查看: 4182|回復: 0
CT107D 開發板上實現流水燈控制
ID:217409 發表于 2017-7-5 16:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg52.h"  //定義51單片機特殊功能寄存器
unsigned char read_key(void);
void key_proc(unsigned char key);
void delay(void);
void cls_buzz()
        P2 = (P2&0x1F|0xA0);
        P0 = 0x00;
        P2 &= 0x1F;
void cls_led()
        P2 = (P2&0x1F|0x80);
        P0 = 0xFF;
        P2 &= 0x1F;
//主函數
void main(void)
    unsigned char temp;
        cls_buzz();
        cls_led();
        temp = read_key();
        if(temp != 0xff)
            delay();  //按鍵消抖
            temp = read_key();
            if(temp != 0xff)
                //進入按鍵處理函數
                key_proc(temp);
                while(P3 != 0xff);  //等待按鍵釋放
//按鍵掃描函數
    unsigned char temp;
    unsigned char key_value = 0xff;
    temp = P3&0x0f;
    switch(temp)
        case 0x0e:
            key_value = 1;  //S7
            break;
        case 0x0d:
            key_value = 2;  //S6
            break;
        case 0x0b:
            key_value = 3;  //S5
            break;
        case 0x07:
            key_value = 4;  //S4
            break;
    return key_value;
//按鍵處理函數
    switch(key)
        case 1:
                        P2 = (P2&0x1f|0x80);
                        P0++;
                        P2 &= 0x1f;
            break;
        case 2:
                        P0--;
                        P2 &= 0x1f;
        case 3:
                        P0 += 2;
                        P2 &= 0x1f;
            break;
        case 4:
                        P0 -= 2;
                        P2 &= 0x1f;
            break;
//延時函數: 10ms@11.0592MHz
void delay(void)
        unsigned char i, j;
        i = 108;
        j = 145;
        do
                while (--j);
        } while (--i);
