只需一步,快速開(kāi)始
查看: 2213|回復(fù): 0
51單片機(jī)電子時(shí)鐘的設(shè)計(jì)及程序,為什么不能顯示結(jié)果?
#include "reg51.h"
#define char unsigned char
char code dis_7[12]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0xb2,0xf8,0x80,0x90,0xff,0xbf};
char code scan_con[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
char data dis[8]={0x00,0x00,0x0b,0x00,0x00,0x0b,0x00,0x00};
char data timedata[3]={0x00,0x00,0x00};
char data ms50=0x00,con=0x00,con1=0x00,con2=0x00;
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
void delay1ms(int t)
   int i,j;
   for(i=0;i<t;i++)
      for(j=0;j<120;j++)
void keyscan()
   EA=0;
   if(key0==0)
       delay1ms(10);
       while(key0==0)
       con++;
       TR0=0;
       ET0=0;
       if(con>=3)
         con=0;
         TR0=1;
         ET0=1;
    if(con!=0)
       if(key1==0)
          delay1ms(10);
          while(key1==0)
          timedata[con]++;
          if(con==2)
                 con1=24;
                 con1=60;
          if(timedata[con]>=con1)
             timedata[con]=0;
if(con!=0)
   if(key2==0)
          delay1ms(10);
            while(key2==0)
            timedata[con]--;
            if(con==2)
                con2=23;
                con2=59;
            if(timedata[con]<=0)
                      timedata[con]=con2;
EA=1;
void scan()
    char k;
    dis[0]=timedata[0]%10;
    dis[1]=timedata[0]/10;
    dis[3]=timedata[1]%10;
    dis[4]=timedata[1]/10;
    dis[6]=timedata[2]%10;
    dis[7]=timedata[2]/10;
    for(k=0;k<8;k++)
       P0=dis_7[dis[k]];
       P2=scan_con[k];
       delay1ms(1);
       P2=0xff;
main()
   TH0=0x3c;TL0=0xb0;
   TMOD=0x01;ET0=1;
   TR0=1;EA=1;
      scan();
      keyscan();
void time_intt0(void) interrupt 0
    ET0=0;TR0=0;
    TH0=0x3c;TL0=0xb0;
    TR0=1;
    ms50++;
    if(ms50==20)
         ms50=0x00;
         timedata[0]++;
         if(timedata[0]==60)
                timedata[0]=0;
                timedata[1]++;
                if(timedata[1]==60)
                      timedata[1]=0;
                      timedata[2]++;
                      if(timedata[2]==24)
                           timedata[2]=0;
     ET0=1;
為什么不能顯示結(jié)果
