查看: 3753|回復: 0
基于fpga的串口收發(fā)代碼(工業(yè)環(huán)境下)
ID:223626 發(fā)表于 2017-7-31 17:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
以下是串口發(fā)送部分
module xiaoze_tx(
                 input  clk,
                                          input  rst_n,
                                          input  send_en,
                                          input [3:0] bps_set,
                                          input [7:0] data_in,
                                          output reg tx_done,
                                          output reg data_out,
                                          output reg tx_state,
                                         //************************測試******************
                                          output reg  bps_clk,
                 output reg [3:0] shift
reg  bps_clk;
reg [3:0] shift;
reg [15:0] bps;
reg [15:0] bps_cnt;
reg [7:0] data_in_a;
reg [7:0] data_in_b;
        always@(posedge clk  or  negedge rst_n)
          if(!rst_n)  bps <= 16'd 5207; //默認值為9600
     else begin
            case(bps_set)
                   4'd 0 : bps <= 16'd 5207; //9600
                   4'd 1 : bps <= 16'd 2603; //19200
              4'd 2 : bps <= 16'd 1301; //38400
                   4'd 3 : bps <= 16'd 867;  //57600
              4'd 4 : bps <= 16'd 433;  //115200
                   default : bps <= 16'd 5207;  //默認值為9600
                 endcase
   end
     if(!rst_n) bps_cnt <= 16'd 0;
     else if(tx_state == 1'b 1)  bps_cnt <= (bps_cnt == bps)? 16'd 0 : bps_cnt + 1'd 1;
          else   bps_cnt <= 16'd 0;
     if(!rst_n)  bps_clk <= 1'b 0;
     else if(bps_cnt == 16'd 1)  bps_clk <= 1'b 1;
     else  bps_clk = 1'b 0;
     if(!rst_n)  shift <= 4'd 0;
     else if(tx_done == 1'b 1) shift <=  4'd 0;
     else if(bps_clk == 1'b 1)  shift <= shift + 1'd 1;
          else  shift <= shift;
          if(!rst_n) begin
            data_in_a <= 8'b 0;
       data_in_b <= 8'b 0;
     end
          else begin
            data_in_a <= data_in;
              data_in_b <= data_in_a;
          end
          if(!rst_n)  data_out <= 1'b 1; //rx默認為高電平
          else begin
            case(shift)
                   4'd 0 :  data_out <= 1'b 1;//默認值
                   4'd 1 :  data_out <= 1'b 0; //起始位
                   4'd 2 :  data_out <= data_in_b[0];
              4'd 3 :  data_out <= data_in_b[1];
              4'd 4 :  data_out <= data_in_b[2];
              4'd 5 :  data_out <= data_in_b[3];
                   4'd 6 :  data_out <= data_in_b[4];
              4'd 7 :  data_out <= data_in_b[5];
              4'd 8 :  data_out <= data_in_b[6];
              4'd 9 :  data_out <= data_in_b[7];
                   4'd 10 :  data_out <= 1'b 1;//停止位
              4'd 11 :  data_out <= 1'b 1;//默認值
                        default : data_out <= 1'b 1;//默認值
                endcase
        end
  if(!rst_n)  tx_done <= 1'b 0;
  else if(shift == 4'd 11)  tx_done <= 1'b 1;
  else  tx_done <= 1'b 0;
  if(!rst_n)  tx_state <= 1'b 0;
  else if(send_en == 1'b 1)  tx_state <= 1'b 1;
  else if(tx_done == 1'b 1)  tx_state <= 1'b 0;
  else  tx_state <= tx_state;
  endmodule
//以下是串口接收部分
module xiaoze_rx(
                 input  clk,
                                          input  rst_n,
                                          input  data_in,
                                          input [2:0] bps,
                                          output reg rx_stop,
                                          output reg rx_state,
                                          output reg [7:0] data_out
//**********************數(shù)據(jù)定義區(qū)**************************
              reg [8:0] bps_set;
                                  reg  data_a;
                                  reg  data_b;
                                  reg  data_c;
                                  reg  data_d;
                                  wire  nedge;
                                  reg [8:0] cnt;
                                  reg  bps_clk;
                                  reg [7:0] shift;
                                  reg [2:0] data_read [7:0];
                                  reg [2:0] data_start;
                                  reg [2:0] data_stop;
                                  reg  start_n;
//波特率設置模塊
          if(!rst_n)  bps_set <= 9'd 324;
          else begin
            case(bps)
                   3'd 0 : bps_set<= 9'd 324;  //9600
                        3'd 1 : bps_set<= 9'd 162;  //19200
                        3'd 2 : bps_set<= 9'd 80;   //38400
                        3'd 3 : bps_set<= 9'd 53;   //57600
                        3'd 4 : bps_set<= 9'd 26;   //115200
            endcase
     end
//消除亞穩(wěn)態(tài)
          if(!rst_n) begin
            data_a <= 1'b 0;
                 data_b <= 1'b 0;
          end
          else begin
            data_a <= data_in;
            data_b <= data_a;
          end
//接收啟動模塊
          if(!rst_n) begin
            data_c <= 1'b 0;
                 data_d <= 1'b 0;
          end
          else begin
            data_c <= data_b;
                 data_d <= data_c;
          end
//分頻計數(shù)模塊
          if(!rst_n)  cnt <= 9'd 0;
          else if(rx_state) cnt <= (cnt == bps_set)?  9'd 0 : cnt + 1'd 1;
          else  cnt <= 9'd 0;
//波特率時鐘模塊
     else if(cnt == bps_set)  bps_clk <= 1'b 1;
     else bps_clk <= 1'b 0;
//移位計數(shù)模塊
         if(!rst_n)  shift <= 8'd 0;
         else if(rx_stop)  shift <= 8'd 0;
    else if(bps_clk)  shift <= shift + 1'd 1;
//傳送完成標志位設置,如果起始位接收失敗也要清零
         if(!rst_n)  rx_stop <= 1'b 0;
    else if(shift == 9'd 159  || (shift == 9'd 11 && data_read[0][2])) rx_stop <= 1'b 1;
    else  rx_stop <= 1'b 0;
//數(shù)據(jù)讀取模塊
   if(!rst_n) begin
         data_start <= 3'd 0;
         data_read[0] <= 3'd 0;
         data_read[1] <= 3'd 0;
         data_read[2] <= 3'd 0;
         data_read[3] <= 3'd 0;
         data_read[4] <= 3'd 0;
         data_read[5] <= 3'd 0;
         data_read[6] <= 3'd 0;
         data_read[7] <= 3'd 0;
          data_stop <= 3'd 0;
        end
        else if(bps_clk)  begin  // *else if (bps_clk)
          case(shift)
            0 : begin
         data_stop <= 3'd 0;
                 end
              5,6,7,8,9,10 : data_start <= data_start + data_b;
                        21,22,23,24,25,26 : data_read [0] <= data_read [0] + data_b;
                        37,38,39,40,41,42 : data_read [1] <= data_read [1] + data_b;
                        53,54,55,56,57,58 : data_read [2] <= data_read [2] + data_b;
                        69,70,71,72,73,74 : data_read [3] <= data_read [3] + data_b;
                        85,86,87,88,89,90 : data_read [4] <= data_read [4] + data_b;
                        102,103,104,105,106,107 : data_read [5] <= data_read [5] + data_b;
                        117,118,119,120,121,122 : data_read [6] <= data_read [6] + data_b;
                        133,134,135,136,137,138 : data_read [7] <= data_read [7] + data_b;
                        149,150,151,152,153,154 : data_stop<= data_stop + data_b;
     endcase
   end
//數(shù)據(jù)校準模塊
     if(!rst_n)  data_out <= 8'd 0;
          else if (shift == 8'd 159) begin
       data_out[0] <=data_read[0][2];
       data_out[1] <=data_read[1][2];
            data_out[2] <=data_read[2][2];
       data_out[3] <=data_read[3][2];
       data_out[4] <=data_read[4][2];
       data_out[5] <=data_read[5][2];
            data_out[6] <=data_read[6][2];
       data_out[7] <=data_read[7][2];
         end
//狀態(tài)位設置模塊
   if(!rst_n) rx_state <= 1'b 0;
   else if(nedge && shift < 8'd 5)  rx_state <= 1'b 1;
        else if(rx_stop)   rx_state <= 1'b 0;
        else  rx_state <= rx_state;
assign nedge = (data_d  && (!data_c));
endmodule
