查看: 11324|回復: 5
51單片機電子日歷(可調整 帶溫度)DS1302時鐘+12864LCD顯示
ID:220429 發表于 2017-7-27 15:30 | 顯示全部樓層 |閱讀模式
可按照程序接線
51單片機顯示時間(可調整)(DS1302時鐘+12864LCD顯示)
仿真原理圖如下:
仿真
仿真
  1. /****************************************/
  2. /*        帶溫度顯示的電子日歷                */
  3. /****************************************/
  4. #include<reg51.h>
  5. #include<intrins.h>
  6. #include<string.h>
  7. #define uchar unsigned char
  8. #define uint unsigned int
  9. sbit DQ=P2^7;
  10. sbit CS1=P2^1;    //定義選擇芯片左半屏信號
  11. sbit CS2=P2^2;    //定義選擇芯片右半屏信號
  12. sbit DI=P2^5;     //定義選擇顯示類型
  13. sbit RW=P2^4;     //定義讀寫信號
  14. sbit E=P2^3;      //定義數據鎖存信號
  15. sbit IO=P1^0;          //DS1302數據線
  16. sbit CLK=P1^1;          //DS1302時鐘線
  17. sbit RST=P1^2;          //DS1302復位線
  18. sbit s1=P3^0;
  19. sbit s2=P3^1;
  20. sbit s3=P3^2;
  21. uchar Time_Buffer[7]; //日期緩存,0-6依次為秒、分、時、日、月、周日、年
  22. uint Temp,Temp1;
  23. bit Temp_Flag;
  24. uchar s1num;
  25. uchar flag_year=0,flag_moon=0,flag_day=0,flag_hour=0,flag_min=0,flag_sec=0,flag_week=0;
  26. uchar tempa;
  27. uchar t0_num;
  28. void delayms(uint xms);
  29. void Write_1302(uchar addr,uchar dat);
  30. void keyscan();
  31. void time_adj();
  32. /*--年,月,日,星期,時,分,秒,漢字點陣(16*16)--*/
  33. uchar code Date_Time_Words[]=
  34. {
  35. 0x40,0x20,0x10,0x0C,0xE3,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0x02,0x00,0x00,//年
  36. 0x04,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
  37. 0x00,0x00,0x00,0x00,0x00,0xFF,0x11,0x11,0x11,0x11,0x11,0xFF,0x00,0x00,0x00,0x00,//月
  38. 0x00,0x40,0x20,0x10,0x0C,0x03,0x01,0x01,0x01,0x21,0x41,0x3F,0x00,0x00,0x00,0x00,
  39. 0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00,0x00,//日
  40. 0x00,0x00,0x00,0x3F,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x00,
  41. 0x00,0x00,0x00,0xBE,0x2A,0x2A,0x2A,0xEA,0x2A,0x2A,0x2A,0x2A,0x3E,0x00,0x00,0x00,//星
  42. 0x00,0x48,0x46,0x41,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x49,0x41,0x40,0x00,
  43. 0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,//期
  44. 0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00,
  45. 0x00,0xFC,0x44,0x44,0x44,0xFC,0x10,0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,//時
  46. 0x00,0x07,0x04,0x04,0x04,0x07,0x00,0x00,0x03,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,
  47. 0x80,0x40,0x20,0x98,0x87,0x82,0x80,0x80,0x83,0x84,0x98,0x30,0x60,0xC0,0x40,0x00,//分
  48. 0x00,0x80,0x40,0x20,0x10,0x0F,0x00,0x00,0x20,0x40,0x3F,0x00,0x00,0x00,0x00,0x00,
  49. 0x12,0x12,0xD2,0xFE,0x91,0x11,0xC0,0x38,0x10,0x00,0xFF,0x00,0x08,0x10,0x60,0x00,//秒
  50. 0x04,0x03,0x00,0xFF,0x00,0x83,0x80,0x40,0x40,0x20,0x23,0x10,0x08,0x04,0x03,0x00
  51. } ;
  52. //星期幾的漢字點陣
  53. uchar code Weekday_Words[]=
  54. {
  55. 0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00,0x00,//日
  56. 0x00,0x00,0x00,0x3F,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x00,
  57. 0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0x80,0x00,//一
  58. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  59. 0x00,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,//二
  60. 0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x18,0x10,0x00,
  61. 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,//三
  62. 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  63. 0x00,0xFE,0x02,0x02,0x02,0xFE,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,//四
  64. 0x00,0x7F,0x28,0x24,0x23,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x22,0x7F,0x00,0x00,
  65. 0x00,0x02,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0xC2,0x82,0x02,0x00,0x00,0x00,//五
  66. 0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x30,0x20,0x00,
  67. 0x10,0x10,0x10,0x10,0x10,0x91,0x12,0x1E,0x94,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//六
  68. 0x00,0x40,0x20,0x10,0x0C,0x03,0x01,0x00,0x00,0x01,0x02,0x0C,0x78,0x30,0x00,0x00
  69. };
  70. //溫度顯示漢字點陣
  71. uchar code Templt[]=
  72. {
  73. 0x10,0x22,0x64,0x0C,0x80,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFF,0x02,0x00,0x00,//溫
  74. 0x04,0x04,0xFE,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00,
  75. 0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0xA5,0xA6,0xA4,0xFC,0x24,0x34,0x26,0x04,0x00,//度
  76. 0x40,0x20,0x9F,0x80,0x42,0x42,0x26,0x2A,0x12,0x2A,0x26,0x42,0x40,0xC0,0x40,0x00,
  77. 0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//:
  78. 0x00,0x00,0x00,0x00,0x31,0x7B,0x7B,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79. 0x00,0x02,0x05,0xE2,0x18,0x04,0x02,0x02,0x02,0x02,0x02,0x02,0x04,0x1E,0x00,0x00,//℃
  80. 0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x40,0x40,0x40,0x40,0x40,0x20,0x18,0x00,0x00
  81. };
  82. //半角數字點陣
  83. uchar code Digits[]=
  84. {
  85. 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0
  86. 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1
  87. 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2
  88. 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3
  89. 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4
  90. 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5
  91. 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6
  92. 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7
  93. 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8
  94. 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9
  95. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//.
  96. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00        //' '
  97. };
  98. /*--屏幕顯示--*/
  99. void left()//左半屏顯示
  100. {
  101. CS1=1;
  102. CS2=0;
  103. }
  104. void right()//右半屏顯示
  105. {
  106. CS1=0;
  107. CS2=1;
  108. }
  109. /*--判斷LCD是否繁忙--*/
  110. void LCD_Check_Busy()
  111. {
  112. do
  113. {
  114. E=0;
  115. DI=0;
  116. RW=1;
  117. P0=0xff;
  118. E=1;
  119. _nop_();
  120. E=0;
  121. }
  122. while(P0&0x80);//P0.7口
  123. }
  124. /*--向LCD發送命令--*/
  125. void LCD_Write_Command(uchar c)
  126. {
  127.         LCD_Check_Busy();
  128.         P0=0xFF ;
  129. RW=0;
  130. DI=0;
  131.         P0=c ;
  132.          E=1;
  133. E=0;
  134. }
  135. /*--向LCD發送數據--*/
  136. void LCD_Write_Date(uchar d)
  137. {
  138.         LCD_Check_Busy();
  139.         P0=0xFF ;
  140. RW=0;
  141. DI=1;
  142. E=1;
  143. _nop_();
  144.         P0=d ;
  145.          E=0;
  146. _nop_();
  147. }
  148. /*--設置初始頁--*/
  149. void page_first(uchar p)
  150. {
  151. uchar i=p;
  152. p=i|0xb8;
  153. LCD_Check_Busy();
  154.          LCD_Write_Command(p);
  155. }
  156. /*--設置初始列--*/
  157. void col_first(uchar c)
  158. {
  159.         uchar i=c;
  160.         c=i|0x40;
  161.         LCD_Check_Busy();
  162.         LCD_Write_Command(c);
  163. }
  164. /*--任意位置顯示漢字--*/
  165. void Display_Word(uchar page,uchar col,uchar*s)
  166. {
  167.         uchar i,j;
  168.         page_first(page);//上半部
  169.         col_first(col);
  170.          for(i=0;i<16;i++)
  171.         {
  172.                 LCD_Write_Date(*s);
  173. s++;
  174.         }
  175.         page_first(page+1);//下半部
  176.         col_first(col);
  177.         for(j=0;j<16;j++)
  178.         {
  179.                 LCD_Write_Date(*s);
  180.                 s++;
  181.         }
  182. }
  183. /*--任意位置顯示字符--*/
  184. void Display_Char(uchar page,uchar col,uchar*s)
  185. {
  186.         uchar i,j;
  187.         page_first(page);//上半部
  188.         col_first(col);
  189.          for(i=0;i<8;i++)
  190.         {
  191.                 LCD_Write_Date(*s);
  192. s++;
  193.         }
  194.         page_first(page+1);//下半部
  195.         col_first(col);
  196.         for(j=0;j<8;j++)
  197.         {
  198.                 LCD_Write_Date(*s);
  199.                 s++;
  200.         }
  201. }
  202. /*--初始化LCD --*/
  203. void LCD_initialize()
  204. {
  205.         CS1=1;
  206.     CS2=1;
  207.         LCD_Write_Command(0x38); //8位形式,2行字符
  208.         LCD_Write_Command(0x0F); //開顯示
  209.         LCD_Write_Command(0x01); //清屏
  210.         LCD_Write_Command(0x06); //畫面不動光標右移
  211.         LCD_Write_Command(0xC0);//設置起始行
  212. }
  213. /*--向DS1302寫入一字節--*/
  214. void Write_A_Byte_To_1302(uchar x)
  215. {
  216.          uchar i;
  217.         for(i=0;i<8;i++)
  218.         {
  219.                  IO=x&0x01; CLK=1;CLK=0;x>>=1;
  220.         }
  221. }
  222. /*--從DS1302讀取一字節--*/
  223. uchar Receive_A_Byte_From_1302()
  224. {
  225.          uchar i,b=0x00;
  226.         for(i=0;i<8;i++)
  227.         {
  228.                  b |= _crol_((uchar)IO,i);
  229.                 CLK=1;CLK=0;
  230.         }
  231.         return b/16*10+b%16;
  232. }
  233. /*--從DS1302指定位置讀數據--*/
  234. uchar Read_1302(uchar addr)
  235. {
  236.          uchar dat;
  237.         RST = 0;CLK=0;RST=1;
  238.            Write_A_Byte_To_1302(addr);
  239.         dat = Receive_A_Byte_From_1302();
  240.            CLK=1;RST=0;
  241.         return dat;
  242. }
  243. /*--向DS1302某地址寫入數據--*/
  244. void Write_1302(uchar addr,uchar dat)
  245. {
  246.          CLK=0; RST=0;
  247.          Write_A_Byte_To_1302(addr);
  248.          Write_A_Byte_To_1302(dat);
  249.          CLK=0;RST=0;
  250. }
  251. /*--讀取當前日期時間--*/
  252. void Get_Time()
  253. {
  254.         uchar i;
  255.         for(i=0;i<7;i++)
  256.         {
  257.                 Time_Buffer[i]=Read_1302(0x81+2*i);
  258.         }
  259. }
  260. /*--定時器0每秒刷新LCD顯示--*/
  261. void T0_INT() interrupt 1
  262. {
  263.         TH0=(65536-50000)/256;
  264.            TL0=(65536-50000)%256;
  265.         t0_num++;
  266.     left();//顯示左半屏
  267.         if(flag_year==0)
  268.          {
  269.           Display_Char(0,16,Digits+ Time_Buffer [6]/10*16);//顯示年的十位數,占8列
  270.           Display_Char(0,24,Digits+ Time_Buffer [6]%10*16); //顯示年的個位數,占8列
  271.          }
  272.         else
  273.          {
  274.           if(t0_num<=5)
  275.            {
  276.                 Display_Char(0,16,Digits+ Time_Buffer [6]/10*16);//顯示年的十位數,占8列
  277.             Display_Char(0,24,Digits+ Time_Buffer [6]%10*16); //顯示年的個位數,占8列
  278.            }
  279.           if(t0_num>5&&t0_num<=10)
  280.            {
  281.                 if(t0_num==10)t0_num=0;
  282.                 Display_Char(0,16,Digits+ Digits[11]/10*16);//顯示年的十位數,占8列
  283.             Display_Char(0,24,Digits+ Digits[11]%10*16); //顯示年的個位數,占8列
  284.            }
  285.          }
  286.         Display_Char(0,48,Digits+ Time_Buffer [4]/10*16); //顯示月的十位數,占8列
  287.         Display_Char(0,56,Digits+ Time_Buffer [4]%10*16); //顯示月的個位數,占8列
  288.         right();//顯示右半屏
  289.         Display_Char(0,80,Digits+ Time_Buffer [3]/10*16); //顯示日的十位數,占8列
  290.         Display_Char(0,88,Digits+ Time_Buffer [3]%10*16); //顯示日的個位數,占8列
  291.         left();//顯示左半屏
  292.         Display_Char(2,16,Digits+ Time_Buffer [2]/10*16); //顯示時的十位數,占8列
  293.         Display_Char(2,24,Digits+ Time_Buffer [2]%10*16); //顯示時的個位數,占8列
  294.         left();//顯示左半屏
  295.         Display_Char(2,48,Digits+ Time_Buffer [1]/10*16); //顯示分的十位數,占8列
  296.         Display_Char(2,56,Digits+ Time_Buffer [1]%10*16); //顯示分的個位數,占8列
  297.         right();//顯示右半屏,秒顯示在右半屏部分
  298.         Display_Char(2,80,Digits+ Time_Buffer [0]/10*16); //顯示秒的十位數,占8列
  299.         Display_Char(2,88,Digits+ Time_Buffer [0]%10*16); //顯示秒的個位數,占8列
  300.         right();//顯示右半屏
  301.         Display_Word(4,64,Weekday_Words+( Time_Buffer [5]-1)*32);//顯示周日,占16列
  302.         left();//顯示左半屏,溫度
  303.         Display_Char(6,48,Digits+ Temp1/100*16); //顯示溫度十位數,占8列
  304.         Display_Char(6,56,Digits+ Temp1%100/10*16); //顯示溫度個位數,占8列
  305.     right();//顯示右半屏
  306.         Display_Char(6,64,Digits+ 10*16); //顯示溫度小數點,占8列
  307.         Display_Char(6,72,Digits+ Temp%10*16); //顯示溫度十分位數,占8列
  308. }
  309. /*--定時器0初始化程序--*/
  310. void Time0_initialize()
  311. {
  312.         EA=1;//開總中斷
  313.         ET0=1;//開定時/計數器0中斷
  314.         TMOD=0x01;//設置工作方式1
  315.         TH0=(65536-50000)/256;//放入計數初值
  316.         TL0=(65536-50000)%256;//放入計數初值
  317.         TR0=1;//開定時/計數器0
  318. }
  319. /*--顯示固定漢字:年月日 ,星期,時分秒*/
  320. void Display()
  321. {
  322.         left();//左半屏顯示
  323.         Display_Char(0,0,Digits+2*16);//顯示2
  324.         Display_Char(0,8,Digits);//顯示0
  325.         /*--顯示固定漢字:年月日 ,星期,時分秒*/
  326.         Display_Word(0,32,Date_Time_Words+0*32);        //"年"字的顯示
  327.         right();//右半屏顯示
  328.         Display_Word(0,64,Date_Time_Words+1*32);        //"月"字的顯示
  329.         Display_Word(0,96,Date_Time_Words+2*32);        //"日"字的顯示
  330.     left();//左半屏顯示
  331.     Display_Word(2,32,Date_Time_Words+5*32);    //"時"字的顯示
  332.         right();//右半屏顯示
  333.         Display_Word(2,64,Date_Time_Words+6*32);    //"分"字的顯示
  334.         Display_Word(2,96,Date_Time_Words+7*32);    //"秒"字的顯示,秒顯示在右半屏
  335.         left();//左半屏顯示
  336.         Display_Word(4,32,Date_Time_Words+3*32);     //"星"字的顯示
  337.         Display_Word(4,48,Date_Time_Words+4*32);    //"期"字的顯示
  338.         left();//左半屏顯示
  339.     Display_Word(6,0,Templt+0*32);    //"溫"字的顯示
  340.         Display_Word(6,16,Templt+1*32);    //"度"字的顯示
  341.         Display_Word(6,32,Templt+2*32);    //":"字的顯示
  342.         right();//右半屏顯示
  343.         Display_Word(6,80,Templt+3*32);     //"℃"字的顯示
  344. }
  345. void delayms(uint xms)
  346. {
  347.   uint y;
  348.   while(xms--)for(y=110;y>0;y--);
  349. }
  350. //us級延時函數
  351. void Delayus(uchar xus)//晶振為12MHz,延時時間為2i+5 us
  352. {
  353.         while(--xus);
  354. }
  355. //初始化DS18B20函數
  356. bit Init_DS18B20(void)
  357. {
  358.         bit x;
  359.         DQ=1;
  360.         DQ=0;
  361.         Delayus(250);
  362.         DQ=1;
  363.         Delayus(20);
  364.         if(!DQ) x=0;
  365.         else x=1;
  366.         Delayus(250);
  367.         DQ=1;
  368.         return x;
  369. }
  370. //讀DS18B20函數
  371. uchar Read_DS18B20(void)
  372. {
  373.         uchar i=0,Dat=0;
  374.         for(i=0;i<8;i++)
  375.         {
  376.                 DQ=1;
  377.                 DQ=0;
  378.                 Dat>>=1;
  379.                 DQ=1;
  380.                 if(DQ) Dat |= 0x80;
  381.                 DQ=1;
  382.                 Delayus(30);
  383.         }
  384.         return Dat;
  385. }
  386. //寫DS18B20函數
  387. void Write_DS18B20(uchar Dat)
  388. {
  389.         uchar i=0;
  390.         for(i=0;i<8;i++)//循環8次,寫入一個字節
  391.         {
  392.                 DQ=1;//未發送前的狀態
  393.                 Dat >>= 1;//將要傳送的最低位放入CY
  394.                 DQ=0;//將總線拉低,產生寫時序
  395.                 DQ=CY;//將要傳送的位狀態送到總線上
  396.                 Delayus(30);//延時50us,即保持總線狀態,待DS18B20采樣
  397.                 DQ=1;//恢復期,總線置1
  398.         }
  399. }
  400. //取溫度函數
  401. void GetTemp(void)//獲取溫度函數
  402. {
  403.         uchar a=0,b=0;
  404.         TR0=0;//關閉定時器,防止定時器中斷干擾DS18B20
  405.
  406. ……………………
  407. …………限于本文篇幅 余下代碼請從51黑下載附件…………
51單片機顯示時間(可調整)(DS1302時鐘 12864LCD顯示).docx (61.09 KB, 下載次數: 202)
ID:189697 發表于 2017-8-3 18:53 | 顯示全部樓層
好巧啊  我也有一個這樣的程序
ID:609509 發表于 2019-9-9 15:37 | 顯示全部樓層
不錯啊 很有條理
ID:781187 發表于 2020-6-17 10:37 | 顯示全部樓層
在仿真圖上12864不顯示怎么回事
ID:812792 發表于 2020-8-10 11:00 | 顯示全部樓層
請問您的程序包括鍵入的程序么
ID:780721 發表于 2020-12-2 18:28 | 顯示全部樓層
程序有問題
