查看: 4684|回復(fù): 4
輸入模擬電壓,四位數(shù)碼管掃描顯示
ID:225441 發(fā)表于 2017-8-7 13:27 | 顯示全部樓層 |閱讀模式
#include "stm32f10x.h"
#include "adc.h"
#include "dac.h"
u16 ADC_ConvertedValue;
float ADC_ConvertedValueLocal;
u16 dacoutlow;
u16 dacouthigh;
unsigned int a , b ,c ,d;
void LED_GPIO_Config(void)
                /*定義一個(gè)GPIO_InitTypeDef類型的結(jié)構(gòu)體*/
                /*開啟LED相關(guān)的GPIO外設(shè)時(shí)鐘*/
                RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE);
                /*選擇要控制的GPIO引腳*/
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
void  Dig_Disp(int i)
        switch(i)
                case 0:
                             GPIO_ResetBits(GPIOB, GPIO_Pin_7);
        GPIO_ResetBits(GPIOB, GPIO_Pin_8);
        GPIO_ResetBits(GPIOB, GPIO_Pin_9);
        GPIO_ResetBits(GPIOB, GPIO_Pin_10);
        GPIO_ResetBits(GPIOB, GPIO_Pin_11);
        GPIO_ResetBits(GPIOB, GPIO_Pin_12);
        GPIO_SetBits(GPIOB, GPIO_Pin_13);
        GPIO_ResetBits(GPIOB, GPIO_Pin_14);
        break;
                case 1:
        GPIO_SetBits(GPIOB, GPIO_Pin_7);
        GPIO_SetBits(GPIOB, GPIO_Pin_10);
        GPIO_SetBits(GPIOB, GPIO_Pin_11);
        GPIO_SetBits(GPIOB, GPIO_Pin_12);
                break;
                case 2:
        GPIO_SetBits(GPIOB, GPIO_Pin_9);
        GPIO_ResetBits(GPIOB, GPIO_Pin_13);
                break;
                case 3:
                break;
                case 4:
                break;
                case 5:
        GPIO_SetBits(GPIOB, GPIO_Pin_8);
                break;
                case 6:
                break;
                case 7:
                break;
                case 8:
                break;
        case 9:
                break;
void  Dig_DispNP(int i)
        switch(i)
        {            case 0:
        GPIO_SetBits(GPIOB, GPIO_Pin_14);
        break;
                case 1:
                break;
                case 2:
                break;
                case 3:
                break;
                case 4:
                break;
                case 5:
                break;
                case 6:
                break;
                case 7:
                break;
                case 8:
                break;
        case 9:
                break;
void choose(int m)
        switch(m){                     case 0:
                             GPIO_SetBits(GPIOB, GPIO_Pin_0);
        GPIO_ResetBits(GPIOB, GPIO_Pin_1);
        GPIO_ResetBits(GPIOB, GPIO_Pin_5);
        GPIO_ResetBits(GPIOB, GPIO_Pin_6);
        Dig_DispNP(d);
        break;
                                                         case 1:
                      GPIO_ResetBits(GPIOB, GPIO_Pin_0);
        GPIO_SetBits(GPIOB, GPIO_Pin_1);
        Dig_DispNP(c);
                break;
                case 2:
        GPIO_SetBits(GPIOB, GPIO_Pin_5);
        Dig_Disp(b);
                break;
                case 3:
        GPIO_SetBits(GPIOB, GPIO_Pin_6);
                      Dig_DispNP(a);
void  Dig_OutPut(float f)
a = (int)(f*10)%10;                       //提取小數(shù)位
b =(int) (f)%10;                         //提取個(gè)位
c = (int)(f/10)%10;                     //提取十位
d = 0;        //提取千位
LED_GPIO_Config();
void delay(unsigned int i)
while(i--);
int main(void)
        int x=0;
        int ct=0;
        LED_GPIO_Config();
  ADC1_GPIO_Config();
        ADC1_Mode_Config();
        dac_Init();
                x++;
                ADC_SoftwareStartConvCmd(ADC1, ENABLE);
                while(!ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC));
                ADC_ConvertedValue=ADC_GetConversionValue(ADC1);
                dacoutlow=ADC_ConvertedValue/10;
                dacouthigh=dacoutlow*9;
                DAC_SetChannel1Data(DAC_Align_12b_R,dacoutlow);
                DAC_SoftwareTriggerCmd(DAC_Channel_1,ENABLE);
                DAC_SetChannel2Data(DAC_Align_12b_R,dacouthigh);
                DAC_SoftwareTriggerCmd(DAC_Channel_2,ENABLE);
          ADC_ConvertedValueLocal =(float) ADC_ConvertedValue*(float)10/4095;
                Dig_OutPut(ADC_ConvertedValueLocal);
                delay(1000);
                if(x==30)
                                ct++;
        x=0;
                if(ct==4)
                        ct=0;
                choose(ct);
ID:19715 發(fā)表于 2018-1-7 23:37 | 顯示全部樓層
怎么送數(shù)碼管段碼都是用獨(dú)位獨(dú)位發(fā)送,可以用寄存器操作,一次性8位發(fā)送就完事,簡單快捷啊
ID:273047 發(fā)表于 2018-1-8 09:51 | 顯示全部樓層
學(xué)習(xí)了
ID:271363 發(fā)表于 2018-1-8 10:57 | 顯示全部樓層
學(xué)習(xí)中
ID:418829 發(fā)表于 2018-10-31 22:40 | 顯示全部樓層
感謝樓主救我狗命
