查看: 3283|回復: 0
流水燈控制匯編語言程序
ID:209237 發表于 2017-6-8 15:47 | 顯示全部樓層 |閱讀模式
CODE SEGMENT
    ASSUME CS:CODE
START:MOV AL,90H
       MOV DX,206H
       OUT DX,AL
AGAIN:MOV DX,200H
      IN AL,DX
      MOV BP,8
      TEST AL,03H
      JZ TURNOFF
      TEST AL,01H
      JZ DISP_0
      TEST AL,02H
      JZ DISP_1
      JMP AGAIN
DISP_0:MOV AL,00000001B
LP1:   MOV DX,202H
       OUT DX,AL
       ROL AL,1
       CALL DELAY
       DEC BP
       CMP BP,0
       JZ AGAIN
       JMP LP1
DISP_1: MOV AL,10000000B
LP2:   MOV DX,202H
       OUT DX,AL
       ROR AL,1
       CALL DELAY
       DEC BP
       CMP BP,0
       JZ AGAIN
       JMP LP2
TURNOFF:
       MOV AL,00H
       MOV DX,202H
       OUT DX,AL
       JMP AGAIN
DELAY PROC NEAR
      MOV BX,4
D1:   MOV CX,10000
D2:   LOOP D2
      DEC BX
      JNZ D1
      RET
DELAY ENDP
CODE  ENDS
      END START
