查看: 6519|回復(fù): 4
四軸串級PID程序源碼 已用到項目中 很實用 分享給大家
ID:204159 發(fā)表于 2017-5-24 09:01 | 顯示全部樓層 |閱讀模式
這是我做的PID算法,已用到項目中,很實用,現(xiàn)在分享給大家。
四軸串級PID單片機源程序如下:
  1. #include "CONTROL.h"
  2. #include "IMU1.h"
  3. #include "moto.h"
  4. #include "RFdate.h"
  5. #include <math.h>
  6. extern T_RC_Data                         Rc_D;                //遙控通道數(shù)據(jù);
  7. extern u8 txbuf[4];         //發(fā)送緩沖
  8. extern u8 rxbuf[4];         //接收緩沖
  9. extern u16 test1[3]; //接收到NRf24L01數(shù)據(jù)
  10. extern S_INT16_XYZ ACC_F,GYRO_F;
  11. PID PID_ROL,PID_PIT,PID_YAW;
  12. extern S_INT16_XYZ        MPU6050_ACC_LAST,MPU6050_GYRO_LAST;
  13. int Motor_Ele=0;                                           //俯仰期望
  14. int Motor_Ail=0;                                           //橫滾期望
  15. //u8 ARMED = 0;
  16. //float rol_i=0,pit_i=0,yaw_p=0;
  17. float thr=0;
  18. S_FLOAT_XYZ EXP_ANGLE ,DIF_ANGLE;
  19. PID1 PID_Motor;
  20. /*********************************/
  21. float Pitch_i,Roll_i,Yaw_i;                                   //積分項
  22. float Pitch_old,Roll_old,Yaw_old;                 //角度保存
  23. float Pitch_d,Roll_d,Yaw_d;          //微分項
  24. float RC_Pitch,RC_Roll,RC_Yaw;                       //姿態(tài)角
  25. float Pitch_shell_out,Roll_shell_out,Yaw_shell_out;//外環(huán)總輸出
  26.         //外環(huán)PID參數(shù)
  27. float Pitch_shell_kp=280;//30 140
  28. float Pitch_shell_kd=0;//
  29. float Pitch_shell_ki=0;//
  30. /*********************************/
  31. float Roll_shell_kp=250;//30
  32. float Roll_shell_kd=0;//10
  33. float Roll_shell_ki=0;//0.08
  34. /*********************************/
  35. float Yaw_shell_kp=1.5;//10;//30
  36. float Yaw_shell_kd=0;//10
  37. float Yaw_shell_ki=0;//0.08;//0.08
  38. float Gyro_radian_old_x,Gyro_radian_old_y,Gyro_radian_old_z;//陀螺儀保存
  39. float pitch_core_kp_out,pitch_core_kd_out,Roll_core_kp_out,Roll_core_kd_out,Yaw_core_kp_out,Yaw_core_kd_out;//內(nèi)環(huán)單項輸出
  40. float Pitch_core_out,Roll_core_out,Yaw_core_out;//內(nèi)環(huán)總輸出
  41.
  42. //內(nèi)環(huán)PID參數(shù)
  43. //float Pitch_core_kp=0.040;
  44. //float Pitch_core_kd=0.008;////0.007;//0.07;
  45. float Pitch_core_kp=0.040;
  46. float Pitch_core_kd=0.002;////0.007;//0.07;
  47. float Roll_core_kp=0.040;//;
  48. float Roll_core_kd=0.002;////0.007;//06;//0.07;
  49. float Yaw_core_kp=0.046;//;
  50. float Yaw_core_kd=0.012;////0.007;//06;//0.07;
  51. int16_t moto1=0,moto2=0,moto3=0,moto4=0;
  52. float tempjd=0;
  53. void CONTROL(float rol, float pit, float yaw)
  54. {
  55.
  56.          RC_Pitch=(Rc_D.PITCH-1500)/20;
  57.
  58.         ////////////////////////外環(huán)角度環(huán)(PID)///////////////////////////////
  59.   Pitch_i+=(Q_ANGLE.Pitch-RC_Pitch);
  60. //-------------Pitch積分限幅----------------//
  61.   if(Pitch_i>300) Pitch_i=300;
  62.   else if(Pitch_i<-300) Pitch_i=-300;
  63. //-------------Pitch微分--------------------//
  64.   Pitch_d=Q_ANGLE.Pitch-Pitch_old;
  65. //-------------Pitch  PID-------------------//
  66.   Pitch_shell_out = Pitch_shell_kp*(Q_ANGLE.Pitch-RC_Pitch) + Pitch_shell_ki*Pitch_i + Pitch_shell_kd*Pitch_d;
  67. //角度保存
  68.   Pitch_old=Q_ANGLE.Pitch;
  69. /*********************************************************/
  70.
  71.         RC_Roll=(Rc_D.ROLL-1500)/20;
  72.         Roll_i+=(Q_ANGLE.Rool-RC_Roll);
  73. //-------------Roll積分限幅----------------//
  74.   if(Roll_i>300) Roll_i=300;
  75.   else if(Roll_i<-300) Roll_i=-300;
  76. //-------------Roll微分--------------------//
  77.   Roll_d=Q_ANGLE.Rool-Roll_old;
  78. //-------------Roll  PID-------------------//
  79.   Roll_shell_out  = Roll_shell_kp*(Q_ANGLE.Rool-RC_Roll) + Roll_shell_ki*Roll_i + Roll_shell_kd*Roll_d;
  80. //------------Roll角度保存------------------//
  81.   Roll_old=Q_ANGLE.Rool;
  82.
  83.
  84.         RC_Yaw=(Rc_D.YAW-1500)*10;
  85. //-------------Yaw微分--------------------//
  86.   Yaw_d=MPU6050_GYRO_LAST.Z-Yaw_old;
  87. //-------------Roll  PID-------------------//
  88.   Yaw_shell_out  = Yaw_shell_kp*(MPU6050_GYRO_LAST.Z-RC_Yaw) + Yaw_shell_ki*Yaw_i + Yaw_shell_kd*Yaw_d;
  89. //------------Roll角度保存------------------//
  90.   Yaw_old=MPU6050_GYRO_LAST.Z;
  91.
  92.
  93.         ////////////////////////內(nèi)環(huán)角速度環(huán)(PD)///////////////////////////////
  94.   pitch_core_kp_out = Pitch_core_kp * (Pitch_shell_out + MPU6050_GYRO_LAST.Y * 3.5);
  95.   pitch_core_kd_out = Pitch_core_kd * (MPU6050_GYRO_LAST.Y   - Gyro_radian_old_y);
  96.   Roll_core_kp_out  = Roll_core_kp  * (Roll_shell_out  + MPU6050_GYRO_LAST.X *3.5);
  97.   Roll_core_kd_out  = Roll_core_kd  * (MPU6050_GYRO_LAST.X   - Gyro_radian_old_x);
  98.   Yaw_core_kp_out  = Yaw_core_kp  * (Yaw_shell_out  + MPU6050_GYRO_LAST.Z * 1);
  99.   Yaw_core_kd_out  = Yaw_core_kd  * (MPU6050_GYRO_LAST.Z   - Gyro_radian_old_z);
  100.
  101.
  102.         Pitch_core_out = pitch_core_kp_out + pitch_core_kd_out;
  103.   Roll_core_out  = Roll_core_kp_out  + Roll_core_kd_out;
  104.   Yaw_core_out   = Yaw_core_kp_out   + Yaw_core_kd_out;
  105.   Gyro_radian_old_y = MPU6050_GYRO_LAST.X;
  106.   Gyro_radian_old_x = MPU6050_GYRO_LAST.Y;
  107.   Gyro_radian_old_z = MPU6050_GYRO_LAST.Z;   //儲存歷史值
  108.
  109. //--------------------將輸出值融合到四個電機--------------------------------//
  110.
  111.         if(Rc_D.THROTTLE>1020)
  112.         {
  113.   thr=Rc_D.THROTTLE- 1000;
  114. //                if(Rc_D.THROTTLE<=2000)
  115. //                {
  116. //  moto1=(int16_t)(thr  - Pitch_core_out);//- yaw);
  117. //        moto2=(int16_t)(thr  - Pitch_core_out);//+ yaw);
  118. //        moto3=(int16_t)(thr  + Pitch_core_out);// - yaw);
  119. //        moto4=(int16_t)(thr  + Pitch_core_out);//+ yaw);
  120.
  121. //  moto1=(int16_t)(thr  - Roll_core_out);//- yaw);
  122. //        moto2=(int16_t)(thr  + Roll_core_out);//+ yaw);
  123. //        moto3=(int16_t)(thr  + Roll_core_out);// - yaw);
  124. //        moto4=(int16_t)(thr  - Roll_core_out);//+ yaw);
  125. //  moto1=(int16_t)(thr  - Yaw_core_out);//- yaw);
  126. //        moto2=(int16_t)(thr  + Yaw_core_out);//+ yaw);
  127. //        moto3=(int16_t)(thr  - Yaw_core_out);// - yaw);
  128. //        moto4=(int16_t)(thr  + Yaw_core_out);//+ yaw);
  129.
  130. //moto1=(int16_t)(thr - Roll_core_out - Pitch_core_out);
  131. ……………………
  132. …………限于本文篇幅 余下代碼請從51黑下載附件…………
chuanPID.zip (1.75 KB, 下載次數(shù): 79)
ID:222327 發(fā)表于 2017-7-25 15:54 | 顯示全部樓層
謝謝樓主啦~
ID:235962 發(fā)表于 2017-9-28 09:33 | 顯示全部樓層
好東西,贊贊贊
ID:267230 發(fā)表于 2018-2-2 16:49 | 顯示全部樓層
好東西,謝樓主
