查看: 2104|回復: 0
基于51的數字電壓表代碼
ID:225765 發表于 2017-8-8 16:57 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sbit EOC=P2^6;
sbit START=P2^5;
sbit OE=P2^7;
sbit CLK=P2^4;
long int a;
int b,c,d,e,f,g;
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//共陽極顯示0~9
unsigned char code table1[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};//共陽極顯示帶小數點0~9
void delay_display(unsigned int z)
  unsigned int x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void ADC0808()
  if(!EOC)
START=0;
START=1;
START=0;
while(!EOC);
START=1;
START=0;
while(EOC);
void bianma()
  START=0;
ADC0808();
a=P1*100;
a=a/51;
void yima()
b=a/1000;
c=a-b*1000;
d=c/100;
e=c-d*100;
f=e/10;
g=e-f*10;
void display()
P2=0xf1;
P0=table[b];
delay_display(1);
P2=0xf2;
P0=table1[d];
delay_display(1);
P2=0xf4;
P0=table[f];
delay_display(1);
P2=0xf8;
P0=table[g];
delay_display(1);
EA=1;
TMOD=0x02;
TH0=216;
TL0=216;
TR0=1;
ET0=1;
  bianma();
  yima();
  display();
void t0() interrupt 1 using 0
CLK=~CLK ;
