查看: 3692|回復: 0
基于430f5529的無線按鍵傳輸
ID:214217 發表于 2017-7-22 09:32 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
前幾天做了一用433M的無線傳輸,用430單片機發送和就收數據。但是很有很多的不足之處。現在想繼續用兩對這樣的模塊來實現雙工通信。
發送程序
#include "msp430.h"
#include "HAL_UCS.h"
#include "system.h"
#define SET_DATA_PORT P6OUT |= BIT5;
#define CLR_DATA_PORT P6OUT &= ~BIT5;
uchar table[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar i=0,j=0,count=0;
void Port2_Init()
  P2DIR &= ~BIT1;
  P2OUT |= BIT1;
  P2REN |= BIT1;//設置上拉
  P2IES |= BIT1;//P2.1設置為下降沿觸發中斷方式
  P2IE |= BIT1;//使能P2.1中斷
  __enable_interrupt();
void Send_Start_Code()//引導碼
  SET_DATA_PORT;
  __delay_cycles(24000);//delay 5ms
  CLR_DATA_PORT;
  __delay_cycles(16000);
void Send_Data_Code(uchar bit)//數據碼
  if(bit)
    SET_DATA_PORT;
    __delay_cycles(12000);//3000us high  2000us low 1
    CLR_DATA_PORT;
    __delay_cycles(8000);
    SET_DATA_PORT;
    CLR_DATA_PORT;
    __delay_cycles(12000);//2000us high 3000us low 0
void Send_One_Byte(uchar data)//發送一個字節的數據
  uchar bi;
  for(i=0;i<8;i++)
    bi=data&0x80;
    data=data<<1;
    if(bi)
      Send_Data_Code(1);
      Send_Data_Code(0);
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  System_Clock_Init();
  //Port2_Init();
  P4DIR |= BIT7;
  P4OUT |= BIT7;
  P6DIR |= BIT5;
  CLR_DATA_PORT;
    Send_Start_Code();
    Send_One_Byte(0x3f);
    Send_One_Byte(0x06);
    Send_One_Byte(0x5b);
    Send_One_Byte(0x4f);
    Send_One_Byte(0x66);
    Send_One_Byte(0x6d);
    Send_One_Byte(0x7d);
    Send_One_Byte(0x07);
    Send_One_Byte(0x7f);
    Send_One_Byte(0x67);
    __delay_cycles(200000);
接收程序
#include "msp430.h"
#include "system.h"
#define DATA_INPUT P2IN&BIT0
uchar table[10];
uchar th,tl,i,j;
uchar Get_Start_Line()
  uchar i=0;
  while(DATA_INPUT&&i<50)//為1時循環,但不能超過8ms
    i++;
    __delay_cycles(400);
  return i;
uchar Get_High_Line()
  uchar i=0;
  while(DATA_INPUT&&i<80)//為1時循環,但不能超過8ms
    i++;
  return i;
uchar Get_Low_Line()
  uchar i=0;
  while(!DATA_INPUT&&i<60)
    i++;
  return i;
int main( void )
  P4DIR |= BIT7;
  P4OUT &= ~BIT7;
  P1DIR |= BIT0;
  P1OUT &= ~BIT0;
  P3DIR = 0xff;
  P3OUT = 0x3f;
    restart:while(!DATA_INPUT) P1OUT &= ~BIT0;
    th=Get_High_Line();
    if(th<55||th>65) goto restart;
    tl=Get_Low_Line();
    if(tl<35||tl>45) goto restart;//<3.5ms||>4.5ms
    P1OUT |= BIT0;
    for(j=0;j<10;j++)
      for(i=0;i<8;i++)
        th=Get_High_Line();
        //if(th<15||th>35) goto restart;
        tl=Get_Low_Line();
        //if(tl<15||tl>35) goto restart;
        table[j]<<=1;
        if(th>22){table[j] |= 0x01;}
    P3OUT = table[0];
    __delay_cycles(2000000);
    P3OUT = table[1];
    P3OUT = table[2];
    P3OUT = table[3];
    P3OUT = table[4];
    P3OUT = table[5];
    P3OUT = table[6];
    P3OUT = table[7];
    P3OUT = table[8];
    P3OUT = table[9];
