO_Pin_IN1 GPIO_Pin_1
#define GPIO_Pin_IN2 GPIO_Pin_2
#define GPIO_Pin_IN3 GPIO_Pin_5
#define GPIO_Pin_IN4 GPIO_Pin_6
#define GPIO_PWM_A GPIO_Pin_8
#define GPIO_PWM_B GPIO_Pin_11
#define IN1_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN1);
#define IN1_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN1);
#define IN2_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN2);
#define IN2_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN2);
#define IN3_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN3);
#define IN3_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN3);
#define IN4_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN4);
#define IN4_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN4);
#define PWM_A_OFF 1000
#define PWM_B_OFF 1000
- #define GPIO_IN GPIOB
- #define GPIO_PWM GPIOA
- #define GPIO_Pin_IN1 GPIO_Pin_1
- #define GPIO_Pin_IN2 GPIO_Pin_2
- #define GPIO_Pin_IN3 GPIO_Pin_5
- #define GPIO_Pin_IN4 GPIO_Pin_6
- #define GPIO_PWM_A GPIO_Pin_0
- #define GPIO_PWM_B GPIO_Pin_1
- #define IN1_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN1);
- #define IN1_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN1);
- #define IN2_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN2);
- #define IN2_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN2);
- #define IN3_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN3);
- #define IN3_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN3);
- #define IN4_H GPIO_SetBits(GPIO_IN,GPIO_Pin_IN4);
- #define IN4_L GPIO_ResetBits(GPIO_IN,GPIO_Pin_IN4);
- #define PWM_A_OFF 1001
- #define PWM_B_OFF 1001
- #include "pbdata.h"
- void TimCounterInit(int rate_1,int rate_2);
- void Gpio_PWM_Init(void);
- void Gpio_M_Init(void);
- void NVIC_Configuration(void);
- void TurnLeft(void);
- void TurnRight(void);
- void straight(void);
- void sternway(void);
- int A,B;
- /****主函數(shù)****/
- int main(void)
- u8 flag=1;
- Gpio_PWM_Init();
- Gpio_M_Init();
- while(flag==1)
- flag=0;
- straight();//直走
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(1000);
- TurnLeft();//左轉(zhuǎn)
- delay_ms(1000);
- delay_ms(500);
- straight();
- delay_ms(1000);
- TurnRight();
- delay_ms(1000);
- delay_ms(500);
- straight();
- delay_ms(500);
- TurnRight();
- delay_ms(1000);
- straight();
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(1000);
- // /* 回到中線 */
- // TurnLeft(1.5);
- // straight(0.5);
- // TurnLeft(0.5);
- // straight(4);
- // /* 回到中線 */
- // TurnRight(1.5);
- // straight(0.5);
- // TurnRight(1);
- // straight(2);
- // /* 回到中線 */
- // TurnLeft(1.5);
- // straight(0.5);
- // TurnLeft(1);
- // straight(2);
- // sternway(1);
- TimCounterInit(PWM_A_OFF,PWM_B_OFF);
- void TurnLeft()
- IN1_H IN2_L
- IN3_H IN4_L
- A=500;
- B=800;
- TimCounterInit(A,B);
- IN1_H IN2_L
- IN3_H IN4_L
- A=800;
- B=500;
- IN1_H IN2_L
- IN3_H IN4_L
- A=600;
- B=600;
- IN1_L IN2_H
- IN3_L IN4_H
- A=700;
- B=700;
- GPIO_InitTypeDef GPIO_InitStructure;
- //以下設(shè)定是將TIM2的通道1(PA0)的復(fù)用功能打開,這很重要很容易被忘掉
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_PWM_A|GPIO_PWM_B; //選擇led1
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管腳頻率為50MHZ
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //模式為復(fù)用推挽輸出
- GPIO_Init(GPIO_PWM, &GPIO_InitStructure); //初始化led1寄存器
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_IN1|GPIO_Pin_IN2|GPIO_Pin_IN3|GPIO_Pin_IN4; //選擇led1
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIO_IN, &GPIO_InitStructure); //初始化led1寄存器
- *函數(shù)名稱:void TimCounterInit(void)
- *功能說明:TIM計數(shù)初始化配置
- * TIMCLK = 72 MHz, Prescaler = TIM_PSC, TIM counter clock = TIMCLK/TIM_COUNTER MHz
- void TimCounterInit(int rate_1,int rate_2) //rate可以改變占空比
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /* TIM時鐘使能 */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
- /* 基定時器初始化 */
- TIM_TimeBaseStructure.TIM_Period = 1000000*0.001; //計數(shù)值 1000;須介于0~65535
- TIM_TimeBaseStructure.TIM_Prescaler = 72; //分頻系數(shù),為了設(shè)定值數(shù)值較大,這里選得較小
- TIM_TimeBaseStructure.TIM_ClockDivision = 0; //時鐘分割:計數(shù)模式中無作用
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //計數(shù)模式,向上計數(shù)
- TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; //重復(fù)計數(shù)值
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //初始化TIM
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//輸出模式設(shè)定
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//輸出模式使能
- TIM_OCInitStructure.TIM_Pulse = rate_1; //設(shè)置占空比,0時全低電平,1001時全高電平.須介于0~65535
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//輸出比較極性;最終輸出值是高/低電平
- TIM_OC1Init(TIM2, &TIM_OCInitStructure);//輸出通道x,參數(shù)寫入
- TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);//使能通道x預(yù)裝載寄存器
- TIM_OCInitStructure.TIM_Pulse = rate_2; //設(shè)置占空比,0時全低電平,1001時全高電平.須介于0~65535
- TIM_OC2Init(TIM2, &TIM_OCInitStructure);//輸出通道x,參數(shù)寫入
- TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);//使能通道x預(yù)裝載寄存器
- TIM_Cmd(TIM2, ENABLE); //使能TIM
1.PWM調(diào)速電機控制(6.10).rar
(279.69 KB, 下載次數(shù): 300)
2017-8-10 19:09 上傳
PWM
