查看: 3833|回復: 2
電子密碼鎖源程序
ID:207533 發表于 2017-6-3 23:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define uchar unsigned char  //無符號字符型  宏定義  變量范圍0~255
#define uint  unsigned int  //無符號整型  宏定義  變量范圍0~65535
#include "lcd1602.h"
#include "at24c02.h"
sbit relay = P2^2;   //繼電器定義
sbit beep  = P3^3;   //蜂鳴器定義
sbit beiguang = P2^3;   //背光
bit flag_200ms=1;  //200ms標志位
uchar value,i;  //變量
uchar flag_lj_en=1;   //連加使能
uchar flag_lj_en_value;
uchar key_can;   //鍵值
uchar menu_1,menu_i;
uchar smg_i;   //輸密光標
uchar dis_smg[8]={0};
uchar password[8]={8,7,6,5,4,3,2,1}; //密碼保存
uchar password_bj[8]={1,2,3,4,5,6,7,8}; //密碼比較
uchar code password_r[8] = {1,2,3,4,1,2,3,4} ;
uchar password_xg[8]={7,6,5,4,3,2,1,0}; //密碼修改
uchar flag_password;      //密碼正確否標志
uchar flag_password_cishu;//密碼錯誤次數標志
uint flag_time;    //時間標志位
uint flag_bisuo;   //閉鎖標志位
/***********************1ms延時函數*****************************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
  for(j=0;j<120;j++);
/*************************清空數組函數**************************/
void clear_shuzu(uchar *p)
for(i=0;i<8;i++)
  p[i] = 0;
/**************************定時器0初始化函數*******************/
void time_init()
EA   = 1;     //開總中斷
TMOD = 0X01;   //定時器0、工作方式1
ET0  = 1;    //開定時器0中斷
TR0  = 1;    //允許定時器0定時
/********************下載程序密碼初始化函數********************/
void password_chushihua()
  beep = 0;
  write_24c02_8(8,0,password_r);
  delay_1ms(200);
  read_24c02_8(8,0,password);
  beep = 1;
/***********************鍵盤掃描函數**************************/
void key()
static uchar key_new = 0, key_l;
key_can = 20;                   //按鍵值還原
P1 = 0x0f;
if((P1 & 0x0f) != 0x0f)  //如果有按鍵按下
  delay_1ms(1);       //延時消抖
  if(((P1 & 0x0f) != 0x0f) && (key_new == 1))  //再次確認
   key_new = 0;
   key_l = (P1 | 0xf0);   //通過算法得到鍵值
   P1 = key_l;
   switch(P1)  //得到鍵值
    case 0xee:  key_can = 1;  break;
    case 0xde:  key_can = 4;  break;
    case 0xbe:  key_can = 7;  break;
    case 0x7e:  key_can = 10;  break;
    case 0xed:  key_can = 0;  break;
    case 0xdd:  key_can = 8;  break;
    case 0xbd:  key_can = 5;  break;
    case 0x7d:  key_can = 2;  break;
    case 0xeb:  key_can = 3;  break;
    case 0xdb:  key_can = 6;  break;
    case 0xbb:  key_can = 9;  break;
    case 0x7b:  key_can = 11;  break;
    case 0xe7:  key_can = 15;  break;
    case 0xd7:  key_can = 14;  break;
    case 0xb7:  key_can = 13;  break;
    case 0x77:  key_can = 12;  break;
  key_new = 1; //沒有鍵按下時賦值
  flag_lj_en = 0;
/****************按鍵功能處理********************/
void key_with()
static uchar value;
if(key_can == 14)   //如果是“手動閉鎖”鍵
  relay = 1;
if(key_can == 10)  //如果是“密碼還原”鍵
    flag_lj_en = 1;   //連加使能
    flag_lj_en_value = 0;
if(menu_1 == 0)
  if(key_can <= 9)
  if(menu_i < 8)   //密碼輸入位數
   menu_i ++;
   if(menu_i > 8)  //超過8位無法寫入
    menu_i = 8;
   smg_i = menu_i;
   for(i=8;i>0;i--) //依次裝入密碼比較數組
    password_bj[i] = password_bj[i-1];
   password_bj[0] = key_can;
   for(i=0;i<smg_i;i++)  //顯示占位符“*”
    dis_smg[i] ='*';
   write_string(2,7,dis_smg);
   lcd1602_gbiao(1,7 + menu_i + 0x40);  //開光標
  if(key_can == 11)  //如果是“密碼刪除”鍵
   for(i=0;i<menu_i;i++)   //依次從比較數組中取出密碼
    password_bj[i] = password_bj[i+1];
   menu_i --;
   password_bj[menu_i] = ' ';  //清除占位符
   dis_smg[menu_i] = ' ';
  if(key_can == 15)  //如果是“確認”鍵
   value = 0;
   for(i=0;i<8;i++) //8位密碼分別比較
    if(password_bj[i] == password[i])
     flag_password = 1;  //密碼正確
     relay = 0;     //鎖開
     flag_password_cishu=0;   //輸入正確,錯誤次數清零
     for(i=0;i<8;i++)
      dis_smg[i] = 0xbf;
     flag_password = 0;
     flag_password_cishu ++;
     write_string(1,0," Password error ");
     write_string(2,0,"   cishu:       ");
     write_cwcs(2,9,flag_password_cishu);   //在第二行第九位顯示次數
     delay_1ms(280);
     for(i=0;i<6;i++)   //蜂鳴三聲
      beep = ~beep;
      delay_1ms(200);
     beep = 1;  //關閉蜂鳴
     delay_1ms(800);
     break;
   clear_shuzu(dis_smg);   //顯示初始化
   write_string(1,0," Password Lock  ");
   write_string(2,0," Input:         ");
   lcd1602_gbiao(1,7+0x40);  //開光標
   menu_i = 0;
/**************************密碼還原函數***************************/
void password_return()
if(flag_lj_en == 1)
  flag_lj_en_value ++;
  if(flag_lj_en_value > 13)
   flag_lj_en = 0;
   write_24c02_8(8,0,password_r);  //寫入初始化密碼
   beep = 0;
   delay_1ms(500);
   beep = 1;
   read_24c02_8(8,0,password);    //讀取密碼
/*******************************修改密碼**************************/
void xiugai_password()
if(key_can == 13)   //如果是“修改密碼”鍵
  if((relay == 0) && (menu_1 == 0))
   menu_1 = 1; menu_i = 0;  //賦值
   clear_shuzu(password_bj);   //數據清空
   write_string(1,0,"Input1:          ");
   write_string(2,0,"Input2:          ");
   lcd1602_gbiao(1,7);  //開光標
if(menu_1 == 1)   //第一次輸入修改的密碼
  if(key_can <= 9) //鍵號小于或等于9
   if(menu_i < 8)  //輸入個數小于8
    menu_i ++;
    if(menu_i > 8)
     menu_i = 8;
    smg_i = menu_i;
    for(i=8;i>0;i--)
     password_bj[i] = password_bj[i-1];  //依次裝入數組中
     dis_smg[i] ='*';  //依次顯示占位符“*”
    write_string(1,7,dis_smg);
    lcd1602_gbiao(1,7 + menu_i);  //開光標
  if(key_can == 11)   //如果是"刪除"鍵
   menu_i --;
  if(key_can == 15)  //如果是“確定”鍵
   clear_shuzu(password_xg);  //數據清空
   lcd1602_gbiao(1,7 + 0x40);  //開光標
   menu_1 = 2;
      menu_i = 0;
if(menu_1 == 2)   //第二次輸入修改的密碼
  if(key_can <= 9)
   if(menu_i < 8)
    menu_i ++;
    if(menu_i > 8)
     menu_i = 8;
    for(i=8;i>0;i--)
     password_xg[i] = password_xg[i-1];
    password_xg[0] = key_can;
     dis_smg[i] ='*';
  if(key_can == 11)  //如果是“刪除”鍵
    password_xg[i] = password_xg[i+1]; //依次從數組最后一個清除
   password_xg[menu_i] = ' ';
   dis_smg[menu_i] = ' ';   //依次顯示占位符“ ”
   for(i=0;i<8;i++)   //分別比較兩次輸入的8位密碼
    if(password_bj[i] == password_xg[i])   //只要有一位不匹配就會執行else
     flag_password = 1;  //兩次輸入的密碼一樣
     flag_password = 0;
     write_string(1,0," Password Error ");
     write_string(2,0,"     reenter    ");
     delay_1ms(300);
     for(i=0;i<6;i++)
      beep = ~beep;  //提示三聲
      delay_1ms(300);
     beep = 1;
     delay_1ms(1000);
     break;
   if(flag_password == 1)   //如果兩次輸入一致
    for(i=0;i<8;i++)
     write_string(1,0,"    Password    ");
     write_string(2,0,"    Succeed     ");
     password[i] = password_bj[i];     //保存密碼
    write_24c02_8(8,0,password);   //將密碼寫入AT24C02
    delay_1ms(300);
    beep = 0;   //蜂鳴器提示一聲
    delay_1ms(2000);
    beep = 1;
   menu_1 = 0;
      menu_i = 0;
/********************************主程序******************************/
static uint value ;
password_chushihua(); //密碼初始化
time_init();      //定時器初始化
read_24c02_8(8,0,password);       //從AT24C02讀取密碼
init_1602();    //LCD1602初始化
beiguang = 0;   //背光開
  if(flag_password_cishu < 3)     //判斷密碼錯誤次數是否小于3
   key();      //按鍵掃描函數
   if(key_can < 20)
    if(beiguang == 0)
     if(menu_1 == 0)
      key_with();    //按鍵處理函數
     xiugai_password();       //修改密碼函數
     beiguang = 0;
    flag_time = 0;
  if(flag_200ms == 1)
   flag_200ms = 0;
   if(beiguang == 0)  //延時30秒關閉背光
    flag_time ++;
    if(flag_time >= 5 * 30)    //延時30秒(50×4×5×30)
     flag_time = 0;
     beiguang = 1;  //關閉背光
   if(relay == 0)     //延時10秒關閉鎖
    flag_bisuo++;
    if(flag_bisuo >= 5 * 10) //延時10秒
     flag_bisuo = 0;
        relay = 1;    //關閉鎖
    flag_bisuo = 0;
   if(flag_password_cishu >= 3)
    value ++;   //每自加一次延時200ms
    beep = ~beep;      //蜂鳴器報警
    if(value >= 5 * 60)   //報警時間為1分鐘
     value = 0;
     beep = 1;
     flag_password_cishu = 0;
   password_return();   //密碼還原函數
  delay_1ms(1);
/***********************定時器0中斷服務程序***********************/
void time0_int() interrupt 1
static uchar value;
TH0 = 0x3c;  // 50ms(12M晶振下的定時初值)
TL0 = 0xb0;
    value ++;
if(value % 4 == 0)
  flag_200ms = 1;
ID:207533 發表于 2017-6-3 23:08 | 只看該作者
這個程序有什么毛病??
ID:82765 發表于 2017-6-4 08:29 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
