查看: 6377|回復(fù): 2
簡易頻率特性測試儀制作 含原理圖與源碼
2013年競賽題,基于嵌入式的
原理圖如下:
單片機(jī)源程序如下:
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "adc.h"
  7. #include "PROCESS.h"
  8. #include "sram.h"
  9. #include "malloc.h"
  10. #include "sdio_sdcard.h"
  11. #include "usmart.h"
  12. #include "LCDView.h"
  13. #include "touch.h"
  14. #include "TOUCHKEY.h"
  15. #include "DDS.h"
  16. #include "w25qxx.h"
  17. #include "ff.h"
  18. #include "exfuns.h"
  19. #include "fontupd.h"
  20. #include "text.h"
  21. int main(void)
  22. {
  23.     u8 key;
  24.         //u8 lcd_id[12];                                //存放LCD ID字符串
  25.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
  26.         delay_init(168);      //初始化延時(shí)函數(shù)
  27.         uart_init(115200);                //初始化串口波特率為115200
  28.
  29.         LED_Init();                                          //初始化LED
  30.          LCD_Init();           //初始化LCD FSMC接口
  31.         W25QXX_Init();                                //初始化W25Q128
  32.         tp_dev.init();                                //初始化觸摸屏
  33.         AD9854_Init();              //初始化DDS
  34.     Adc_Init();                //初始化ADC
  35.
  36.     usmart_dev.init(168);                //初始化USMART
  37.         my_mem_init(SRAMIN);                //初始化內(nèi)部內(nèi)存池
  38.         my_mem_init(SRAMCCM);                //初始化CCM內(nèi)存池
  39.         exfuns_init();                                //為fatfs相關(guān)變量申請內(nèi)存
  40.           f_mount(fs[0],"0:",1);                 //掛載SD卡
  41.          f_mount(fs[1],"1:",1);                 //掛載FLASH.
  42.         while(font_init())                         //檢查字庫
  43.         {
  44.
  45.                 LCD_Clear(WHITE);                           //清屏
  46.                  POINT_COLOR=RED;                        //設(shè)置字體為紅色
  47.                 LCD_ShowString(30,50,200,16,16,"STM32F4");
  48.                 while(SD_Init())                        //檢測SD卡
  49.                 {
  50.                         LCD_ShowString(30,70,200,16,16,"SD Card Failed!");
  51.                         delay_ms(200);
  52.                         LCD_Fill(30,70,200+30,70+16,WHITE);
  53.                         delay_ms(200);
  54.                 }
  55.                 LCD_ShowString(30,70,200,16,16,"SD Card OK");
  56.                 LCD_ShowString(30,90,200,16,16,"Font Updating...");
  57.                 key=update_font(20,110,16,"0:");//更新字庫
  58.                 while(key)//更新失敗
  59.                 {
  60.                         LCD_ShowString(30,110,200,16,16,"Font Update Failed!");
  61.                         delay_ms(200);
  62.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  63.                         delay_ms(200);
  64.                 }
  65.                 LCD_ShowString(30,110,200,16,16,"Font Update Success!   ");
  66.                 delay_ms(1500);
  67.                 LCD_Clear(WHITE);//清屏
  68.         }
  69.
  70.
  71.         POINT_COLOR=BLUE;      //畫筆顏色:藍(lán)色
  72.         //sprintf((char*)lcd_id,"LCD ID:%04X",lcddev.id);//將LCD ID打印到lcd_id數(shù)組。
  73.     //畫背景
  74. begain:
  75.
  76.         on_off=0;
  77.     mod=0;
  78.         again=0;
  79.
  80.         Draw_Back();
  81.
  82.
  83.     LCD_Fill(AREA_FUNCTION_LEFT+3,AREA_FUNCTION_TOP+4+0*78,AREA_FUNCTION_LEFT+24,AREA_FUNCTION_TOP+74+0*78,GREEN);
  84.     AD9854_SetSine(1000000,4095);
  85.           while(1)
  86.         {
  87.         py_show_result();
  88.                 if(on_off)
  89.                 {
  90.                   if(!mod)
  91.                   {
  92.
  93.             data_process0();
  94.                    }
  95.                   else
  96. ……………………
  97. …………限于本文篇幅 余下代碼請從51黑下載附件…………
原理圖截圖.zip (237.84 KB, 下載次數(shù): 68)
工程主要代碼.rar (69.25 KB, 下載次數(shù): 72)
參與人數(shù) 1黑幣 +50 收起 理由
ID:429158 發(fā)表于 2019-8-9 14:38 | 只看該作者
請問一下 大佬LCD用的什么型號
ID:903064 發(fā)表于 2021-4-9 17:49 | 只看該作者
仿真用的ad9854那個(gè)芯片在哪里找啊
