查看: 2393|回復: 0
智能尋跡小車51單片機控制程序
ID:218007 發表于 2017-7-7 22:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include "car.h"         //自己編寫的頭文件,里面有函數聲明
/*              清空電機控制IO位                        */
void CleanRun()
        left_a = 0;
        left_b = 0;
        right_a = 0;
        right_b = 0;
/*        根據接收到的數據,控制小車        */
void Run()
        uchar delaytime = 50;                                                //前進、后退、側向前進的延時時間
        uchar little_delaytime = 22;                //轉彎的延時時間
        switch(recvbuf)
                                        case 0x01:        //前進
                                                left_a = 1;                                                //正轉
                                                left_b = 0;
                                                right_a = 1;                                        //正轉
                                                right_b = 0;
                                                delayms(delaytime);
                                                break;
                                        case 0x02:        //后退
                                                left_a = 0;                                                //反轉
                                                left_b = 1;
                                                right_a = 0;                                        //反轉
                                                right_b = 1;
                                                delayms(delaytime);
                                                break;
                                        case 0x03:        //左轉
                                                left_a = 0;                                                //不轉
                                                left_b = 0;
                                                right_a = 1;                                        //正轉
                                                right_b = 0;
                                                delayms(little_delaytime);
                                                break;
                                        case 0x04:        //右轉
                                                left_a = 1;                                                //正轉
                                                left_b = 0;
                                                right_a = 0;                                        //不轉
                                                right_b = 0;
                                                break;
                                        case 0x05:        //前左方向運行
                                                right_a = 1;                                        //正轉
                                                right_b = 0;
                                                left_b = 0;                                                //半速正轉
                                                StartPwm(lefta);                        //開啟定時器,設定產生PWM的引腳
                                                delayms(delaytime);                //延時一段時間
                                                StopPwm();                                                //關閉定時器
                                                break;
                                        case 0x06:        //前右方向運行
                                                left_a = 1;                                                //正轉
                                                left_b = 0;
                                                right_b = 0;                                        //半速正轉
                                                StartPwm(righta);
                                                delayms(delaytime);
                                                StopPwm();
                                                break;
                                        case 0x07:        //后左方向運行
                                                right_a = 0;                                        //后轉
                                                right_b = 1;
                                                left_a = 0;                                                //半速后轉
                                                StartPwm(leftb);
                                                delayms(delaytime);
                                                StopPwm();
                                                break;
                                        case 0x08:        //后右方向運行
                                                left_a = 0;                                                //后轉
                                                left_b = 1;
                                                right_a = 0;                                        //半速后轉
                                                StartPwm(rightb);
                                                delayms(delaytime);
                                                StopPwm();
                                                break;
                                        case 0x09:        //原地順時針旋轉
                                                left_a = 1;
                                                left_b = 0;
                                                right_a = 0;
                                                right_b = 1;
                                                delayms(delaytime);
                                                break;
                                        case 0x0a:        //原地逆時針旋轉
                                                left_a = 0;
                                                left_b = 1;
                                                right_a = 1;
