查看: 4699|回復: 2
關于NRF24L01的問題
ID:146960 發(fā)表于 2017-7-2 11:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
在兩塊開發(fā)板上,用NRF24L01通信實現(xiàn)按下一塊開發(fā)板上的按鍵,另一塊開發(fā)版上的小燈亮
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "lcd.h"
#include "usart.h"
#include "24l01.h"
int main(void)
        u8 key,mode;
        u16 t=0;
        u8 tmp_buf[33];
        delay_init();                     //延時函數(shù)初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置中斷優(yōu)先級分組為組2:2位搶占優(yōu)先級,2位響應優(yōu)先級
        uart_init(115200);                 //串口初始化為115200
        LED_Init();                                          //初始化與LED連接的硬件接口
        KEY_Init();                                        //初始化按鍵
        LCD_Init();                                           //初始化LCD
        NRF24L01_Init();                    //初始化NRF24L01
        POINT_COLOR=RED;                        //設置字體為紅色
        LCD_ShowString(30,50,200,16,16,"ELITE STM32");
        LCD_ShowString(30,70,200,16,16,"NRF24L01 TEST");
        LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(30,110,200,16,16,"2015/1/17");
        while(NRF24L01_Check())
                LCD_ShowString(30,130,200,16,16,"NRF24L01 Error");
                delay_ms(200);
                LCD_Fill(30,130,239,130+16,WHITE);
                delay_ms(200);
                LED0=1;
        LCD_ShowString(30,130,200,16,16,"NRF24L01 OK"); //檢測24L01是否存在
                key=KEY_Scan(0);
                if(key==KEY0_PRES)
                        mode=0;
                        break;
                }else if(key==KEY1_PRES)
                        mode=1;
                        break;
                t++;
                if(t==100)LCD_ShowString(10,150,230,16,16,"KEY0:RX_Mode  KEY1:TX_Mode"); //閃爍顯示提示信息
                if(t==200)
                        LCD_Fill(10,150,230,150+16,WHITE);
                        t=0;
                delay_ms(5);
        LCD_Fill(10,150,240,166,WHITE);//清空上面的顯示
        POINT_COLOR=BLUE;//設置字體為藍色
        if(mode==0)//RX模式
                LCD_ShowString(30,150,200,16,16,"NRF24L01 RX_Mode");
                LCD_ShowString(30,170,200,16,16,"Received DATA:");
                NRF24L01_RX_Mode();
                        if(NRF24L01_RxPacket(tmp_buf)==0)//一旦接收到信息,則顯示出來.
                                tmp_buf[32]=0;//加入字符串結束符
                                LCD_ShowString(0,190,lcddev.width-1,32,16,tmp_buf);
                        }else delay_us(100);
                        t++;
                        if(t==10000)//大約1s鐘改變一次狀態(tài)
                                t=0;
                                LED0=!LED0;
        }else//TX模式
                LCD_ShowString(30,150,200,16,16,"NRF24L01 TX_Mode");
                NRF24L01_TX_Mode();
                mode=' ';//從空格鍵開始
                        if(NRF24L01_TxPacket(tmp_buf)==TX_OK)
                                LCD_ShowString(30,170,239,32,16,"Sended DATA:");
                                key=mode;
                                for(t=0;t<32;t++)
                                        key++;
                                        if(key>('~'))key=' ';
                                        tmp_buf[t]=key;
                                mode++;
                                if(mode>'~')mode=' ';
                                tmp_buf[32]=0;//加入結束符
                        }else
                                LCD_Fill(0,170,lcddev.width,170+16*3,WHITE);//清空顯示
                                LCD_ShowString(30,170,lcddev.width-1,32,16,"Send Failed ");
                        LED0=!LED0;
                        delay_ms(1500);
這是列程,我該改哪些部分?
ID:82765 發(fā)表于 2017-7-2 12:50 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
ID:146960 發(fā)表于 2017-7-2 15:00 | 只看該作者
cjjcjj1 發(fā)表于 2017-7-2 12:50
你好!你程序發(fā)的不完整,缺少主要的頭文件
#include "24l01.h"
#include "lcd.h"
#include "delay.h"
#include "spi.h"
#include "usart.h"
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //發(fā)送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};
//初始化24L01的IO口
void NRF24L01_Init(void)
  SPI_InitTypeDef  SPI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOG, ENABLE);         //使能PB,G端口時鐘
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;                                 //PB12上拉 防止W25X的干擾
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);        //初始化指定IO
        GPIO_SetBits(GPIOB,GPIO_Pin_12);//上拉
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8;        //PG8 7 推挽
        GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化指定IO
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PG6 輸入
        GPIO_ResetBits(GPIOG,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8);//PG6,7,8上拉
  SPI2_Init();                    //初始化SPI
        SPI_Cmd(SPI2, DISABLE); // SPI外設不使能
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //SPI設置為雙線雙向全雙工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //SPI主機
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //發(fā)送接收8位幀結構
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //時鐘懸空低
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;        //數(shù)據(jù)捕獲于第1個時鐘沿
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信號由軟件控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;                //定義波特率預分頻的值:波特率預分頻值為16
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //數(shù)據(jù)傳輸從MSB位開始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值計算的多項式
        SPI_Init(SPI2, &SPI_InitStructure);  //根據(jù)SPI_InitStruct中指定的參數(shù)初始化外設SPIx寄存器
        SPI_Cmd(SPI2, ENABLE); //使能SPI外設
        NRF24L01_CE=0;                         //使能24L01
        NRF24L01_CSN=1;                        //SPI片選取消
//檢測24L01是否存在
//返回值:0,成功;1,失敗
u8 NRF24L01_Check(void)
        u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
        u8 i;
        SPI2_SetSpeed(SPI_BaudRatePrescaler_4); //spi速度為9Mhz(24L01的最大SPI時鐘為10Mhz)
        NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//寫入5個字節(jié)的地址.
        NRF24L01_Read_Buf(TX_ADDR,buf,5); //讀出寫入的地址
        for(i=0;i<5;i++)if(buf!=0XA5)break;
        if(i!=5)return 1;//檢測24L01錯誤
        return 0;                 //檢測到24L01
//SPI寫寄存器
//reg:指定寄存器地址
//value:寫入的值
u8 NRF24L01_Write_Reg(u8 reg,u8 value)
        u8 status;
           NRF24L01_CSN=0;                 //使能SPI傳輸
          status =SPI2_ReadWriteByte(reg);//發(fā)送寄存器號
          SPI2_ReadWriteByte(value);      //寫入寄存器的值
          NRF24L01_CSN=1;                 //禁止SPI傳輸
          return(status);                               //返回狀態(tài)值
//讀取SPI寄存器值
//reg:要讀的寄存器
u8 NRF24L01_Read_Reg(u8 reg)
        u8 reg_val;
        NRF24L01_CSN = 0;          //使能SPI傳輸
          SPI2_ReadWriteByte(reg);   //發(fā)送寄存器號
          reg_val=SPI2_ReadWriteByte(0XFF);//讀取寄存器內容
          NRF24L01_CSN = 1;          //禁止SPI傳輸
          return(reg_val);           //返回狀態(tài)值
//在指定位置讀出指定長度的數(shù)據(jù)
//reg:寄存器(位置)
//*pBuf:數(shù)據(jù)指針
//len:數(shù)據(jù)長度
//返回值,此次讀到的狀態(tài)寄存器值
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len)
        u8 status,u8_ctr;
          status=SPI2_ReadWriteByte(reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
        for(u8_ctr=0;u8_ctr<len;u8_ctr++)pBuf[u8_ctr]=SPI2_ReadWriteByte(0XFF);//讀出數(shù)據(jù)
          NRF24L01_CSN=1;       //關閉SPI傳輸
          return status;        //返回讀到的狀態(tài)值
//在指定位置寫指定長度的數(shù)據(jù)
//reg:寄存器(位置)
//len:數(shù)據(jù)長度
u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len)
        u8 status,u8_ctr;
          status = SPI2_ReadWriteByte(reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
          for(u8_ctr=0; u8_ctr<len; u8_ctr++)SPI2_ReadWriteByte(*pBuf++); //寫入數(shù)據(jù)
          NRF24L01_CSN = 1;       //關閉SPI傳輸
//啟動NRF24L01發(fā)送一次數(shù)據(jù)
//txbuf:待發(fā)送數(shù)據(jù)首地址
//返回值:發(fā)送完成狀況
u8 NRF24L01_TxPacket(u8 *txbuf)
        u8 sta;
        SPI2_SetSpeed(SPI_BaudRatePrescaler_8);//spi速度為9Mhz(24L01的最大SPI時鐘為10Mhz)
        NRF24L01_CE=0;
          NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數(shù)據(jù)到TX BUF  32個字節(jié)
        NRF24L01_CE=1;//啟動發(fā)送
        while(NRF24L01_IRQ!=0);//等待發(fā)送完成
        sta=NRF24L01_Read_Reg(STATUS);  //讀取狀態(tài)寄存器的值
        NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中斷標志
        if(sta&MAX_TX)//達到最大重發(fā)次數(shù)
                NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
                return MAX_TX;
        if(sta&TX_OK)//發(fā)送完成
                return TX_OK;
        return 0xff;//其他原因發(fā)送失敗
//返回值:0,接收完成;其他,錯誤代碼
u8 NRF24L01_RxPacket(u8 *rxbuf)
        u8 sta;
        SPI2_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度為9Mhz(24L01的最大SPI時鐘為10Mhz)
        if(sta&RX_OK)//接收到數(shù)據(jù)
                NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數(shù)據(jù)
                NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
                return 0;
        return 1;//沒收到任何數(shù)據(jù)
//該函數(shù)初始化NRF24L01到RX模式
//設置RX地址,寫RX數(shù)據(jù)寬度,選擇RF頻道,波特率和LNA HCURR
//當CE變高后,即進入RX模式,并可以接收數(shù)據(jù)了
void NRF24L01_RX_Mode(void)
        NRF24L01_CE=0;
          NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//寫RX節(jié)點地址
          NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01);    //使能通道0的自動應答
          NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40);             //設置RF通信頻率
          NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數(shù)據(jù)寬度
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//設置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開啟
          NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式
          NRF24L01_CE = 1; //CE為高,進入接收模式
//該函數(shù)初始化NRF24L01到TX模式
//設置TX地址,寫TX數(shù)據(jù)寬度,設置RX自動應答的地址,填充TX發(fā)送數(shù)據(jù),選擇RF頻道,波特率和LNA HCURR
//PWR_UP,CRC使能
//CE為高大于10us,則啟動發(fā)送.
void NRF24L01_TX_Mode(void)
        NRF24L01_CE=0;
          NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//寫TX節(jié)點地址
          NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //設置TX節(jié)點地址,主要為了使能ACK
          NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
          NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//設置自動重發(fā)間隔時間:500us + 86us;最大自動重發(fā)次數(shù):10次
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40);       //設置RF通道為40
          NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);  //設置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開啟
          NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e);    //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷
        NRF24L01_CE=1;//CE為高,10us后啟動發(fā)送
,我主要是想實現(xiàn)目的,能移植成功夠就行
