只需一步,快速開(kāi)始
查看: 5017|回復(fù): 1
8086仿真的問(wèn)題 用8253和8255A實(shí)現(xiàn)流水燈,求大神解答
  電路圖和代碼如下。一直找不到問(wèn)題在哪里,有大神指導(dǎo)嗎?用8253和8255A實(shí)現(xiàn)流水燈。
DATA SEGMENT
        COTR EQU 00F6H
        PB_A EQU 00F0H
        PC_A EQU 00EEH
DATA ENDS
CODE SEGMENT
   ASSUME CS:CODE,DS:DATA
  START: MOV DX,00EEH
         MOV AL,00110111B
                 OUT DX,AL
                 MOV DX,00E8H
                 MOV AL,50H
                 OUT DX,AL
                 MOV DX,00E8H
                 MOV AL,00H
                 OUT DX,AL
                 MOV AX,DATA
                 MOV DS,AX
                 MOV DX,COTR
                 MOV AL,10000001B
                 OUT DX,AL
                 MOV DX,00EEH
                 MOV AL,00110111B
                 OUT DX,AL
                 MOV DX,00E8H
                 MOV AL,50H
                 OUT DX,AL
                 MOV DX,00E8H
                 MOV AL,00H
                 OUT DX,AL
                 MOV DX,PB_A
                 MOV AL,0FCH
                 OUT DX,AL
            LOO: MOV DX,PB_A
                 OUT DX,AL
                 PUSH AX
           AGAIN:IN AL,0F4H
                 MOV AH,AL
                 IN AL,0F4H
                 CMP AL,AH
                 JZ AGAIN
                 POP AX
                 ROL AL,1
                 JMP LOO
        CODE ENDS
        END START
ID:463243 發(fā)表于 2019-1-8 15:00 | 只看該作者
樓主,可以說(shuō)一下你的這個(gè)流水燈的可以實(shí)現(xiàn)什么嗎?
