查看: 5524|回復: 1
ADC0832模數轉換與顯示電路仿真與代碼
ID:212506 發表于 2017-6-19 11:48 | 顯示全部樓層 |閱讀模式
仿真圖
仿真圖
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  6. sbit RS = P2^0;
  7. sbit RW = P2^1;
  8. sbit E  = P2^2;
  9. sbit CS  = P1^0;
  10. sbit CLK = P1^1;
  11. sbit DIO = P1^2;
  12. uchar Display_Buffer[] = "0.00V";
  13. uchar code Line1[] = "Current Voltage:";
  14. void DelayMS(uint ms)
  15. {
  16.         uchar i;
  17.         while(ms--)
  18.         {
  19.                  for(i=0;i<120;i++);
  20.         }
  21. }
  22. bit LCD_Busy_Check()
  23. {
  24.         bit result;
  25.         RS = 0;
  26.         RW = 1;
  27.         E  = 1;
  28.         delay4us();
  29.         result = (bit)(P0&0x80);
  30.         E  = 0;
  31.         return result;
  32. }
  33. void LCD_Write_Command(uchar cmd)
  34. {
  35.         while(LCD_Busy_Check());
  36.         RS = 0;
  37.         RW = 0;
  38.         E  = 0;
  39.         _nop_();
  40.         _nop_();
  41.         P0 = cmd;
  42.         delay4us();
  43.         E = 1;
  44.         delay4us();
  45.         E = 0;
  46. }
  47. void Set_Disp_Pos(uchar pos)
  48. {
  49.         LCD_Write_Command(pos | 0x80);
  50. }
  51. void LCD_Write_Data(uchar dat)
  52. {
  53.         while(LCD_Busy_Check());
  54.         RS = 1;
  55.         RW = 0;
  56.         E  = 0;
  57.         P0 = dat;
  58.         delay4us();
  59.         E = 1;
  60.         delay4us();
  61.         E = 0;
  62. }
  63. void LCD_Initialise()
  64. {
  65.         LCD_Write_Command(0x38); DelayMS(1);
  66.         LCD_Write_Command(0x0c); DelayMS(1);
  67.         LCD_Write_Command(0x06); DelayMS(1);
  68.         LCD_Write_Command(0x01); DelayMS(1);
  69. }
  70. uchar Get_AD_Result()
  71. {
  72.         uchar i,dat1=0,dat2=0;
  73.         /*CS  = 0;
  74.         CLK = 0;
  75.         DIO = 1; _nop_(); _nop_();
  76.         CLK = 1; _nop_(); _nop_();
  77.         CLK = 0;DIO = 1; _nop_(); _nop_();
  78.         CLK = 1; _nop_(); _nop_();
  79.         CLK = 0;DIO = 1; _nop_(); _nop_();
  80.         CLK = 1;DIO = 1; _nop_(); _nop_();
  81.         CLK = 0;DIO = 1; _nop_(); _nop_();*/
  82.         uchar j;
  83.         CS=0;
  84.         for(j=0;j<4;j++)
  85.         {
  86.                 CLK=0;
  87.                 DIO=1;
  88.                 _nop_();_nop_();
  89.                 CLK=1;
  90.                 _nop_();_nop_();
  91.         }
  92.         for(i=0;i<8;i++)
  93.         {
  94.                  CLK = 1; _nop_(); _nop_();
  95.                 CLK = 0; _nop_(); _nop_();
  96.                 dat1 = dat1 << 1 | DIO;
  97.         }
  98.         for(i=0;i<8;i++)
  99.         {
  100.                  dat2 = dat2 << ((uchar)(DIO)<<i);
  101.                 CLK = 1; _nop_(); _nop_();
  102.                 CLK = 0; _nop_(); _nop_();
  103.         }
  104.         CS = 1;
  105.         return (dat1 == dat2) ? dat1:0;
  106. }
  107. void main()
  108. {
  109.         uchar i;
  110.         uint d;
  111.         LCD_Initialise();
  112.         DelayMS(10);
  113.         while(1)
  114.         {
  115.                  d = Get_AD_Result()*500.0/255;
  116.                 Display_Buffer[0]=d/100+'0';
  117.                 Display_Buffer[2]=d/10%10+'0';
  118.                 Display_Buffer[3]=d%10+'0';
  119.                 Set_Disp_Pos(0x01);
  120.                 i = 0;
  121.                 while(Line1[i]!='\0')
  122. ……………………
  123. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ADC0832模數轉換與顯示.rar (52.4 KB, 下載次數: 90)
ID:272932 發表于 2020-5-9 22:43 | 顯示全部樓層
真的黑,給的程序仿真失敗,只能用HEX文件仿真。
