查看: 6953|回復: 7
自制超聲波倒車小車(帶程序!原理圖!實物圖)
ID:212924 發表于 2017-7-31 09:18 | 顯示全部樓層 |閱讀模式
IMG_20170731_091217.jpg IMG_20170731_091151.jpg IMG_20170731_091147.jpg IMG_20170731_091141.jpg (~M52L(FXNFQFV9C0J[$GWQ.png
  1. #include <reg52.H>//Æ÷¼þÅäÖÃÎļþ
  2. #include <intrins.h>
  3. //´«¸ÐÆ÷½Ó¿Ú
  4. sbit RX  = P3^2;
  5. sbit TX  = P3^3;
  6. //°´¼üÉùÃ÷
  7. sbit S1  = P1^4;
  8. sbit S2  = P1^5;
  9. sbit S3  = P1^6;
  10. //·äÃùÆ÷
  11. sbit Feng= P2^0;
  12. sbit W1=P1^0;
  13. sbit W2=P1^1;
  14. sbit W3=P1^2;
  15. sbit W4=P1^3;
  16. //±äÁ¿ÉùÃ÷
  17. unsigned int  time=0;
  18. unsigned int  timer=0;
  19. unsigned char posit=0;
  20. unsigned long S=0;
  21. unsigned long BJS=50;//±¨¾¯¾àÀë80CM
  22. //ģʽ 0Õý³£Ä£Ê½ 1µ÷Õû
  23. char Mode=0;
  24. bit  flag=0;
  25. bit flag_KEY=0;
  26. unsigned char const discode[] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0xff/*-*/}; //ÊýÂë¹ÜÏÔʾÂë0123456789-ºÍ²»ÏÔʾ
  27. //unsigned char const positon[4]={0xfd,0xfb,0xf7,0xfe}; //λѡ
  28. unsigned char disbuff[4]    ={0,0,0,0};   //Êý×éÓÃÓÚ´æ·Å¾àÀëÐÅÏ¢
  29. unsigned char disbuff_BJ[4] ={0,0,0,0};//±¨¾¯ÐÅÏ¢
  30. void Display();
  31. //ÑÓʱ20ms£¨²»¾«È·£©
  32. void delay(void)
  33. {
  34.     unsigned char a,b,c;
  35.     for(c=2;c>0;c--)
  36.         for(b=38;b>0;b--)
  37.             for(a=60;a>0;a--);
  38. }
  39. //°´¼üɨÃè
  40. void Key_()
  41. {
  42. if(flag_KEY==0)
  43. {
  44.   if(Mode!=0)
  45.   {
  46.    //+
  47.    if(S1==0)
  48.    {
  49.     delay();    //ÑÓʱȥ¶¶
  50.     if(S1==0)
  51.     {
  52.      BJS++;  //±¨¾¯Öµ¼Ó
  53.      flag_KEY=1;
  54.      if(BJS>=151) //×î´ó151
  55.      {
  56.       BJS=0;
  57.      }
  58. //     while(S1==0)
  59. //     Display();
  60.     }
  61.
  62.    }
  63.    //-
  64.    if(S2==0)
  65.    {
  66.     delay();
  67.     if(S2==0)
  68.     {
  69.      BJS--;  //±¨¾¯Öµ¼õ
  70.      flag_KEY=1;
  71.      if(BJS<=1)  //×îС1
  72.      {
  73.       BJS=150;
  74.      }
  75. //     while(S2==0)
  76. //     Display();
  77.     }
  78.
  79.    }
  80.   }
  81.   //¹¦ÄÜ
  82.   if(S3==0)  //ÉèÖüü
  83.   {
  84.    delay();
  85.    if(S3==0)
  86.    {
  87.     Mode++;  //ģʽ¼Ó
  88.     flag_KEY=1;
  89.     if(Mode>=2)  //¼Óµ½2ʱÇåÁã
  90.     {
  91.      Mode=0;
  92.     }
  93. //    while(S3==0)
  94. //    Display();
  95.    }
  96.   }
  97. }
  98. if((P1&0x70)==0x70)
  99. {
  100.   flag_KEY=0;
  101. }
  102. }
  103. /**********************************************************************************************************/
  104. //ɨÃèÊýÂë¹Ü
  105. void Display(void)
  106. {
  107. //Õý³£ÏÔʾ
  108. if(Mode==0)
  109. {
  110.   P0=0x00;  //¹Ø±ÕÏÔʾ
  111.   if(posit==1)//ÊýÂë¹ÜµÄСÊýµã
  112.   {
  113.    P0=(discode[disbuff[posit]])|0x80;//°´Î»»ò£¬×î¸ßλ±äΪ1£¬ÏÔʾСÊýµã
  114.   }
  115.   else if(posit==0)
  116.   {
  117.    P0=~discode[11];
  118.   }
  119.   else
  120.   {
  121.    P0=discode[disbuff[posit]];
  122.   }
  123.   switch(posit)
  124.   {
  125.    case 0 : W1=0;W2=1;W3=1;W4=1; break;
  126.    case 1 : W1=1;W2=0;W3=1;W4=1; break;
  127.    case 2 : W1=1;W2=1;W3=0;W4=1; break;
  128.    case 3 : W1=1;W2=1;W3=1;W4=0; break;
  129.   }
  130.   posit++;
  131.   if(posit>3)  //ÿ½øÒ»´ÎÏÔʾº¯Êý£¬±äÁ¿¼Ó1
  132.    posit=0;  //¼Óµ½3ʱÇåÁã
  133. }
  134. //±¨¾¯ÏÔʾ
  135. else
  136. {
  137.   P0=0x00;
  138.   if(posit==1)//ÊýÂë¹ÜµÄСÊýµã
  139.   {
  140.    P0=(discode[disbuff_BJ[posit]])|0x80;
  141.   }
  142.   else if(posit==0)
  143.   {
  144.    P0=0x76; //ÏÔʾ×Öĸ
  145.   }
  146.   else
  147.   {
  148.    P0=discode[disbuff_BJ[posit]];
  149.   }
  150.   switch(posit)
  151.   {
  152.    case 0 : W1=0;W2=1;W3=1;W4=1; break;
  153.    case 1 : W1=1;W2=0;W3=1;W4=1; break;
  154.    case 2 : W1=1;W2=1;W3=0;W4=1; break;
  155.    case 3 : W1=1;W2=1;W3=1;W4=0; break;
  156.   }
  157.   posit++;
  158.   if(posit>3)
  159.    posit=0;
  160. }
  161. }
  162. /**********************************************************************************************************/
  163. //¼ÆËã
  164. void Conut(void)
  165. {
  166. time=TH0*256+TL0;   //¶Á³öT0µÄ¼ÆÊ±ÊýÖµ
  167. TH0=0;
  168. TL0=0;      //Çå¿Õ¼ÆÊ±Æ÷
  169. S=(time*1.7)/100;     //Ëã³öÀ´ÊÇCM
  170. //ÉùÒôµÄËÙ¶ÈÊÇ340m/s£¬Ê±¼äµÄµ¥Î»ÊÇus£¬¼ÆËãµ½ÃëÐèÒª½«Ê±¼äÊý¾Ý/1000000£¬
  171. //³¤¶È=ËÙ¶È*ʱ¼ä£¬340*time/1000000£¬³¤¶ÈÊý¾Ýµ¥Î»ÊÇmת»»³ÉcmÐèÒª³ËÒÔ100µÃµ½340*time/10000£¬
  172. //СÊýµã¶¼Ïò×óÒÆÁ½Î»µÃµ½3.4*time/100£¬ÒòΪ³¬Éù²¨ÊÇÍù·µÁË£¬ËùÒÔÔÙ³ýÒÔ2,µÃµ½¾àÀëÊý¾Ý(time*1.7)/100
  173. if(Mode==0)     //·ÇÉèÖÃ״̬ʱ
  174. {
  175.   if((S>=700)||flag==1) //³¬³ö²âÁ¿·¶Î§ÏÔʾ¡°-¡±
  176.   {
  177.    Feng=0;      //·äÃùÆ÷±¨¾¯
  178.    flag=0;
  179.    disbuff[1]=10;    //¡°-¡±
  180.    disbuff[2]=10;    //¡°-¡±
  181.    disbuff[3]=10;    //¡°-¡±
  182.   }
  183.   else
  184.   {
  185.    //¾àÀëСÓÚ±¨¾¯¾à
  186.    if(S<=BJS)
  187.    {
  188.     Feng=0; //±¨¾¯
  189.    }
  190.    else  //´óÓÚ
  191.    {
  192.     Feng=1;  //¹Ø±Õ±¨¾¯
  193.    }
  194.    disbuff[1]=S%1000/100;   //½«¾àÀëÊý¾Ý²ð³Éµ¥¸öλ¸³Öµ
  195.    disbuff[2]=S%1000%100/10;
  196.    disbuff[3]=S%1000%10 %10;
  197.   }
  198. }
  199. else
  200. {
  201.    Feng=1;
  202.    disbuff_BJ[1]=BJS%1000/100;
  203.    disbuff_BJ[2]=BJS%1000%100/10;
  204.    disbuff_BJ[3]=BJS%1000%10 %10;
  205. }
  206. }
  207. /**********************************************************************************************************/
  208. //¶¨Ê±Æ÷0
  209. void zd0() interrupt 1    //T0ÖжÏÓÃÀ´¼ÆÊýÆ÷Òç³ö,³¬¹ý²â¾à·¶Î§
  210. {
  211. flag=1;       //ÖжÏÒç³ö±êÖ¾
  212. }
  213. /**********************************************************************************************************/
  214. //¶¨Ê±Æ÷1
  215. void zd3() interrupt 3    //T1ÖжÏÓÃÀ´É¨ÃèÊýÂë¹ÜºÍ¼Æ800MSÆô¶¯Ä£¿é
  216. {
  217. TH1=0xf8;
  218. TL1=0x30;     //¶¨Ê±2ms
  219. Key_();     //ɨÃè°´¼ü
  220. Display();    //ɨÃèÏÔʾ
  221. timer++;    //±äÁ¿¼Ó
  222. if(timer>=400)   //400´Î¾ÍÊÇ800ms
  223. {
  224.   timer=0;
  225.   TX=1;             //800MS  Æô¶¯Ò»´ÎÄ£¿é
  226.   _nop_();
  227.   _nop_();
  228.   _nop_();
  229.   _nop_();
  230.   _nop_();
  231.   _nop_();
  232.   _nop_();
  233.   _nop_();
  234.   _nop_();
  235.   _nop_();
  236.   _nop_();
  237.   _nop_();
  238.   _nop_();
  239.   _nop_();
  240.   _nop_();
  241.   _nop_();
  242.   _nop_();
  243.   _nop_();
  244.   _nop_();
  245.   _nop_();
  246.   _nop_();
  247.   TX=0;
  248. }
  249. }
  250. /**********************************************************************************************************/
  251. //Ö÷º¯Êý
  252. void main(void)
  253. {
  254. TMOD=0x11;     //ÉèT0Ϊ·½Ê½1
  255. TH0=0;
  256. TL0=0;
  257. TH1=0xf8;     //2MS¶¨Ê±
  258. TL1=0x30;
  259. ET0=1;    //ÔÊÐíT0ÖжÏ
  260. ET1=1;      //ÔÊÐíT1ÖжÏ
  261. TR1=1;      //¿ªÆô¶¨Ê±Æ÷
  262. EA=1;     //¿ªÆô×ÜÖжÏ
  263. while(1)
  264. {
  265.   while(!RX);  //µ±ÉϴνÓÊÕÍ겨ºó£¬RXÒý½ÅÊÇµÍµçÆ½£¬È¡·´¾ÍÊÇ1£¬´Ëwhile³ÉÁ¢£¬·´¸´ÅжÏRX״̬¡£µ±RXûÓнÓÊÕµ½·µ»Ø²¨Ê±ÊÇ¸ßµçÆ½£¬È¡·´¾ÍÊÇ0£¬´Ëwhile²»³ÉÁ¢£¬Ìø³ö
  266.   TR0=1;   //¿ªÆô¼ÆÊý
  267.   while(RX);  //µ±RXûÓнÓÊÕµ½·µ»Ø²¨£¬´Ëwhile³ÉÁ¢£¬³ÌÐòÍ£ÔÚÕâÀïÒ»Ö±ÅжÏRX״̬¡£µ±RX½ÓÊÕµ½·µ»Ø²¨£¬RXÒý½Å±äΪµÍµçƽ£¬´Ëwhile²»³ÉÁ¢£¬Ìø³ö
  268.   TR0=0;   //Í£Ö¹¼ÆÊý
  269.   Conut();   //¼ÆËã
  270. }
  271. }
原理圖.doc
104 KB, 下載次數: 23, 下載積分: 黑幣 -5
參與人數 2黑幣 +60 收起 理由
564654654 + 10 絕世好帖!
ID:1 發表于 2017-7-31 16:14 | 顯示全部樓層
樓主能分享下源碼壓縮包嗎 ,中文是亂碼
ID:212924 發表于 2017-8-1 08:42 | 顯示全部樓層
admin 發表于 2017-7-31 16:14
樓主能分享下源碼壓縮包嗎 ,中文是亂碼
可以的
ID:212924 發表于 2017-8-1 08:50 | 顯示全部樓層
補上小車的程序,里面略有改動因為之前打算用SS8050三極管驅動電機但是最后發現無法和單片機共地所以沒辦法了只能用了繼電器模塊,有點大材小用,沒辦法比賽時間到了所以就這樣
超聲波測距小車C程序.docx
14.62 KB, 下載次數: 15, 下載積分: 黑幣 -5
C程序
參與人數 1黑幣 +80 收起 理由
admin + 80 共享資料的黑幣獎勵!
ID:229527 發表于 2017-9-12 11:36 | 顯示全部樓層
很給力!正在學習中,希望自己也能成功做出來
ID:229527 發表于 2017-9-14 10:08 | 顯示全部樓層
壓縮包怎么還是亂碼呀
ID:233038 發表于 2017-9-14 10:18 | 顯示全部樓層
感覺好厲害,雖然看不懂程序
ID:231115 發表于 2017-9-25 11:38 | 顯示全部樓層
好像是老外的程序,注釋是外國的
