#include<reg52.h>
#include<stdio.h>
#include<intrins.h>
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P1^2;
sbit Busy = P0^7;
void delay(uint z)
while(z--);
void BusyJiance(void) //忙檢測(cè)
P0 = 0xFF;
RS = 0;
RW = 1;
EN = 1;
while(Busy);
EN = 0;
void WriteLCD1602Command(uchar com)
BusyJiance();
P0 = com;
RS = 0;
RW = 0;
EN = 1;
delay(2);
EN = 0;
void WriteLCD1602Dat(uchar dat)
BusyJiance();
P0 = dat;
RS = 1;
RW = 0;
EN = 1;
delay(2);
EN = 0;
void LCD1602_Init(void)
WriteLCD1602Command(0x38);
WriteLCD1602Command(0x0c);
WriteLCD1602Command(0x06);
WriteLCD1602Command(0x01);
//WriteLCD1602Command(0x08);
/*******顯示單個(gè)字符函數(shù)***********/
void LCD_Write_Char(uchar x,uchar y,uchar a)
if (y == 0)
WriteLCD1602Command(0x80 + x);
WriteLCD1602Command(0xC0 + x);
WriteLCD1602Dat(a);
/*******顯示字符串函數(shù)************/
void DisplayLCD1602(uchar x, uchar y, uchar *p)
if(x == 0)
WriteLCD1602Command(0x80 + y);
WriteLCD1602Command(0xc0 + y);
while(*p)
WriteLCD1602Dat(*p);
p++;
/*按鍵掃描函數(shù),返回掃描鍵值*/
uchar KeyScan() //鍵盤掃描函數(shù),使用行列反轉(zhuǎn)掃描法
uchar num1;
static uchar key_on =0;
P2=0x0f;
if(P2!=0x0f)
if(key_on==0)
key_on=1;
num1=P2;
num1 |= 0xf0;
P2=num1;
num1=P2;
return(num1);
key_on=0;
return(0xff);
uchar KeyPro()
switch(KeyScan())
// case 0x7e:return '+';break;//0 按下相應(yīng)的鍵顯示相對(duì)應(yīng)的碼值
// case 0x7d:return '-';break;//1
// case 0x7b:return '*';break;//2
// case 0x77:return '/';break;//3
// case 0xbe:return '3';break;//4
// case 0xbd:return '6';break;//5
// case 0xbb:return '9';break;//6
// case 0xb7:return '=';break;//7
// case 0xde:return '2';break;//8
// case 0xdd:return '5';break;//9
// case 0xdb:return '8';break;//a
// case 0xd7:return '0';break;//b
// case 0xee:return '1';break;//c
// case 0xed:return '4';break;//d
// case 0xeb:return '7';break;//e
// case 0xe7:return '.';break;//f
// default:return 0xff;break;
case 0xe7:return '.';break;//0 按下相應(yīng)的鍵顯示相對(duì)應(yīng)的碼值
case 0xeb:return '0';break;//1
case 0xed:return '=';break;//2 .0=/
case 0xee:return '/';break;//3
case 0xd7:return '7';break;//4
case 0xdb:return '8';break;//5 789*
case 0xdd:return '9';break;//6
case 0xde:return '*';break;//7
case 0xb7:return '4';break;//8
case 0xbb:return '5';break;//9 456-
case 0xbd:return '6';break;//a
case 0xbe:return '-';break;//b
case 0x77:return '1';break;//c
case 0x7b:return '2';break;//d 123+
case 0x7d:return '3';break;//e
case 0x7e:return '+';break;//f
unsigned char num,i,sign;
unsigned char temp[16]; //最大輸入16個(gè) -
bit firstflag; //標(biāo)志位
float a=0,b=0;
unsigned char s;
LCD1602_Init(); //初始化液晶屏
WriteLCD1602Command(0x01); //清屏
while (1) //主循環(huán)
num=KeyPro(); //掃描鍵盤
if(num != 0xff) //如果掃描是按鍵有效值則進(jìn)行處理
if(i==0) //輸入是第一個(gè)字符的時(shí)候需要清空,方便觀看
if((num=='+')||(num=='-') || (num=='*')|| (num=='/') || (num=='='))//輸入符號(hào)表示輸入結(jié)束
i=0; //計(jì)數(shù)器復(fù)位
if(firstflag==0) //如果是輸入的第一個(gè)數(shù)據(jù),賦值給a,并把標(biāo)志位 置1,到下一個(gè)數(shù)據(jù)輸入時(shí)可以跳轉(zhuǎn)賦值給b
sscanf(temp,"%f",&a);
firstflag=1;
else //把第二個(gè)數(shù)據(jù)賦給 b
sscanf(temp,"%f",&b);
for(s=0;s<16;s++) //賦值完成后把緩沖區(qū)清零,防止下次輸入影響結(jié)果
temp[s]=0;
LCD_Write_Char(0,1,num);
if(num != '=') //判斷當(dāng)前符號(hào)位并做相應(yīng)處理
sign=num; //如果不是等號(hào)記下標(biāo)志位
firstflag=0; //檢測(cè)到輸入=號(hào),判斷上次讀入的符合
switch(sign)
case '+':a=a+b;break;
case '-':a=a-b;break;
case '*':a=a*b;break;
case '/':a=a/b;break;
default:break;
sprintf(temp,"%g",a); //輸出浮點(diǎn)型,無用的0不輸出
DisplayLCD1602(1,1,temp);//顯示到液晶屏
sign=0;a=b=0; //用完后所有數(shù)據(jù)清零
temp[s]=0;
else //輸入的是數(shù)字并處理
if(i<=16)
if( (1==i) && (temp[0]=='0') )//如果第一個(gè)字符是0,判讀第二個(gè)字符(i不自加一)
if(num=='.') //如果是小數(shù)點(diǎn)則正常輸入,光標(biāo)位置加1
temp[1]='.';
LCD_Write_Char(1,0,num);//輸出數(shù)據(jù)
i++;
} //這里沒有判斷連續(xù)按小數(shù)點(diǎn),如0.0.0
temp[0]=num; //如果是1-9數(shù)字,說明0沒有用,則直接替換第一位0
LCD_Write_Char(0,0,num);//輸出
temp[i]=num;
LCD_Write_Char(i,0,num);//輸出數(shù)據(jù)(顯示)
i++; //光標(biāo)位置加1
if(i==16)
i=0; //防止當(dāng)按下17下的時(shí)候等待
評(píng)分
查看全部評(píng)分
