淘寶買套件送的程序
- #include <AT89X52.h>
- #define uchar unsigned char
- #define uint unsigned int //宏定義
- #define KEY P3_7 //定義畫面切換按鍵
- uchar KY; //KY作用在后面說明
- uchar disp; //顯示漢字指針
- uchar pic=0,num=0; //pic為按鍵次數(shù);num為中斷次數(shù)
- uchar code love[] = {
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,
- 0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x0F,
- 0x04,0x10,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x04,0x10,0xF8,0x0F,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xFE,0x07,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x20,0x00,0x10,
- 0x00,0x08,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x82,0x20,0x82,0x20,
- 0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*LOVE*/
- uchar code loveyou[] = {
- 0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F,
- 0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00,
- 0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*心形圖案*/
- uchar code hehe[] = {
- 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
- 0xF0,0x0F,0x08,0x10,0x04,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
- 0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x20,
- 0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
- 0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x04,0x20,0x08,0x10,
- 0xF0,0x0F,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*呵呵o(∩_∩)o圖案*/
- unsigned char code hanzi[] = {
- //-- 歡 --
- 0x04,0x10,0x34,0x08,0xC4,0x06,0x04,0x01,
- 0xC4,0x82,0x3C,0x8C,0x20,0x40,0x10,0x30,
- 0x0F,0x0C,0xE8,0x03,0x08,0x0C,0x08,0x10,
- 0x28,0x60,0x18,0xC0,0x00,0x40,0x00,0x00,
- //-- 迎 --
- 0x40,0x00,0x42,0x40,0x44,0x20,0xC8,0x1F,
- 0x00,0x20,0xFC,0x47,0x04,0x42,0x02,0x41,
- 0x82,0x40,0xFC,0x7F,0x04,0x40,0x04,0x42,
- 0x04,0x44,0xFE,0x63,0x04,0x20,0x00,0x00,
- //-- 使 --
- 0x40,0x00,0x20,0x00,0xF8,0xFF,0x07,0x00,
- 0x04,0x80,0xF4,0x43,0x14,0x45,0x14,0x29,
- 0x14,0x19,0xFF,0x17,0x14,0x21,0x14,0x21,
- 0x14,0x41,0xF6,0xC3,0x04,0x40,0x00,0x00,
- //-- 用 --
- 0x00,0x80,0x00,0x60,0xFE,0x1F,0x22,0x02,
- 0x22,0x02,0x22,0x02,0x22,0x02,0xFE,0x7F,
- 0x22,0x02,0x22,0x02,0x22,0x42,0x22,0x82,
- 0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
- //-- 神 --
- 0x08,0x01,0x88,0x00,0x49,0x00,0xEE,0xFF,
- 0x58,0x00,0x88,0x00,0x00,0x00,0xF8,0x1F,
- 0x88,0x08,0x88,0x08,0xFF,0xFF,0x88,0x08,
- 0x88,0x08,0xFC,0x1F,0x08,0x00,0x00,0x00,
- //-- 奇 --
- 0x40,0x00,0x40,0x00,0x44,0x00,0x44,0x3E,
- 0x64,0x12,0x54,0x12,0x4C,0x12,0x47,0x12,
- 0x4C,0x3F,0x54,0x42,0x74,0x80,0xC6,0x7F,
- 0x44,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
- //-- 魔 --
- 0x00,0x40,0x00,0x30,0xFE,0x8F,0x4A,0x80,
- 0xAA,0x5F,0x9A,0x4A,0xFE,0x2A,0xAA,0x1A,
- 0xCB,0x0F,0xAA,0x7A,0xFE,0x8A,0x9A,0xAA,
- 0xAA,0x8F,0x6B,0x80,0x22,0xE0,0x00,0x00,
- //-- 幻 --
- 0x80,0x20,0xC0,0x30,0xA0,0x28,0x98,0x24,
- 0x87,0x22,0x80,0x21,0xC4,0x30,0x04,0x60,
- 0x04,0x00,0x04,0x20,0x04,0x40,0x04,0x80,
- 0x04,0x40,0xFE,0x3F,0x04,0x00,0x00,0x00,
- //-- 搖 --
- 0x10,0x02,0x10,0x42,0x10,0x81,0xFF,0x7F,
- 0x90,0x04,0x54,0x05,0xCC,0xF4,0xB4,0x44,
- 0x84,0x44,0xBC,0x7F,0x82,0x44,0xA2,0x44,
- 0x9B,0xF4,0x82,0x06,0x00,0x04,0x00,0x00,
- //-- 搖 --
- //-- 棒 --
- 0x10,0x04,0x10,0x03,0xD0,0x00,0xFF,0xFF,
- 0x90,0x00,0x54,0x05,0x44,0x12,0xD4,0x15,
- 0x74,0x14,0x5F,0xFF,0xD4,0x14,0x54,0x15,
- 0x56,0x12,0x44,0x06,0x40,0x02,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x7C,0x10,0xFE,0x3B,
- 0xFE,0x3B,0x7C,0x10,0x00,0x00,0x00,0x00,
- /*****函數(shù)聲明*****/
- void display1_ltor(void);
- void display2_ltor(void);
- void display2_rtol(void);
- void display3(void);
- void display4(void);
- /*****n(us)延時(shí)子程序*****/
- void DelayUs(uint N)
- uint x;
- for(x=0; x<=N;x++);
- /*****中斷服務(wù)程序*****/
- void intersvr0(void) interrupt 0
- KY=~KY; //每個(gè)搖動(dòng)來回水銀開關(guān)會(huì)在擺幅兩端分別產(chǎn)生下降沿中斷,只提取其中一次(從左向右搖才顯示)
- if(KY==0)
- num++; //計(jì)算中斷次數(shù)
- switch(pic) //選擇畫面
- case 0:{display1_ltor();}break;
- case 1:{display2_ltor();}break;
- case 2:{display3();}break;
- case 3:{display4();}break;
- default:{display1_ltor();}
- /*****顯示子程序1(漢字)*****/
- uchar i;
- if(num>10){disp++;num=0;} //12個(gè)漢字分為3次顯示完(每次顯示4個(gè)),每中斷10次切換
- if(disp>2)disp=0;
- DelayUs(5200); //此處延時(shí)時(shí)間依各硬件差別而各不相同,試著調(diào)整使得顯示內(nèi)容居中即可
- for(i=0;i<64;i++)
- P0=~hanzi[disp*128+i*2];
- P2=~hanzi[disp*128+i*2+1];
- DelayUs(100);
- /*****顯示子程序2(LOVE)*****/
- uchar i;
- DelayUs(4000);
- for(i=0;i<64;i++)
- P0=~love[i*2];
- P2=~love[i*2+1];
- DelayUs(140);
- /*****顯示子程序3(心形圖案)*****/
- uchar i;
- DelayUs(4000);
- for(i=0;i<64;i++)
- P0=~loveyou[i*2];
- P2=~loveyou[i*2+1];
- DelayUs(120);
- /*****顯示子程序4(呵呵o(∩_∩)o圖案)*****/
- uchar i;
- DelayUs(4000);
- for(i=0;i<64;i++)
- P0=~hehe[i*2];
- P2=~hehe[i*2+1];
- DelayUs(120);
- /*****主函數(shù)*****/
- void main(void)
- IT0=1;
- EX0=1;
- EA=1; //開中斷,下降沿中斷
- KY=0;
- KEY=1;
- while(1) //主程序中只檢測按鍵
- if(KEY==0) //畫面切換鍵按下
- DelayUs(10000); //按鍵去抖
- if(KEY==0);
- pic++;
- while(KEY==0);
- if(pic>3)pic=0;
- /*****END*****/
