查看: 2506|回復: 0
LCD顯示字符串
ID:215568 發(fā)表于 2017-6-28 18:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg51.h"
#include"absacc.h"
typedef unsigned char BYTE;
typedef unsigned int  WORD;
#define  wr_com  XBYTE[0xC000]
#define  wr_data  XBYTE[0xC100]
#define  rd_com  XBYTE[0xC200]
#define  rd_data  XBYTE[0xC300]
void lcd_init(void);                                    // lcd???
void write_cmd(BYTE cmd);
void write_data(BYTE dat) ;                    // ???
void set_display_place(BYTE line,column);
void write_string_lcd(BYTE line,column,unsigned char *string);
void Delay(WORD n)
{     WORD x;
         while(n--)
{      x=500;   while(x--);  }
                 {     BYTE dl;
                         do {
                         dl=rd_com;   }
                         while((dl&0x80)!=0); //??
                         wr_com= cmd;
                 Delay(1); }
{  BYTE dl;
         do {   dl=rd_com;   }
         wr_data= dat;
                Delay(1); }
                void write_string(BYTE *s)
                        {     while(*s != '\0')            //'\0'????????
                                {         write_data(*s);
                        s++;     } }
                        void set_display_place(BYTE line,column) {
                                BYTE address;
                                if(line == 1)     {
                                        address = 0x80 + column;
                        else if(line == 2)
                        {         address = 0xc0 + column;     }
                        write_cmd(address);          }
                        void write_string_lcd(BYTE line,column,unsigned char *string) {
                        set_display_place(line,column);
                        write_string(string);
                        Delay(1); }
                        void lcd_init(void)       {
                                write_cmd(0x38);//
                                write_cmd(0x38);//
                                write_cmd(0x06);//
                                write_cmd(0x0c);//
                                write_cmd(0x01);//
void main() {
         lcd_init();
        write_string_lcd(1,1,"   0123456789   ");
write_string_lcd(2,1,"   ABCDEDGHIJ   ");      } }
