只需一步,快速開(kāi)始
查看: 5335|回復(fù): 2
stc15w4k58s4單片機(jī)芯片12864的時(shí)鐘
12864的時(shí)鐘,采用stc15w4k58s4芯片
單片機(jī)代碼:
  1. #include<stc15.h>
  2. #include<intrins.h>
  3. #include<gpio.h>
  5. #define uint unsigned int
  6. uchar numbuf;
  7. uchar con1s;
  8. //uchar flash;
  9. uchar clkey;
  10. uchar secp,secd,minp,mind,hou,houp,houd;
  11. #include<LCD12864.h>
  12. uchar mip,mid,hop,hod;
  13. uchar dis[]={0x02,0x03,0x05,0x06,0x02,0x06};
  14. uchar alarm1[]={0x02,0x03,0x05,0x08};
  15. uchar temp_num[]={0x00,0x00,0x00,0x00};
  16. #include<scan_1286.h>
  17. #include<alarm_scan.h>
  18. #include<flag.h>
  19. #include<keyscan.h>
  20. #include<alarm.h>
  21. void Timer0Init(void)                //50毫秒@11.0592MHz
  22. {
  23.         AUXR &= 0x7F;                //定時(shí)器時(shí)鐘12T模式
  24.         TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
  25.         TL0 = 0x00;                //設(shè)置定時(shí)初值
  26.         TH0 = 0x4C;                //設(shè)置定時(shí)初值
  27.         TF0 = 0;                //清除TF0標(biāo)志
  28.         TR0 = 1;                //定時(shí)器0開(kāi)始計(jì)時(shí)
  29.         ET0=1;
  30. }
  31. void fuzhi()
  32. {
  33.         secp=(dis[5]);
  34.         secd=(dis[4]);
  35.         minp=(dis[3]);
  36.         mind=(dis[2]);
  37.         houp=(dis[1]);
  38.         houd=(dis[0]);
  39.         mip=(alarm1[3]);
  40.         mid=(alarm1[2]);
  41.         hop=(alarm1[1]);
  42.         hod=(alarm1[0]);
  43.
  44.
  45. }
  46. void main()
  47. {
  48.         gpio();
  49.         Timer0Init();
  50.         fuzhi();
  51.         Init_lcd();
  52.         Clr_Scr();
  53.         EA=1;
  54.         while(1)
  55.         { keyscan();
  56.         alarm();
  57.         scan_1286(2);
  58.           fla();
  59.         }
  60. }
  61. void time0(void) interrupt 1
  62. {
  63.         con1s++;
  64.         if(con1s==20)
  65.         {
  66.                 con1s=0;
  67.                 secp++;//秒計(jì)時(shí)計(jì)數(shù)-個(gè)位
  68.                 if(secp>=10)
  69.                 {
  70.                         secp=0;
  71.                         secd++;        //秒計(jì)時(shí)-十位
  72.                         if(secd>=6)
  73.                         {
  74.                                 secd=0;
  75.                             minp++;//分計(jì)時(shí)-個(gè)位
  76.                                 if(minp>=10)
  77.                                 {
  78.                                         minp=0;
  79.                                         mind++;        //分計(jì)時(shí)十位
  80.                                         if(mind>=6)
  81.                                         {
  82.                                                 mind=0;
  83.                                                 houp++;
  84.                                                 if(houd<2)
  85.                                                 {
  86.                                                         if(houp>=10)
  87.                                                         houp=0;
  88.                                                         houd++;
  89.                                                         if(houd>=3)
  90.                                                         houd=0;
  91.                                                 }
  92.                                                 else if(houd>=2)
  93.                                                 {if(houp>=4)
  94.                                                 {houp=0;houd=0;}}
  95.                                         }
  96.                                 }
  97. ……………………
  98. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
12864.zip (74.7 KB, 下載次數(shù): 47)
ID:220010 發(fā)表于 2017-7-16 10:26 | 只看該作者
  下載下來(lái)試一下
ID:44037 發(fā)表于 2017-7-28 06:17 | 只看該作者
謝謝分享  下載下來(lái) 參考一下
