只需一步,快速開(kāi)始
查看: 5445|回復(fù): 0
用數(shù)碼管實(shí)時(shí)顯示環(huán)境溫度(DS18B20)
ID:218542 發(fā)表于 2017-7-10 16:31 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define MAIN_Fosc                11059200UL        //宏定義主時(shí)鐘HZ
自定義類(lèi)型名
typedef unsigned char INT8U;
typedef unsigned char uchar;
typedef unsigned int INT16U;
typedef unsigned int uint;
硬件接口位聲明
sbit DS  = P2^2;   //DS18B20單總線(xiàn)
sbit DU  = P2^6;   //數(shù)碼管段選
sbit WE  = P2^7;   //數(shù)碼管位選
共陰極數(shù)碼管段選碼
uchar code table[]={
//0                1         2     3     4     5     6     7     8
0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
//9     A     B           C         D           E         F                -         .          關(guān)顯示
0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x40, 0x80, 0x00
數(shù)碼管位選碼
                                  //1        2          3         4位   5        6          7        8
uchar code T_COM[] = {0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f};//數(shù)碼管位碼
函數(shù):void Delay_Ms(INT16U ms)
參數(shù):ms,毫秒延時(shí)形參
描述:12T 51單片機(jī)自適應(yīng)主時(shí)鐘毫秒級(jí)延時(shí)函數(shù)
     INT16U i;
         do{
              i = MAIN_Fosc / 96000;
                  while(--i);   //96T per loop
     }while(--ms);
/*us延時(shí)函數(shù),執(zhí)行一次US--所需6.5us進(jìn)入一次函數(shù)需要11.95us*/
void Delay_us(uchar us)
        while(us--);
函數(shù):void Display(INT16U Value)
參數(shù):Value,顯示值 取值0-65535
描述:共陰極數(shù)碼管顯示函數(shù)可顯示一個(gè)字節(jié)的數(shù)
void Display(INT16U Value)                        //注意由于需要顯示的數(shù)大于一個(gè)字節(jié)所有形參需為int
        DU = 0;                                                        //關(guān)閉段選
        P0 = table[Value/100];                //數(shù)碼管顯示百位
        DU = 1;                                                        //打開(kāi)段選
        WE = 0;                                                //關(guān)閉位選
        P0 = T_COM[0];                                   //第一位數(shù)碼管
        WE = 1;                                                //打開(kāi)位選
        Delay_Ms(3);
        DU = 0;
        P0 = table[Value%100/10]|0x80; //顯示十位
        DU = 1;
        DU = 0;
        WE = 0;
        P0 = T_COM[1];                          //第二位數(shù)碼管
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        DU = 0;
        P0 = table[Value%10];                //顯示個(gè)位
        DU = 1;
        DU = 0;
        WE = 0;
        P0 = T_COM[2];                                //第三位數(shù)碼管
        WE = 1;
        WE = 0;
        Delay_Ms(3);
/*單總線(xiàn)初始化時(shí)序*/
bit ds_init()
        bit i;
        DS = 1;
        _nop_();
        DS = 0;
        Delay_us(75); //拉低總線(xiàn)499.45us 掛接在總線(xiàn)上的18B20將會(huì)全部被復(fù)位
        DS = 1; //釋放總線(xiàn)
        Delay_us(4); //延時(shí)37.95us 等待18B20發(fā)回存在信號(hào)
        i = DS;
        Delay_us(20); //141.95us
        DS = 1;
        _nop_();
        return (i);
/*寫(xiě)一個(gè)字節(jié)*/
void write_byte(uchar dat)
        uchar i;
        for(i=0;i<8;i++)
                DS = 0;
                _nop_();//產(chǎn)生些時(shí)序
                DS = dat & 0x01;
                Delay_us(10);//76.95us
                DS = 1; //釋放總線(xiàn)準(zhǔn)備下一次數(shù)據(jù)寫(xiě)入
                _nop_();
                dat >>= 1;
uchar read_byte()
        uchar i, j, dat;
        for(i=0;i<8;i++)
                DS = 0;
                _nop_();//產(chǎn)生讀時(shí)序
                DS = 1;
                _nop_();//釋放總線(xiàn)
                j = DS;
                DS = 1;
                _nop_();
                dat = (j<<7)|(dat>>1);
        return (dat);
        uint i;
        uchar L, M;
/*        ds_init();//初始化DS18B20
        write_byte(0xcc);//發(fā)送跳躍ROM指令
        write_byte(0x4e);//寫(xiě)暫存器指令
        write_byte(0x7f);
        write_byte(0xf7);
        write_byte(0x1f);//配置工作在9位模式下
        write_byte(0x48);*/
                write_byte(0x44);//發(fā)送溫度轉(zhuǎn)換指令
                write_byte(0xbe);//讀取DS18B20暫存器值
                L = read_byte();
                M = read_byte();
                i = M;
                i <<= 8;
                i |= L;
                i = i * 0.0625 * 10 + 0.5;
                Display(i);
