使用單片機(jī)+數(shù)碼管制作的計(jì)時(shí)器proteus仿真和源程序
2017-5-25 02:44 上傳
2017-5-25 02:43 上傳
單片機(jī)源程序如下:
- /***** L A B C E N T E R E L E C T R O N I C S *****/
- /***** LABCENTER INTEGRATED SIMULATION ARCHITECTURE *****/
- /***** Tasks Processes *****/
- #include <reg52.h>
- #include "cext.h"
- char num[ ] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; // 7-seg codes
- char add[ ] = {0x0fe,0x0fd,0x0fb,0x0f7}; // Multiplexing address
- char dpn[ ] = {0,0,0,0}; // Dots matrix
- char buf[ ] = {0,0,0,0}; // Counter buffer
- char alm[ ] = {0,0,0,0}; // Alarm sets buffer
- char value, key_mask, new_key;
- static uchar d0, d1, d2, d3, d5;
- static uchar flag;
- static uchar digit_counter;
- static char set_flag;
- static char set_count;
- static char set_alm;
- static char stop_counter = true;
- char un, th;
- uint timer;
- uint alarm;
- uchar del;
- // P2.7. Alarm output
- sbit alm_out = P2^7;
- // processor switch contest.
- #pragma registerbank (1)
- // Multiplexing Task. Do it every 10ms
- void led_mux ()
- { if (!set_flag)
- { // Normal counting. Display the counts.
- value = buf[digit_counter];
- P1 = num[value] | dpn[digit_counter] ;
- else
- { // Display alarm values
- value = alm[digit_counter];
- if (set_alm)
- { // Timer and alarm value
- timer = buf[0] * 1000 + buf[1] * 100 + buf[2] * 10 + buf[3];
- alarm = alm[0] * 1000 + alm[1] * 100 + alm[2] * 10 + alm[3];
- // Check whether the alarm condition is occured or not
- if ((alarm - timer) <= 0)
- { alm_out = false; // Make alarm out low.
- stop_counter = true ; // Stop the counter.
- // Drive the digit actually multiplexed.
- P0 = add[digit_counter];
- for (del=0; del<100; del++) ;
- // Increase multiplexer address to the next digit
- digit_counter++ ;
- // Did you diplay all digit ?
- if (digit_counter >= 4)
- // Start again.
- digit_counter = 0;
- // Pulse high P0.0, P0.1, P0.2 and P0.3
- P0 = P0 | 0x0f;
- // Blink on and off the dots when counting and alarm is on.
- void blink_dp ()
- { if (!set_flag && !stop_counter)
- { if (flag)
- dpn[1] = 0x80;
- else
- dpn[1] = 0x0;
- flag = !flag;
- // Counter. Counts from 00.00 to 59.59 min.sec.
- // The Timer interrupt is driven every 1 sec.
- void led_counter ()
- { if (!stop_counter) buf[3]++;
- if (buf[3] > 9)
- { buf[3] = 0;
- d3 = true;
- if (d3)
- { ++buf[2];
- d3 = false;
- if (buf[2] > 5)
- { buf[2] = 0;
- d2 = true;
- if (d2)
- { ++buf[1];
- d2 = false;
- if (buf[1] > 9)
- { buf[1] = 0;
- d1 = true;
- if (d1)
- { ++buf[0];
- d1 = false;
- if (buf[0] > 5)
- { buf[0] = 0;
- d0 = true;
- // Four keys Task manager.
- // Timer interrupt driven every 250ms
- void get_key ()
- { char valid_key;
- char delay = 127;
- key_mask = P0 & 0xf0;
- while (--delay >= 0) ;
- valid_key = P0 & 0xf0;
- if (key_mask != valid_key) valid_key = 0;
- while ((P0 & 0xf0) != (0 | (valid_key & 0x40))) ;
- switch (valid_key)
- { case 0x10: // Reset Timer
- buf[0] = 0;
- buf[1] = 0;
- buf[2] = 0;
- buf[3] = 0;
- alm_out = true;
- stop_counter = !stop_counter;
- break;
- case 0x20: // Set alarm
- ++set_count;
- if (set_count == 1)
- { // First time SET is pressed. Sets seconds
- set_flag = true;
- dpn[0] = 0; dpn[1] = 0; dpn[2] = 0x80; dpn[3] = 0x80;
- else if (set_count == 2)
- { // Second time SET is pressed. Set minutes
- set_flag = true;
- dpn[0] = 0x80; dpn[1] = 0x80; dpn[2] = 0; dpn[3] = 0;
- else if (set_count == 3)
- { // Latest time SET is pressed. Return to timer functions.
- set_flag = false;
- set_count = 0;
- dpn[0] = 0; dpn[1] = 0; dpn[2] = 0; dpn[3] = 0;
- un = 0;
- th = 0;
- break;
- case 0x40: // Set seconds/minutes
- { ++un;
- if (un > 9)
- { th++;
- un = 0;
- if(th > 5)
- th = 0;
- alm[3] = un;
- alm[2] = th;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
8051 Timer with LCD.zip
(54.22 KB, 下載次數(shù): 23)
2017-5-24 17:49 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
