查看: 2928|回復: 1
關于12864液晶顯示的代碼問題
ID:213766 發表于 2017-7-4 12:38 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
#include <intrins.h>
#include <stdlib.h>
#define uint  unsigned int
#define LCD_data  P0
sbit LCD_RS  =  P2^0;
sbit LCD_RW  =  P2^1;
sbit LCD_EN  =  P1^2;
sbit LCD_PSB =  P2^6;
uchar dis1[10];
uchar code dis2[] = {"www.txmcu.com"};
uchar code dis3[] = {"龍卷風"};
uchar code dis4[] = {"--------"};
void cls_buzz(void)
        P2 = (P2&0x1f|0xA0);
        P0 = 0x00;
        P2 = 0x1f;
        P2 = (P2&0x1f|0x80);
        P0 = 0xff;
        P2 = 0x1f;
        P2 = (P2&0x1f|0xc0);
        P0 = 0x00;
        P2 = 0x1f;
        P2 = (P2&0x1f|0xe0);
        P0 = 0xff;
        P2 = 0x1f;
void delay_1ms(uint x)
        uint i,j;
        for(j=0;j<x;j++)
                for(i=0;i<110;i++);
void write_cmd(uchar cmd)
    LCD_RS = 0;
    LCD_RW = 0;
    P0 = cmd;
        delay_1ms(5);
    LCD_EN = 1;
        delay_1ms(5);
    LCD_EN = 0;
void write_dat(uchar dat)
    LCD_RS = 1;
    LCD_RW = 0;
    P0 = dat;
        delay_1ms(5);
    LCD_EN = 1;
        delay_1ms(5);
    LCD_EN = 0;
void lcd_pos(uchar X,uchar Y)
   uchar  pos;
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
   pos = X+Y ;
   write_cmd(pos);
void makerand()
        uint ran;
        ran=rand();
        dis1[0]=ran/10000+0x30;
        dis1[1]=ran%10000/1000+0x30;
        dis1[2]=ran%1000/100+0x30;
        dis1[3]=ran%100/10+0x30;
        dis1[4]=ran%10+0x30;
        ran=rand();
        dis1[5]=ran/10000+0x30;
        dis1[6]=ran%10000/1000+0x30;
        dis1[7]=ran%1000/100+0x30;
        dis1[8]=ran%100/10+0x30;
        dis1[9]=ran%10+0x30;
void lcd_init()
    LCD_PSB = 1;         //2¢¿ú·½ê½
    write_cmd(0x30);      //»ù±¾Ö¸áî2ù×÷
    delay_1ms(5);
    write_cmd(0x0C);      //ÏÔ꾿a£¬1Ø1a±ê
    delay_1ms(5);
    write_cmd(0x01);      //Çå3yLCDμÄÏÔê¾ÄúèY
    delay_1ms(5);
    uchar i;
                cls_buzz();
    delay_1ms(10);
    lcd_init();
    lcd_pos(1,0);
    while(dis2[i] != '\0')
       write_dat(dis2[i]);
       i++;
        lcd_pos(2,0);
    i = 0;
    while(dis3[i] != '\0')
       write_dat(dis3[i]);
        lcd_pos(3,0);
    i = 0;
    while(dis4[i] != '\0')
       write_dat(dis4[i]);
       i++;
                lcd_pos(0,0);
                makerand();
                for(i=0;i<10;i++)
                    write_dat(dis1[i]);
原代碼如上,用12864液晶顯示三行數據
代碼是例程,我就改了sbit的端口數據,因為是在另一塊板子上弄
但是怎么都沒顯示
求指教~
修改端口的LCD原理圖
修改端口的LCD原理圖
ID:213766 發表于 2017-7-4 12:55 | 顯示全部樓層
自己回復自己。。問題已解決,是硬件問題
