查看: 2638|回復(fù): 1
1602液晶顯示adda轉(zhuǎn)換值
ID:221864 發(fā)表于 2017-7-23 21:19 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define MAIN_Fosc        11059200UL    //ºê¶¨ÒåÖ÷ʱÖÓHZ
#define PCF8591_ADDR    0x90        //PCF8591µØÖ·
#define DACOUT_EN        0x40        //DACÊä³öʹÄÜ
×Ô¶¨ÒåÀàÐÍÃû
typedef unsigned char INT8U;
typedef unsigned char uchar;
typedef unsigned int INT16U;
typedef unsigned int uint;
sbit SDA = P2^0;   //I2C´®ÐÐÊý¾Ý
sbit SCL = P2^1;   //I2C´®ÐÐʱÖÓ
sbit DU  = P2^6;   //ÊýÂë¹Ü¶ÎÑ¡
sbit WE  = P2^7;   //ÊýÂë¹Üλѡ
sbit LED1= P1^0;   //¶ÁÈ¡ADµÄÖµÊÇ·ñ³É¹¦£¨ÁÁ³É¹¦£¬Ãðʧ°Ü£©
sbit LED2= P1^1;   //DAC³É¹¦Êä³ö£¨ÁÁ³É¹¦£¬Ãðʧ°Ü£©
uchar AD_Value;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
void delay(uint x)//ÑÓʱº¯Êý
    uint a,b;
    for(a=x;a>0;a--)
        for(b=10;b>0;b--);
void write_com(uchar com)
    P0=com;
    rs=0;
    lcden=0;
    delay(10);
    lcden=1;
    delay(10);
    lcden=0;
void write_date(uchar date)
    P0=date;
    rs=1;
    lcden=0;
    delay(10);
    lcden=1;
    delay(10);
    lcden=0;
void init()
    dula=0;
    wela=0;
    write_com(0x38);
    delay(20);
    write_com(0x0c);
    delay(20);
    write_com(0x06);
    delay(20);
    write_com(0x01);
    delay(20);
º¯Êý£ºvoid Delay_Ms(INT16U ms)
²ÎÊý£ºms£¬ºÁÃëÑÓʱÐβÎ
ÃèÊö£º12T 51µ¥Æ¬»ú×ÔÊÊÓ¦Ö÷ʱÖÓºÁÃë¼¶ÑÓʱº¯Êý
     INT16U i;
     do{
          i = MAIN_Fosc / 96000;
          while(--i);   //96T per loop
     }while(--ms);
º¯Êý£ºvoid Delay5us()
ÃèÊö£º12T 51µ¥Æ¬»ú5΢ÃëÑÓʱº¯Êý×ÔÊÊӦʱÖÓ£¨11.0592M£¬12M,22.1184M£©
void Delay5us()
    #if MAIN_Fosc == 11059200
        _nop_();
    #elif MAIN_Fosc == 12000000
        _nop_()
    #elif MAIN_Fosc == 22118400
        _nop_(); _nop_(); _nop_();
    #endif
º¯Êý£ºI2C_init()
ÃèÊö£ºI2C×ÜÏß³õʼ»¯
void I2C_init()
    SDA = 1;   //Êý¾Ý×ÜÏ߸ß
    _nop_();
    SCL = 1;   //ʱÖÓ×ÜÏ߸ß
    _nop_();
º¯Êý£ºI2C_Start()
ÃèÊö£ºI2CÆðʼÐźÅ
void I2C_Start()
    SCL = 1;
    _nop_();
    SDA = 1;
    Delay5us();
    SDA = 0;
    Delay5us();
º¯Êý£ºI2C_Stop()
ÃèÊö£ºI2CÍ£Ö¹ÐźÅ
void I2C_Stop()
    SDA = 0;
    _nop_();
    SCL = 1;
    Delay5us();
    SDA = 1;
    Delay5us();
º¯Êý£ºMaster_ACK(bit i)
²ÎÊý£ºi Ϊ0ʱ·¢ËÍ·ÇÓ¦´ð Ϊ1ʱ·¢ËÍÓ¦´ð
ÃèÊö£ºI2CÖ÷»ú·¢ËÍÓ¦´ð
void Master_ACK(bit i)
    SCL = 0; // À­µÍʱÖÓ×ÜÏßÔÊÐíSDAÊý¾Ý×ÜÏßÉϵÄÊý¾Ý±ä»¯
    _nop_(); // ÈÃ×ÜÏßÎȶ¨
    if (i)     //Èç¹ûi = 1 ÄÇôÀ­µÍÊý¾Ý×ÜÏß ±íʾÖ÷»úÓ¦´ð
        SDA = 0;
        SDA = 1;     //·¢ËÍ·ÇÓ¦´ð
    _nop_();//ÈÃ×ÜÏßÎȶ¨
    SCL = 1;//À­¸ßʱÖÓ×ÜÏß Èôӻú´ÓSDAÏßÉ϶Á×ß Ö÷»úµÄÓ¦´ðÐźÅ
    _nop_();
    SCL = 0;//À­µÍʱÖÓ×ÜÏߣ¬ Õ¼ÓÃ×ÜÏß¼ÌÐøÍ¨ÐÅ
    _nop_();
    SDA = 1;//ÊÍ·ÅSDAÊý¾Ý×ÜÏß¡£
    _nop_();
º¯Êý£ºTest_ACK()
·µ»Ø£º0Ϊ·ÇÓ¦´ð 1ΪӦ´ð
ÃèÊö£ºI2C¼ì²â´Ó»úÓ¦´ð
bit Test_ACK()     // ¼ì²â´Ó»úÓ¦´ð
    SCL = 1;//ʱÖÓ×ÜÏßΪ¸ßµçƽÆÚ¼ä¿ÉÒÔ¶ÁÈ¡´Ó»úÓ¦´ðÐźÅ
    Delay5us();
    if (SDA)
        SCL = 0;
        I2C_Stop();
        return(0);
        SCL = 0;
        return(1);
º¯Êý£ºI2C_send_byte(uchar byte)
²ÎÊý£ºbyte Òª·¢Ë͵Ä×Ö½Ú
ÃèÊö£ºI2C·¢ËÍÒ»¸ö×Ö½Ú
void I2C_send_byte(uchar byte)
    uchar i;
    for(i = 0 ; i < 8 ; i++)
        SCL = 0;
        _nop_();
        if (byte & 0x80)    //
            SDA = 1;
            _nop_();
            SDA = 0;
            _nop_();
        SCL = 1;
        _nop_();
        byte <<= 1;
    SCL = 0;
    _nop_();
    SDA = 1;
    _nop_();
º¯Êý£ºI2C_read_byte()
·µ»Ø£º¶ÁÈ¡µÄ×Ö½Ú
ÃèÊö£ºI2C¶ÁÒ»¸ö×Ö½Ú
uchar I2C_read_byte()
    uchar i, dat;
    SCL = 0 ;
    _nop_();
    SDA = 1;
    _nop_();
        SCL = 1;
        _nop_();
        dat <<= 1;
        if (SDA)
            dat |= 0x01;
        _nop_();
        SCL = 0;
        _nop_();
    return(dat);
/*DACÊä³ö*/
bit DAC_OUT(uchar DAT)
    I2C_Start();
    I2C_send_byte(PCF8591_ADDR+0);//ADDR=0x90
    if (!Test_ACK())
        return(0);
    I2C_send_byte(DACOUT_EN);    //DAÊä³öʹÄÜ ¿ØÖÆ×Ö½Ú
    if (!Test_ACK())
        return(0);
    I2C_send_byte(DAT);
    if (!Test_ACK())
        return(0);
    I2C_Stop();
    return(1);
/*¶ÁADÊý¾Ý*/
bit ADC_Read(uchar CON)
    I2C_Start();
    if (!Test_ACK())
        return(0);
    I2C_send_byte(CON);
    Master_ACK(0);
    I2C_Start();
    I2C_send_byte(PCF8591_ADDR+1);
    if (!Test_ACK())
        return(0);
    AD_Value = I2C_read_byte();
    Master_ACK(0);
    I2C_Stop();
    return(1);
    I2C_init();
    init();
    write_com(0x80+5);
    delay(20);
        //µ¥¶ËÊäÈ룬¶Á³öͨµÀ2µÄÖµ
        if (ADC_Read(0x00))    LED1 = 0;    else    LED1 = 1;
        if (DAC_OUT(AD_Value))    LED2 = 0;    else    LED2 = 1;
        write_date(AD_Value/100+'0');
        write_date(AD_Value%100/10+'0');
        write_date(AD_Value%10+'0');
        write_com(0x80+5);
        Delay_Ms(100);
參與人數(shù) 1黑幣 +5 收起 理由
vktpas + 5 贊一個(gè)!
ID:276150 發(fā)表于 2018-1-16 15:17 | 只看該作者
請問有仿真電路圖嗎
