只需一步,快速開(kāi)始
查看: 6051|回復(fù): 3
STM32 HX711+LCD12864電子秤程序
ID:223876 發(fā)表于 2017-8-1 16:20 | 顯示全部樓層 |閱讀模式
從別處找的電子秤程序STM32單片機(jī)主控 hx711芯片+12864液晶顯示 希望對(duì)大家有幫助
stm32單片機(jī)主程序如下:
  1. /******************** (C) COPYRIGHT 2012 WildFire Team **************************
  2. * 文件名  :main.c
  3. * 描述    :3個(gè)LED在 SysTick 的控制下,以500ms的頻率閃爍。
  4. * 實(shí)驗(yàn)平臺(tái):野火STM32開(kāi)發(fā)板
  5. * 庫(kù)版本  :ST3.5.0
  6. * 作者    :wildfire team
  7. **********************************************************************************/
  8. #include "stm32f10x.h"
  9. #include "SysTick.h"
  10. #include "12864.h"
  11. #include "HX711.h"
  12. uint32_t ticktime;
  13. unsigned long HX711_Buffer = 0;
  14. unsigned int Weight_Maopi = 0,Weight_Shiwu = 0;
  15. char Price_Count = 0;
  16. unsigned char KEY_NUM = 0;
  17. unsigned char Price_Buffer[5] = {0x00,0x00,0x00,0x00,0x00};
  18. unsigned long Money = 0;
  19. unsigned char Flag_OK = 0;
  20. unsigned char temp = 0,temp1 = 0xf7;
  21. /*
  22. * 函數(shù)名:main
  23. * 描述  :主函數(shù)
  24. * 輸入  :無(wú)
  25. * 輸出  :無(wú)
  26. */
  27. void Key_GPIO_Config(void)
  28. {         GPIO_InitTypeDef GPIO_InitStructTRIG;
  29.         RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);
  30.           GPIO_InitStructTRIG.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2;
  31.           GPIO_InitStructTRIG.GPIO_Mode = GPIO_Mode_Out_PP;
  32.           GPIO_InitStructTRIG.GPIO_Speed = GPIO_Speed_50MHz;
  33.           GPIO_Init(GPIOA, &GPIO_InitStructTRIG);
  34.         GPIO_SetBits(GPIOA, GPIO_Pin_1|GPIO_Pin_2 );
  35. }
  36. /********************************************************/
  37. void Led_GPIO_Config(void)
  38. {
  39.                 GPIO_InitTypeDef GPIO_InitStructure;
  40.         RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC, ENABLE);
  41.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  42.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  43.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  44.           GPIO_Init(GPIOC, &GPIO_InitStructure);
  45.         GPIO_SetBits(GPIOC, GPIO_Pin_3 );
  46. }
  47. /************************************************************/
  48. void Get_Weight()
  49. {
  50.         HX711_Buffer = HX711_Read();
  51.         HX711_Buffer = HX711_Buffer/100;
  52.         if(HX711_Buffer >= Weight_Maopi)
  53.         {
  54.                 Weight_Shiwu = HX711_Buffer;
  55.                 Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //獲取實(shí)物的AD采樣數(shù)值。
  56.
  57.                 Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/2.135+0.05);         //計(jì)算實(shí)物的實(shí)際重量
  58.        //因?yàn)椴煌膫鞲衅魈匦郧不一樣,因此,每一個(gè)傳感器需要矯正這里的2.15這個(gè)除數(shù)。
  59.        //當(dāng)發(fā)現(xiàn)測(cè)試出來(lái)的重量偏大時(shí),增加該數(shù)值。
  60.        //如果測(cè)試出來(lái)的重量偏小時(shí),減小改數(shù)值。
  61.        //該數(shù)值一般在2.15附近調(diào)整之間。因傳感器不同而定。
  62.        //+0.05是為了四舍五入百分位
  63.
  64.                 if(  Weight_Shiwu > 20000 )
  65.                 {
  66.                 GPIO_ResetBits(GPIOC, GPIO_Pin_3 );                                //打開(kāi)警報(bào)
  67.                 }
  68.                 else
  69.                 {
  70.                         GPIO_SetBits(GPIOC, GPIO_Pin_3 );                        //關(guān)閉警報(bào)
  71.                 }
  72.         }
  73.         else if(HX711_Buffer < Weight_Maopi - 30)
  74.         {
  75.                 GPIO_ResetBits(GPIOC, GPIO_Pin_3 );                                //負(fù)重量報(bào)警
  76.         }
  77. }
  78. //****************************************************
  79. //獲取毛皮重量
  80. //****************************************************
  81. void Get_Maopi()
  82. {
  83.         HX711_Buffer = HX711_Read();
  84.         Weight_Maopi = HX711_Buffer/100;
  85. }
  86. /******************************************************************/
  87. /******************************************************************/
  88. int main(void)
  89. {
  90.         Led_GPIO_Config();
  91.         Key_GPIO_Config();
  92.         /* 配置SysTick 為10us中斷一次 */
  93.         SysTick_Init();
  94.         /*********************************************************************/
  95.         /************************************************************************/
  96.     LCD12864_InitPort(); //端口初始化
  97.         LCD12864_Init();         //液晶初始化
  98.         HX711_init();
  99.   //  LCD12864_Pos(3,5);
  100.     LCD_ShowString(1,0,"初始化……");
  101. /*        LCD12864_NoWaitIdle_COM_Write(0x80);                                                //指針設(shè)置
  102.         LCD12864_write_word("※※※※※※※※");
  103.         LCD12864_NoWaitIdle_COM_Write(0x90);                                                //指針設(shè)置
  104.         LCD12864_write_word("※※歡迎使用※※");
  105.         LCD12864_NoWaitIdle_COM_Write(0x88);                                                //指針設(shè)置
  106.         LCD12864_write_word("※20公斤電子秤※");
  107.         LCD12864_NoWaitIdle_COM_Write(0x98);                                                //指針設(shè)置
  108.         LCD12864_write_word("※※※※※※※※");                   */
  109.         Get_Maopi();                                //稱毛皮重量
  110.
  111.         delay_ms(10000);                 //延時(shí)10s,等待傳感器穩(wěn)定
  112.         Price_Count = 0;
  113.         Price_Buffer[0] = 0;
  114.         Price_Buffer[1] = 0;
  115.         Price_Buffer[2] = 0;
  116.         Price_Buffer[3] = 0;
  117.         Price_Buffer[4] = 0;
  118.         Money = 0;
  119.         Flag_OK = 0;
  120.         Get_Maopi();                                //稱毛皮重量
  121.         LCD12864_Clr();                        //清空
  122.
  123.         while(1)
  124.         {
  125.                 delay_ms(500);
  126.                 LCD12864_Clr();
  127.                 LCD_ShowString(1,0,"上海工程技術(shù)大學(xué)");
  128.                 LCD_ShowString(2,0,"大學(xué)生創(chuàng)新項(xiàng)目");
  129.         //        LCD12684_Wdat(i+0x30);
  130.                         Get_Weight();                        //稱重
  131.
  132.                         //顯示當(dāng)前重量
  133.                         LCD_ShowString(3,0,"重量");
  134.                         LCD12864_Pos(3,2);
  135.                 //        LCD12684_Wdat('');
  136.                         if( Weight_Shiwu/10000 != 0)
  137.                         {
  138.                                 LCD12684_Wdat(Weight_Shiwu/10000 + 0x30);
  139.                         }
  140.                         else
  141.                         {
  142.                                 LCD12684_Wdat(' ');
  143.                         }
  144.                         LCD12684_Wdat(Weight_Shiwu%10000/1000 + 0x30);
  145.                         LCD12684_Wdat('.');
  146.                         LCD12684_Wdat(Weight_Shiwu%1000/100 + 0x30);
  147.                         LCD12684_Wdat(Weight_Shiwu%100/10 + 0x30);
  148.                         LCD12684_Wdat(Weight_Shiwu%10 + 0x30);
  149.                 LCD_ShowString(3,6,"kg");
  150.                 }
  151. }
  152. /******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
完整源碼51黑下載地址:
HX711+lcd12864.rar (286.38 KB, 下載次數(shù): 166)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:148337 發(fā)表于 2018-3-7 09:37 | 顯示全部樓層
串行還是并行
ID:290014 發(fā)表于 2019-1-3 16:48 | 顯示全部樓層
正需要這樣的程序,下來(lái)看看
ID:395289 發(fā)表于 2019-4-27 20:29 | 顯示全部樓層
wjh_004 發(fā)表于 2019-1-3 16:48
正需要這樣的程序,下來(lái)看看
能給我發(fā)一份嗎。謝謝1799835116@qq.com
