查看: 2373|回復: 1
單片機數碼管按鍵出數程序
ID:194956 發表于 2017-7-7 17:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
sTC15w4k58s4,4*4按鍵矩陣,按鍵出數1-16
數碼管.zip (74.8 KB, 下載次數: 11)
  1. #include "reg51.h"
  2. #include "spi.h"
  3. #define ADC_POWER     0x80
  4. #define ADC_FLAG      0x10
  5. #define ADC_START     0x08
  6. #define ADC_SPEEDLL   0x00
  7. #define ADC_SPEEDL    0x20
  8. #define ADC_SPEEDH    0x40
  9. #define ADC_SPEEDHH   0x60
  10. sfr ADC_CONTR =0xBC;
  11. sfr ADC_RES   =0xBD;
  12. sfr ADC_RESL  =0xBE;
  13. sfr P1ASF     =0x9D;
  14. unsigned char ch=4;
  15. unsigned char datah=0,datal=0;
  16. unsigned int tmp=0;
  17. unsigned char code t_display[16]={0x3F,0x06,0x5B,0x4F,
  18.                                       0x66,0x6D,0x7D,0x07,
  19.                                       0x7F,0x6F,0x77,0x7C,
  20.                                       0x39,0x5E,0x79,0x71};
  21. unsigned char code T_COM[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  22. bit flag=0;
  23. unsigned m=0;
  24. void SPI_SendByte(unsigned char dat)
  25. {
  26.         SPSTAT=SPIF+WCOL;
  27.         SPDAT=dat;
  28.         while((SPSTAT & SPIF)==0);
  29.         SPSTAT=SPIF+WCOL;
  30. }
  31. void seg7scan(unsigned char index1,unsigned char index2)
  32. {
  33.         SPI_SendByte(~T_COM[index1]);
  34.         SPI_SendByte(t_display[index2]);
  35.         HC595_RCLK=1;
  36.         HC595_RCLK=0;
  37. }
  38. void timer_0() interrupt 1
  39. {
  40.         flag=1;
  41. }
  42. void adc_int() interrupt 5
  43. {
  44.         unsigned char i=0;
  45.         ADC_CONTR &=!ADC_FLAG;
  46.         tmp=(ADC_RES*4+ADC_RESL);
  47. //        switch(tmp)//不可以
  48. //        {
  49. //          case 1023:datah=1;datal=6;break;
  50. //                case 960:datah=1;datal=5;break;
  51. //                case 896:datah=1;datal=4;break;
  52. //                case 832:datah=1;datal=3;break;
  53. //                case 768:datah=1;datal=2;break;
  54. //                case 704:datah=1;datal=1;break;
  55. //                case 640:datah=1;datal=0;break;
  56. //                case 576:datah=0;datal=9;break;
  57. //                case 512:datah=0;datal=8;break;
  58. //                case 448:datah=0;datal=7;break;
  59. //                case 384:datah=0;datal=6;break;
  60. //                case 320:datah=0;datal=5;break;
  61. //                case 256:datah=0;datal=4;break;
  62. //                case 192:datah=0;datal=3;break;
  63. //                case 128:datah=0;datal=2;break;
  64. //                case 64:datah=0;datal=1;break;
  65. //                default:datah=0;datal=0;
  66. //        }
  67. //                ADC_CONTR=ADC_POWER |ADC_SPEEDLL | ADC_START | ch;
  68. //}
  69.         if(tmp>=1010&&tmp<=1023)
  70.         {
  71.           datah=1;datal=6;
  72.         }
  73.         else if(tmp>=950&&tmp<=970)
  74.         {
  75.           datah=1;datal=5;
  76.         }
  77.         else if(tmp>=886&&tmp<=906)
  78.         {
  79.           datah=1;datal=4;
  80.         }
  81.         else if(tmp>=822&&tmp<=842)
  82.         {
  83.           datah=1;datal=3;
  84.         }
  85.         else if(tmp>=758&&tmp<=778)
  86.         {
  87.           datah=1;datal=2;
  88.         }
  89.                 else if(tmp>=694&&tmp<=714)
  90.         {
  91.           datah=1;datal=1;
  92.         }
  93.                 else if(tmp>=630&&tmp<=650)
  94.         {
  95.           datah=1;datal=0;
  96.         }
  97.                 else if(tmp>=566&&tmp<=586)
  98.         {
  99.           datah=0;datal=9;
  100.         }
  101.                 else if(tmp>=502&&tmp<=522)
  102.         {
  103.           datah=0;datal=8;
  104.         }
  105.                 else if(tmp>=438&&tmp<=458)
  106.         {
  107.           datah=0;datal=7;
  108.         }
  109.                 else if(tmp>=374&&tmp<=394)
  110.         {
  111.           datah=0;datal=6;
  112.         }
  113.                 else if(tmp>=310&&tmp<=330)
  114.         {
  115.           datah=0;datal=5;
  116.         }
  117.                 else if(tmp>=246&&tmp<=266)
  118.         {
  119.           datah=0;datal=4;
  120.         }
  121.                 else if(tmp>=182&&tmp<=202)
  122.         {
  123.           datah=0;datal=3;
  124.         }
  125.                 else if(tmp>=118&&tmp<=138)
  126.         {
  127.           datah=0;datal=2;
  128.         }
  129.                 else if(tmp>=54&&tmp<=74)
  130.         {
  131.           datah=0;datal=1;
  132.         }
  133.         else
  134.                 {
  135.           datah=0;datal=0;
  136.         }
  137.
  138.         ADC_CONTR=ADC_POWER |ADC_SPEEDLL | ADC_START | ch;
  139. }
  140. void main()
  141. {
  142.         unsigned char i;//管號
  143.         unsigned int j=0;//延時
  144.         SPCTL=(SSIG<<7)+(SPEN<<6)+(DORD<<5)+(MSTR<<4)
  145.              +(CPOL<<3)+(CPHA<<2)+SPEED_4;
  146.   CLK_DIV=0x03;
  147.         TL0=TIMS;
  148.         TH0=TIMS>>8;
  149.   AUXR&=0x3F;
  150.         AUXR1=0X08;
  151.         TMOD=0x00;
  152.         TR0=1;
  153.         ET0=1;
  154.         P1ASF=0x10;
  155.         ADC_RES=0;
  156.         ADC_CONTR=ADC_POWER|ADC_SPEEDLL | ADC_START | ch;
  157. ……………………
  158. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ID:405995 發表于 2018-10-7 10:48 | 只看該作者
求仿真文件
