查看: 37406|回復(fù): 6
數(shù)字電路8路數(shù)字搶答器設(shè)計(jì)文檔
進(jìn)行本次設(shè)計(jì)主要有兩個(gè)目的,一是對數(shù)字邏輯這門課 的理論知識進(jìn)行一次系統(tǒng)的梳理;二是鍛煉自己將理論應(yīng)用于實(shí)踐的能力。針對以上目的,就要求做到,通過分析實(shí)際的需求提煉出相應(yīng)的理論模型,進(jìn)而再進(jìn)行電路的設(shè)計(jì),在之后的實(shí)際電路實(shí)現(xiàn)的過程中,還可以根據(jù)實(shí)際的需要對電路做出一些改進(jìn)。
結(jié)合課堂理論知識與實(shí)驗(yàn)課的實(shí)踐經(jīng)驗(yàn),本次課計(jì)主要設(shè)計(jì)了一個(gè)智力競賽搶答器。該搶答電路允許八位選手同時(shí)參與,由主持人發(fā)出指令,可顯示選手序號、實(shí)現(xiàn)鎖存功能并具有顯示搶答倒計(jì)時(shí)和答題倒計(jì)時(shí)功能,對犯規(guī)選手(包括提前搶答和超時(shí)搶答),設(shè)計(jì)有顯示其序號的功能。
數(shù)字搶答器共包括搶答電路、控制電路和報(bào)警電路等部分,主要應(yīng)用有74LS00、74LS32、74LS76、74LS148、74LS161、74LS190、74LS373和555定時(shí)器等集成芯片,利用Multisim進(jìn)行設(shè)計(jì)并模擬仿真調(diào)試,然后在電子技術(shù)綜合實(shí)驗(yàn)儀上進(jìn)行實(shí)物操作。
目   錄
摘要······························································2
第1章 概述······················································ 4
第2章設(shè)計(jì)任務(wù)及要求········································ 5
         2.1 設(shè)計(jì)任務(wù)·············································5
         2.2 設(shè)計(jì)要求·············································5
第3章 系統(tǒng)設(shè)計(jì)·················································· 7
         3.1 方案論證·············································7
         3.2 系統(tǒng)設(shè)計(jì)·············································7
            3.2.1  結(jié)構(gòu)框圖及說明·································7
            3.2.2  系統(tǒng)原理圖及工作原理···························8
         3.3 單元電路設(shè)計(jì)·········································9
            3.3.1  單元電路工作原理·······························9
            3.3.2  元件參數(shù)選擇··································16
第4章 軟件仿真················································· 17
         4.1 仿真電路圖··········································17
         4.2 仿真過程············································17
         4.3 仿真結(jié)果············································19
第5章 安裝調(diào)試················································· 20
         5.1 安裝調(diào)試過程········································20
         5.2 故障分析············································20
第6章 結(jié)論····················································· 21
第7章 使用儀器設(shè)備清單········································· 22
參考文獻(xiàn)························································ 24
收獲、體會和建議················································ 25
第1章 概述
近年來類似于智力競賽類的搶答型娛樂競技活動越來越受到廣大群眾的歡迎,隨著科學(xué)技術(shù)的不斷發(fā)展,數(shù)字搶答器的功能日益豐富和完善,成本也在逐漸降低,易于擴(kuò)展、可靠性高、集成度高、功能多樣等優(yōu)點(diǎn)都使得數(shù)字搶答器得到了更加廣泛的應(yīng)用。
立足于《電子技術(shù)》這門的知識體系,力求通過本學(xué)科的一些知識來自主實(shí)現(xiàn)具有基本應(yīng)用功能的數(shù)字搶答器。希望通過這次設(shè)計(jì)實(shí)踐,達(dá)到兩個(gè)目的,鍛煉自己的動手實(shí)踐能力,以及用已學(xué)的知識對數(shù)字搶答器電路進(jìn)行詳盡的分析與模擬。
本次設(shè)計(jì)的數(shù)字搶答器電路主要由基本電路和擴(kuò)展電路組成,其中基本電路包括選手搶答電路、鎖存電路、主持人控制電路;擴(kuò)展電路包括倒計(jì)時(shí)電路和報(bào)警電路。通過優(yōu)先編碼器74LS148、鎖存器74LS373和譯碼器將參賽選手的輸入信號在顯示器上輸出,利用控制電路和主持人開關(guān)啟動報(bào)警電路;通過倒計(jì)時(shí)電路和譯碼電路將秒脈沖產(chǎn)生的信號在顯示器上輸出,并利用蜂鳴器和指示燈實(shí)現(xiàn)報(bào)警電路。
第2章 設(shè)計(jì)任務(wù)及要求
設(shè)計(jì)一個(gè)智力競賽搶答器。
1.基本設(shè)計(jì)任務(wù)
(1)設(shè)計(jì)一個(gè)具有八個(gè)選手(序號從1到8)的搶答電路,序號和選手一一對應(yīng);
(2)搶答器要求具有顯示選手的序號,同時(shí)禁止其他選手搶答的鎖存功能;
(3)設(shè)計(jì)主持人控制系統(tǒng)的開始與結(jié)束電路。當(dāng)主持人發(fā)出搶答命令,并同時(shí)按下啟動定時(shí)開關(guān)后,八個(gè)選手通過各自的按鍵開關(guān)發(fā)出搶答信號;
(4)報(bào)警電路:對犯規(guī)選手(包括提前搶答和超時(shí)搶答),設(shè)計(jì)有顯示搶答犯規(guī)選手序號的功能。
2.擴(kuò)展設(shè)計(jì)任務(wù)
(1)每個(gè)選手按鍵搶答問題的同時(shí),配有聲音提示;
(2)當(dāng)選手開始答題的時(shí)候,系統(tǒng)開始倒計(jì)時(shí)30s有數(shù)字顯示。計(jì)時(shí)結(jié)束時(shí),有聲息提示;
(3)當(dāng)主持人發(fā)出答題信號后,系統(tǒng)開始10s倒計(jì)時(shí),同時(shí)有數(shù)字顯示,若選手仍未搶答時(shí)間到后,停止搶答,同時(shí)具有聲音提示。
2.2 設(shè)計(jì)要求
按照設(shè)計(jì)任務(wù)提出設(shè)計(jì)方案,并完成原理圖設(shè)計(jì)、模擬仿真,按要求完成設(shè)計(jì)報(bào)告。
1.理論設(shè)計(jì)部分
  •      獨(dú)立完成系統(tǒng)的原理設(shè)計(jì)。說明系統(tǒng)實(shí)現(xiàn)的功能,應(yīng)達(dá)到技術(shù)指標(biāo),進(jìn)行方案論證,確定設(shè)計(jì)方案。
  •      畫出電路圖,說明各部分電路的工作原理,初步選定所使用的各種器件的主要參數(shù)及型號,列出元器件明細(xì)表。
  •      系統(tǒng)中包含的中、小規(guī)模集成電路的種類至少在六種以上。
2.模擬仿真
  •      根據(jù)理論設(shè)計(jì)用Multisim 7在計(jì)算機(jī)上進(jìn)行仿真。驗(yàn)證所設(shè)計(jì)方案的正確性。
  •      分析電路的工作原理,寫出仿真報(bào)告。
3.安裝調(diào)試部分
  •      實(shí)現(xiàn)給定的小型數(shù)字系統(tǒng),并進(jìn)行單元測試和系統(tǒng)調(diào)試。完成系統(tǒng)功能。
  •      若系統(tǒng)出現(xiàn)故障,排除系統(tǒng)故障,分析并記錄系統(tǒng)產(chǎn)生故障的原因,并將此部分內(nèi)容寫在報(bào)告中。
3.1方案論證
與普通搶答器比較,本作品有以下幾個(gè)方面的優(yōu)勢:
  • 具有清零裝置和搶答裝置,可由主持人操縱避免有人在主持人說“開始”前提前搶答違反規(guī)則。
  • 具有定時(shí)功能,在30秒內(nèi)無人搶答表示所有參賽選手獲參賽對本題棄權(quán)。
  • 30秒時(shí)仍無人搶答其報(bào)警電路工作表示搶答時(shí)間耗盡并禁止搶答。
圖3.1 系統(tǒng)組成框圖
搶答電路中,由主持人控制選手的搶答電路的工作與否,在發(fā)出搶答指令的同時(shí)打開倒計(jì)時(shí)電路,在倒計(jì)時(shí)時(shí)間范圍內(nèi)允許選手搶答。若選手超時(shí)或提前搶答,則犯規(guī),報(bào)警電路工作,顯示電路顯示犯規(guī)選手序號。若選手正常搶答,則顯示電路顯示搶答成功的選手序號,蜂鳴器工作發(fā)出提示,進(jìn)入答題系統(tǒng)。答題系統(tǒng)由主持人發(fā)令開始并控制倒計(jì)時(shí)系統(tǒng),在倒計(jì)時(shí)時(shí)間范圍內(nèi),選手答題。倒計(jì)時(shí)結(jié)束時(shí)提示電路發(fā)出提示,選手停止答題,展示自己的答案。一輪數(shù)字搶答器工作完畢后,主持人可以復(fù)位控制開關(guān)進(jìn)行下一輪搶答。
定時(shí)搶答器的總體框圖如下圖
圖3.2 系統(tǒng)組成框圖
如圖所示電路包括主體電路和擴(kuò)展電路兩部分。其中主體電路完成基本的搶答功能,即主持人按下控制開關(guān)后,當(dāng)選手按動搶答鍵時(shí),數(shù)碼管顯示選手編號,同時(shí)封鎖輸入電路,其他選手搶答無效。擴(kuò)展電路完成定時(shí)搶答的功能以及報(bào)警功能。圖3.2所示電路的工作過程是:接通電源后,主持人將控制開關(guān)置于“清除”處,此時(shí)搶答器處于禁止?fàn)顟B(tài),選手不能進(jìn)行搶答,定時(shí)顯示器顯示設(shè)定的時(shí)間(30s),當(dāng)主持人將控制開關(guān)置于 “開始”時(shí),揚(yáng)聲器發(fā)出聲響,搶答器處于工作狀態(tài),同時(shí)定時(shí)器開始倒計(jì)時(shí)。當(dāng)選手在定時(shí)時(shí)間內(nèi)按動搶答鍵時(shí),電路要完成以下功能:
(1)優(yōu)先編碼電路判斷搶答者的編號,并由鎖存器進(jìn)行鎖存,然后通過譯碼顯示電路在數(shù)碼管上顯示搶答者的編號;
(2)揚(yáng)聲器發(fā)出短暫聲響;
(3)控制電路對其余輸入編碼進(jìn)行封鎖,禁止其他選手進(jìn)行搶答;
(4)控制電路要使定時(shí)器停止工作,數(shù)碼管上顯示剩余的搶答時(shí)間,當(dāng)選手將問題回答完畢,主持人操作控制開關(guān)進(jìn)行系統(tǒng)清零,使系統(tǒng)回復(fù)到禁止工作狀態(tài),以便進(jìn)行下一輪搶答。當(dāng)定時(shí)時(shí)間到,卻沒有選手搶答時(shí),系統(tǒng)將報(bào)警,并封鎖輸入電路,禁止選手超時(shí)后搶答。
3.3  單元電路設(shè)計(jì)
3.3.1單元電路工作原理
(1)搶答電路的設(shè)計(jì)
搶答電路的功能有兩個(gè):一是能分辨出選手按鍵的的先后,并鎖存優(yōu)先搶答者的編號,供譯碼顯示電路用;二是有禁止其他選手搶答的鎖存功能,可用優(yōu)先編碼和鎖存器完成上述功能。
其電路組成如下所示:
圖3.3  搶答電路
工作原理:當(dāng)主持人控制開關(guān)處于“清零”位置時(shí),RS觸發(fā)器的R端為低電平,輸出端(4Q~1Q)全部為低電平。于是74LS48的BI=0,顯示器滅燈;74LS148的選通輸入端ST=0,74LS148處于工作狀態(tài),此時(shí)鎖存電路不工作。當(dāng)主持人將開關(guān)撥到“開始”位置時(shí),優(yōu)先編碼電路和鎖存電路同時(shí)處于工作狀態(tài),既搶答器處于等待工作狀態(tài),等待輸入端I7、I6、I5、I4、I3、I2、I1、I0輸入信號,當(dāng)有選手將鍵按下時(shí)(如按下S5),74LS148的輸出Y2Y1Y0=010,YEX=0,經(jīng)RS鎖存器后,CTR=1,BI=1,此時(shí)74LS279處于工作狀態(tài),4Q3Q2Q=101,經(jīng)74LS48譯碼后,顯示器顯示出“5”。此外,CTR=1,使74LS148的ST端為高電平,74LS148處于禁止工作狀態(tài),封鎖了其它按鍵的輸入。當(dāng)按下的鍵松開后,74LS148的YEX高電平,但由于CTR維持高電平不變,所以74LS148仍處于禁止工作狀態(tài),其它按鍵的輸入信號仍不會被接受。這就保證了搶答者的優(yōu)先性以及搶答電路的準(zhǔn)確性。當(dāng)優(yōu)先搶答者回答完問題后,主持人操作控制開關(guān)S,使搶答電路復(fù)位,以便進(jìn)行下一輪搶答。
(2)定時(shí)電路的設(shè)計(jì)
74LS48的7,6,2,3引腳接受來自74LS192的輸出信號并把它譯碼顯示在數(shù)碼管上。74LS192的9,10,11,15引腳完成時(shí)間設(shè)定功能,本設(shè)計(jì)要求定時(shí)30秒,所以把左邊的芯片的1,15引腳接高電位,期于的全接低位,使的初始時(shí)間設(shè)定為30秒。555芯片完成產(chǎn)生秒脈沖的功能。工作過程為:搶答開始前,74LS192的置數(shù)端為低電位,處于初始狀態(tài),數(shù)碼管顯示為30,5引腳接高電位。搶答開始后,秒脈沖沖推動右邊的芯片開始倒記時(shí),同時(shí)右邊芯片產(chǎn)生的信號做為左邊芯片的CP信號推動左邊的芯片倒記時(shí),完成十進(jìn)制的倒記時(shí)功能。當(dāng)有人搶答后1Q的輸出為1,經(jīng)過非門后變?yōu)?,通過與門屏蔽了秒信號,停止記時(shí),完成顯示搶答時(shí)間的功能。當(dāng)記到了30秒時(shí),左邊的芯片產(chǎn)生的定時(shí)到信號輸出為低電位,也屏蔽了秒信號,使得數(shù)碼管顯示為00。
圖3.4  定時(shí)電路
(3)報(bào)警電路的設(shè)計(jì)
555構(gòu)成多諧振蕩器,振蕩頻率為:
f0=1/(R1+2R2)*C*ln2=1.43/(R1+2R2)*C
其輸出信號經(jīng)三極管推動揚(yáng)聲器。PR為控制信號,當(dāng)PR為高電平時(shí),多諧振蕩器工作,反之,電路停振不再工作。
由555定時(shí)器和三極管構(gòu)成的報(bào)警電路如下所示:
圖3.5  報(bào)警電路
(4)時(shí)序控制電路的設(shè)計(jì)
時(shí)序控制電路是搶答器設(shè)計(jì)的關(guān)鍵,它要完成以下三項(xiàng)功能:
①主持人將控制開關(guān)撥到“開始”位置時(shí),揚(yáng)聲器發(fā)聲,搶答電路和定時(shí)電路進(jìn)入正常搶答工作狀態(tài),
②當(dāng)參賽選手按動搶答鍵時(shí),揚(yáng)聲器發(fā)聲,搶答電路和定時(shí)電路停止工作。
③當(dāng)設(shè)定的搶答時(shí)間到,無人搶答時(shí),揚(yáng)聲器發(fā)聲,同時(shí)搶答電路和定時(shí)電路停止工作。
根據(jù)上面的功能要求以及圖3.3和圖3.4,設(shè)計(jì)的時(shí)序控制電路如下圖所示:
圖3.6(A)  搶答與定時(shí)電路的時(shí)序控制電路
圖3.6(B)  報(bào)警電路的時(shí)序控制電路
門G1的作用是控制時(shí)鐘信號CP的放行與禁止,門G2的作用是控制74LS148的輸入使能端ST。圖3.6(A)的工作原理是:主持人控制開關(guān)從“清零”位置撥到“開始”位置時(shí),來自于圖3.3中的74LS279的輸出CTR=0,經(jīng)G3反相,A=1,則從555輸出端來的時(shí)鐘信號CP能夠加到74LS192的CPD時(shí)鐘輸入端,定時(shí)電路進(jìn)行遞減計(jì)時(shí),在定時(shí)時(shí)間未到時(shí),圖3.4中74LS192的借位輸出端BO2=1,門G2的輸出ST=0,使74LS148處于正常工作狀態(tài),從而實(shí)現(xiàn)功能①的要求;當(dāng)選手在定時(shí)時(shí)間內(nèi)按動搶答鍵時(shí),CTR=1,經(jīng)G3反相,A=0,封鎖CP信號,定時(shí)器處于保持狀態(tài),門G2的輸出ST=1,74LS148處于禁止工作狀態(tài),從而實(shí)現(xiàn)功能②的要求;當(dāng)定時(shí)時(shí)間到時(shí),圖3.4中74LS192的借位輸出端BO2=0,門G2的輸出ST=1,74LS148處于禁止工作狀態(tài),禁止選手進(jìn)行搶答,門G1同時(shí)處于關(guān)門狀態(tài),封鎖CP信號,使定時(shí)電路為00狀態(tài),從而實(shí)現(xiàn)功能③的要求,74LS121用于控制報(bào)警電路及發(fā)聲的時(shí)間。
(5)音頻產(chǎn)生電路的設(shè)計(jì)
  本單元用于產(chǎn)生音頻信號驅(qū)動蜂鳴器工作,要使蜂鳴器工作必須給其輸入脈沖信號,因此,在該單元中我們同樣采用了555定時(shí)器來產(chǎn)生方波脈沖,考慮到對脈沖信號能夠做到有效的控制,我們采用由555構(gòu)成的多諧振蕩器。
圖3.7   由555定時(shí)器構(gòu)成的多諧振蕩器
設(shè)電容C 原先未充電, 故 TH  = TR < VCC /3 , 此時(shí) uo  = 1 , 555內(nèi)的晶體管 T 截止 , 電源通過 R1 和 R2 對電容 C 充電。在 uC 沒有充電到 2VCC /3 之前, uo 保持 1 不變。
一旦 uC 充至穩(wěn)態(tài)值 , 即 TH = TR > 2VCC /3 , 立即 uo = 0 , 同時(shí)555內(nèi)的管 T 導(dǎo)通,電容 C 放電, 一直至VCC /3 , 使得uo 回到 1 , 進(jìn)入循環(huán)。
輸出方波的周期 T的計(jì)算:   T = T1  + T2  = 0.7 ( R1 + 2R2 ) C
在電路中用到的由555定時(shí)器構(gòu)成的音頻產(chǎn)生電路如下:
圖 3.8 音頻產(chǎn)生電路
該電路中555定時(shí)器的4腳接到指示控制電路中,由指示控制電路來控制音頻信號的產(chǎn)生及消失。即當(dāng)4腳來的是高電平時(shí),該電路才能正常工作并產(chǎn)生音頻信號驅(qū)動蜂鳴器,當(dāng)4腳來的是低電平時(shí),555定時(shí)器處于復(fù)位狀態(tài),輸出為低電平,蜂鳴器不工作。
(6) 聲光指示電路的設(shè)計(jì)
聲光指示單元用于指示搶答的信息,能夠指示出搶答是否有效,圖1.22是聲光指示單元的電路。各單元的指示信號送給雙與非門74LS00及雙輸入或門74LS32,它將信號進(jìn)行不同的組合處理分別送給發(fā)光二極管或音頻產(chǎn)生電路來向主持人做出相應(yīng)的信號指示。圖中,DS1為無效搶答指示燈,DS2為有效搶答指示燈。
以上就是多個(gè)單元電路的詳細(xì)分析,下面將各單元聯(lián)系起來做一次全面地分析。電路功能規(guī)定,當(dāng)SA按下后為清零狀態(tài),此時(shí)不允許搶答,只有當(dāng)SB按下后且在規(guī)定的時(shí)間內(nèi)搶答才視為有效搶答。分析如下。
首先接通電源,在主持人按下SA鍵后,此時(shí)74LS76的2腳及8腳均為低電平,而3和7始終為高電平,所以由74LS00功能表知將被預(yù)置為RS觸發(fā)器,則輸出端15腳為高電平,該路送到74LS373的LE端,使得74LS373能夠正常工作,此時(shí)要是沒有搶答鍵按下,則會實(shí)現(xiàn)如前面所述的清零功能,若此時(shí)有搶答鍵按下,則會在顯示器上顯示出相應(yīng)的號碼,但此種情況視為違規(guī)搶答,要發(fā)出違規(guī)信號,因?yàn)樵诖藭r(shí)有按鍵按下后,74LS148將會對信號進(jìn)行編碼,則它的EO端將輸出高電平送至74LS00的9腳,而該與非門另一輸入端接到定時(shí)器輸出端此時(shí)為低電平,所以在74LS00的11腳輸出為低電平,此時(shí)有效指示燈DS2不會點(diǎn)亮,相反地,74LS148的GS將輸出低電平,由于電容C1的作用此時(shí)74LS76的2和8腳皆上升為高電平被預(yù)置為邊沿JK觸發(fā)器,由于按鍵SB為按下所以定時(shí)電路輸出低電平,將在9腳和12腳分別產(chǎn)生高、低電平,隨著GS低電平信號的到來,11腳將輸出高電平,這時(shí)DS1將被點(diǎn)亮指示為無效搶答,同時(shí)74LS32輸出高電平使得音頻電路產(chǎn)生脈沖信號驅(qū)動揚(yáng)聲器工作。
在按下SA鍵后,接著再按下SB鍵,此時(shí)開始定時(shí),定時(shí)時(shí)間由定時(shí)電路設(shè)定,此時(shí)定時(shí)電路將輸出一高電平。74LS76的9和12腳將分別為低、高電平。在有搶答按鍵按下后。74LS76的11腳輸出低電平。而747LS00的11腳輸出為高電平,此時(shí)DS1位被點(diǎn)亮,DS2被點(diǎn)亮同時(shí)蜂鳴器發(fā)出聲音。指示為搶答有效。
(1)搶答電路開始運(yùn)行,主持人將控制開關(guān)置于清除位置。搶答器出于禁止工作狀態(tài),蜂鳴器關(guān)閉,顯示電路關(guān)閉,定時(shí)顯示器顯示設(shè)定的10秒搶答倒計(jì)時(shí);
(2)當(dāng)主持人開關(guān)置于開始位置,蜂鳴器聲音提示,搶答器處于工作狀態(tài),定時(shí)器開始10秒搶答倒計(jì)時(shí);
(3)10秒倒計(jì)時(shí)內(nèi),若有選手成功搶答,鎖存器工作,顯示電路顯示選手編號,同時(shí)亮綠燈,禁止其他選手再次搶答,蜂鳴器聲音提示,計(jì)時(shí)器開始顯示30秒答題倒計(jì)時(shí);
(4)若有人在主持人開關(guān)開始前搶答,或者當(dāng)10秒搶答倒計(jì)時(shí)結(jié)束后再由選手搶答,報(bào)警啟動,有蜂鳴聲,同時(shí)亮起紅燈。
(5)當(dāng)選手搶答成功后,主持人將開始答題開關(guān)打開,30秒答題計(jì)時(shí)系統(tǒng)開始工作,倒計(jì)時(shí)結(jié)束后,蜂鳴器報(bào)警,禁止選手超時(shí)作答
3.3.2元件參數(shù)選擇
表3.1 元件參數(shù)選擇
序號
類型
數(shù)量
1
74LS279(RS鎖存器)
1
2
74LS48(4線—7段譯碼驅(qū)動器)
3
3
74LS148(8線—3線優(yōu)先編碼器)
1
4
74LS192(十進(jìn)制可逆計(jì)數(shù)器)
2
5
74LS121(單穩(wěn)態(tài)觸發(fā)器)
1
6
74LS00(二輸入與非門)
2
7
74LS20(四輸入與非門)
2
8
NE555
2
9
晶體管3DG130
1
10
七段數(shù)碼管(共陰極)
1
11
B鍵(觸發(fā)開關(guān))
9
12
發(fā)光二極管
1
13
揚(yáng)聲器
1
14
B鍵(輸入開關(guān))
8
15
電阻(510Ω)
2
16
電阻(1KΩ)
2
17
電阻(10KΩ)
9
18
電阻(15KΩ)
2
19
電阻(68KΩ)
2
20
電容(0.01μF)
2
21
電容(0.1μF)
2
22
電容(10μF)
2
23
電容(100μF)
2
4軟件仿真
4.1 仿真電路圖
如下圖所示:
圖4.1 仿真電路圖
4.2 仿真過程
按上述原理設(shè)計(jì)出整個(gè)電路,用Multisim12軟件進(jìn)行EDA仿真調(diào)試,首先讓選手的1-8的按鍵彈起,點(diǎn)擊仿真按鈕,主持人清零開關(guān)J9和定時(shí)器開關(guān)J10同時(shí)閉合,實(shí)現(xiàn)對選手搶答數(shù)碼管清零和對定時(shí)器數(shù)碼管置數(shù)的功能,然后斷開J9和J10,讓選手進(jìn)行搶答,通過仿真調(diào)試,該電路完全能夠?qū)崿F(xiàn)搶答器設(shè)計(jì)要求的基本功能和擴(kuò)展功能。
第2路搶答器搶答后的顯示,同時(shí)發(fā)光二極管指示燈發(fā)光,如下圖:
圖4.2 搶答結(jié)果
CTR端的示波器波形,撥動開關(guān)后,CTR上跳,有人搶答時(shí),CTR下跳,如下圖所示:
圖4.3 示波器波形圖
倒計(jì)時(shí)開始后開始計(jì)數(shù),同時(shí)倒計(jì)時(shí)指示燈亮直到倒數(shù)到0秒熄滅,如下圖所示:
圖4.4 顯示結(jié)果
倒計(jì)時(shí)開始后開始計(jì)數(shù),同時(shí)倒計(jì)時(shí)指示燈亮直到倒數(shù)到0秒熄滅,計(jì)時(shí)器個(gè)位減到0時(shí),BO1出現(xiàn)一個(gè)下跳;計(jì)時(shí)器十位減到0時(shí),BO2出現(xiàn)一個(gè)下跳,如下圖所示:
圖4.5 示波器波形圖
4.3 仿真結(jié)果
主持人打開開關(guān)搶答開始計(jì)時(shí),有人搶答后顯示編號且顯示剩余時(shí)間。時(shí)間到00后報(bào)警燈亮且無法搶答。而提前搶答和超時(shí)搶答時(shí)會由蜂鳴器發(fā)聲,進(jìn)行報(bào)警。該仿真完全達(dá)到要求。
第5章 安裝調(diào)試
5.1 安裝調(diào)試過程
電子電路的組裝與調(diào)試在電子設(shè)計(jì)技術(shù)中占有重要位置。它是對理論設(shè)計(jì)進(jìn)行檢 驗(yàn)、修改和完善的過程,任何一個(gè)新產(chǎn)品往往都是在安裝、調(diào)試并反復(fù)改多次方能最終完成。
組裝電路時(shí)應(yīng)注意以下幾點(diǎn):
1)              所有元器件在組裝前應(yīng)盡可能全部測試一遍,以保證所用元器件均合格。
2)              所有集成電路的組裝方向要保持一致,以便于正確布線和查線。
3)              組裝分立元件時(shí)應(yīng)使其標(biāo)志朝上或朝向易于觀察的方向,以便于查找和更換。
4)              對于有極性的元件,例如電解電容器、晶體二極管等,組裝時(shí)一定要特別注意,切勿搞錯(cuò)。
5)              為了便于查線,可根據(jù)連接線的不同作用選擇不同顏色的導(dǎo)線。一般習(xí)慣是正電源用紅色線、負(fù)電源用藍(lán)色線、地線用黑色線、信號線用黃色線等。
6)              連線盡量做到橫平豎直。連線不允許跨接在集成電路上,必須從其周圍通過。同時(shí)應(yīng)盡可能做到連線不互相重疊、不從元器件上方通過。
7)              為使電路能夠正常工作與調(diào)測,所有地線必須連接在一起,形成一個(gè)公共參考點(diǎn)。
正確的組裝方法和合理的布局,不僅可使電路整齊美觀、工作可靠,而且便于檢查、調(diào)試和排除故障。如果能在組裝前先擬訂出組裝草圖,則可獲得事半功倍之效果,使組裝既快又好。
5.2 故障分析
連接完成后,報(bào)警電路工作異常。經(jīng)排查,導(dǎo)線連接正確,各元件完好。后借助儀器檢查出損壞導(dǎo)線,更換后電路正常。
第6章 結(jié)論
本設(shè)計(jì)基本完成了老師的要求,能夠?qū)崿F(xiàn)全部的功能。能八路搶答,能定時(shí)搶答,也能報(bào)警,清零。
    在進(jìn)行實(shí)驗(yàn)的時(shí)候,遇到不少的問題。一開始不知道該使用什么芯片去做實(shí)驗(yàn),復(fù)習(xí)老師講過的課件,熟悉芯片的功能,同時(shí)去圖書館借有關(guān)書籍,看看哪些芯片能達(dá)到編碼,譯碼,鎖存等,以及重新溫習(xí)了上個(gè)學(xué)期的《數(shù)字邏輯與數(shù)字系統(tǒng)》書本。經(jīng)過資料的搜集,基本確定了用哪類芯片達(dá)到哪類功能。然后就研究電路圖,仔細(xì)對照真值表連接電路圖,并畫好電路圖草稿。畫好電路圖后,然后在電腦上模擬,一開始在電腦上畫好電路圖后,仿真也不過,存在幾個(gè)錯(cuò)誤,慢慢檢查后,是連線的錯(cuò)誤,有幾個(gè)地方是不該接在一起的,從而造成了一個(gè)輸入端有兩個(gè)輸入量。在排除錯(cuò)誤后,經(jīng)過了仿真,但是數(shù)碼管完全沒有反應(yīng),檢查后發(fā)現(xiàn)是因?yàn)樵谕ㄟ^與非門進(jìn)行清零的時(shí)候,接線錯(cuò)誤導(dǎo)致令74LS279一直不工作,改過錯(cuò)誤后,數(shù)碼管能正確顯示,選手也能搶答,但是搶答時(shí)間到了,74LS192還是在計(jì)數(shù),不能在00那里停止,于是改進(jìn)電路圖,使74LS192的十位的BON連到一個(gè)脈沖上。上面是一些問題和解決方法,其實(shí)遇到的問題遠(yuǎn)不止這些,不過現(xiàn)在回想起來都是一些很低級的錯(cuò)誤,有時(shí)候是因?yàn)榇中拇笠庠斐傻腻e(cuò)誤,有時(shí)候是因?yàn)闆]有認(rèn)真看芯片的真值表而造成的。
    經(jīng)過了這次設(shè)計(jì),我收獲良多。在一開始的時(shí)候,很擔(dān)心自己不能完成實(shí)驗(yàn),因?yàn)樯蠈W(xué)期的數(shù)字邏輯不是學(xué)得很好,造成信心不是很足。后來也證明了我是可以獨(dú)立完成的。在設(shè)計(jì)電路的時(shí)候,考慮的不是很全面,以及畫電路圖的時(shí)候沒有很細(xì)心謹(jǐn)慎地工作,造成了一些低級錯(cuò)誤。所以經(jīng)過設(shè)計(jì),我提高了自己的動手能力,也增強(qiáng)了自己的信心。同時(shí)讓我知道在工作的時(shí)候要保持細(xì)致嚴(yán)密的工作態(tài)度,這樣會事半功倍。
第7章 使用儀器設(shè)備清單
1. 74LS148的引腳圖和邏輯功能表
2. 74121的邏輯功能表和引腳圖(代替74LS121)
3. 74LS279的邏輯功能表和引腳圖
4. 74LS192的邏輯功能表和引腳圖
參考文獻(xiàn)
1.李景宏,馬學(xué)文.電子技術(shù)實(shí)驗(yàn)教程.沈陽:東北大學(xué)出版社.2000
2.王永軍,李景華編著.數(shù)字邏輯與數(shù)字系統(tǒng).北京:電子工業(yè)出版社,2002
3.高吉祥,易凡編著.電子技術(shù)基礎(chǔ)實(shí)驗(yàn)與設(shè)計(jì).北京:電子工業(yè)出版社,2002
4.陳大欽編著. 電子技術(shù)基礎(chǔ)實(shí)驗(yàn). 北京:高等教育出版社,2000
收獲、體會和建議
由為期數(shù)天的設(shè)計(jì)實(shí)踐,主要獲得以下幾點(diǎn)總結(jié)和體會。這次設(shè)計(jì)是通過查閱多種資料、與同學(xué)討論以及獨(dú)立思考設(shè)計(jì)出來的。在設(shè)計(jì)過程中,用到了本學(xué)期所學(xué)過的各個(gè)集成芯片,因此我對它們的功能和運(yùn)用有了更深一步的了解。同時(shí)通過Multisim軟件對電路進(jìn)行模擬仿真,從而使設(shè)計(jì)結(jié)果得到了驗(yàn)證。 通過這次設(shè)計(jì)環(huán)節(jié),我了解到模擬電路和數(shù)字電路之間的聯(lián)系,對單元功能電路的理解和運(yùn)用能力有了一定的提高。
將理論與實(shí)踐相結(jié)合,知識的價(jià)值才會真正體現(xiàn)出來,但將所學(xué)的知識合理有效的應(yīng)用于實(shí)踐中,是很艱難的。然而面對困難我們需要勇氣和執(zhí)著,如果缺乏勇氣不能在挫折面前我們便會不知所措,不愿有所作為,這樣是不會有進(jìn)展的。一開始接觸這樣綜合性的電路實(shí)驗(yàn),我心里很沒底,不知從何處著手。但是指導(dǎo)老師的指點(diǎn)和查閱的一些資料讓我漸漸理清思路。另外還想提一下的就是Multisim的使用,開始的時(shí)候?qū)ultisim很不熟悉,但是摸索一段時(shí)間,我們還是能用它來進(jìn)行仿真設(shè)計(jì)的。當(dāng)然要進(jìn)行一項(xiàng)比較復(fù)雜的實(shí)踐時(shí),光有勇氣還是不夠的,更加需要執(zhí)著的付出。
這次的設(shè)計(jì)主要是關(guān)于數(shù)字電路的知識,譬如多諧震蕩器的原理,其周期的計(jì)算,模式開關(guān)電路的設(shè)計(jì),各種芯片(主要是74LS373和74LS148等)的結(jié)構(gòu)與功能等。這時(shí)需要靜下心來復(fù)習(xí),把電路的各個(gè)部分原理弄清楚。
基于以上所述,總的來說就是三點(diǎn)。一,端正態(tài)度,認(rèn)真負(fù)責(zé)。要像對待理論學(xué)習(xí)一樣,認(rèn)真地參與實(shí)踐,將理論聯(lián)系實(shí)際,在實(shí)踐中檢驗(yàn)理論,升華理論知識。認(rèn)真聽取指導(dǎo)教師的意見和建議,不斷改進(jìn)。二,堅(jiān)持付出,不懼失敗。在實(shí)踐活動中,我們可能會遇到各種各樣的困難,經(jīng)歷很多失敗,這是必然的,但面對困難與失敗,我們要迎難而上,要有一股不出結(jié)果不罷休的精神。三,勇于創(chuàng)新,精益求精。在實(shí)踐中不斷改進(jìn),取得更大的進(jìn)步。
以上文檔肯定存在很多錯(cuò)誤,歡迎大家批評指正,一起學(xué)習(xí) 提高技術(shù)(word格式 可編輯的文檔下載,僅供參考 切勿照搬):
課 程 設(shè) 計(jì) 報(bào) 告.docx (509.25 KB, 下載次數(shù): 120)
參與人數(shù) 4黑幣 +59 收起 理由
cj123suiyue + 1 tmd。仿真電路圖每一個(gè)對的,照著畫都運(yùn)行.
moxinooo + 3
Triste. + 5 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂 踩
ID:161488 發(fā)表于 2017-6-5 18:26 | 只看該作者
51有你更精彩!
ID:324020 發(fā)表于 2018-5-7 10:48 | 只看該作者
感謝樓主分享,好貼頂一個(gè)
ID:352507 發(fā)表于 2018-6-17 16:58 | 只看該作者
原理圖跟后面的仿真電路對不上號,所用的器件后面有的也沒有,不知道樓主發(fā)出來有啥意思?這也太水了吧,仿真電路放不出來,報(bào)警電路跟原理圖完全不一樣!
ID:361672 發(fā)表于 2018-6-29 11:32 | 只看該作者
有沒有用74ls165 20  的設(shè)計(jì)啊
ID:310363 發(fā)表于 2018-7-30 10:07 | 只看該作者
好像對不上哦。有沒有仿真圖,上一個(gè)澄清一下哦。嘻嘻!
ID:358756 發(fā)表于 2018-9-8 09:01 | 只看該作者
謝謝樓主的分享 是個(gè)好人啊啊
