查看: 3754|回復(fù): 0
小車液晶實時顯示(尋跡或避障)源程序
ID:202915 發(fā)表于 2017-5-20 18:05 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
小車液晶顯示實時顯示
單片機(jī)源程序如下:
  1. //巍巍機(jī)器人小賣部提供//
  2. //歡迎您的使用//
  3. #include<reg52.h>
  4. #include <intrins.h>
  5. sbit    sce = P0^3;  //片選
  6. sbit    res = P0^4;  //復(fù)位,0復(fù)位
  7. sbit    dc  = P0^2;  //1寫數(shù)據(jù),0寫指令
  8. sbit    sdin = P0^1;  //數(shù)據(jù)
  9. sbit    sclk = P0^0;  //時鐘
  10. sbit    ledd = P0^5;  //背景燈
  11. sbit    m11 = P1^0;   //電機(jī)控制
  12. sbit    m12 = P1^1;  //電機(jī)控制
  13. sbit     m21 = P1^2;  //電機(jī)控制
  14. sbit     m22 = P1^3;  //電機(jī)控制
  15. sbit   RightSenser = P1^4;   //信號輸入端口
  16. sbit   LeftSenser = P1^5;   //信號輸入端口
  17. unsigned char code shuzi[]={
  18. /*--  文字:  1  --*/
  19. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  20. 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
  21. /*--  文字:  2  --*/
  22. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  23. 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
  24. /*--  文字:  3  --*/
  25. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  26. 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
  27.
  28. };
  29. unsigned char code maohao[]={
  30. /*--  文字:  :  --*/
  31. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  32. 0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00
  33. };
  34. unsigned char code jiaohao[]={
  35. /*--  文字:  -  --50*/
  36. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
  37. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x00
  38. };
  39. unsigned char code hanzi[]=
  40. {
  41. /*--  文字:  系  --*/
  42. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  43. 0x00,0x00,0x02,0x22,0xB2,0xAA,0x66,0x62,0x22,0x11,0x4D,0x81,0x01,0x01,0x00,0x00,
  44. 0x00,0x40,0x21,0x13,0x09,0x05,0x41,0x81,0x7F,0x01,0x05,0x09,0x13,0x62,0x00,0x00,
  45. /*--  文字:  統(tǒng)  --*/
  46. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  47. 0x20,0x30,0x2C,0xA3,0x60,0x10,0x84,0xC4,0xA4,0x9D,0x86,0x84,0xA4,0xC4,0x84,0x00,
  48. 0x20,0x22,0x23,0x12,0x12,0x92,0x40,0x30,0x0F,0x00,0x00,0x3F,0x40,0x41,0x70,0x00,
  49. /*--  文字:  已  --*/
  50. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  51. 0x00,0x00,0xE2,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x7E,0x00,0x00,0x00,0x00,
  52. 0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3C,0x10,0x00,
  53. /*--  文字:  啟  --*/
  54. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  55. 0x00,0x00,0x00,0xF8,0x48,0x48,0x48,0x49,0x4E,0x4A,0x48,0x48,0x48,0x78,0x00,0x00,
  56. 0x40,0x20,0x18,0x07,0x00,0x7E,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x7E,0x00,0x00,
  57. /*--  文字:  動  --*/
  58. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  59. 0x20,0x24,0x24,0xE4,0x24,0x24,0x24,0x20,0x10,0x10,0xFF,0x10,0x10,0xF0,0x00,0x00,
  60. 0x08,0x1C,0x0B,0x08,0x0C,0x05,0x4E,0x24,0x10,0x0C,0x03,0x20,0x40,0x3F,0x00,0x00,
  61. /*--  文字:  向  --*/
  62. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  63. 0x00,0x00,0xFC,0x04,0x04,0xE6,0x25,0x24,0x24,0x24,0xE4,0x04,0x04,0xFC,0x00,0x00,
  64. 0x00,0x00,0x7F,0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x0F,0x20,0x40,0x3F,0x00,0x00,
  65. /*--  文字:  右  --*/
  66. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  67. 0x08,0x08,0x08,0x88,0xC8,0x38,0x0F,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,
  68. 0x04,0x02,0x01,0x00,0x7F,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x7F,0x00,0x00,0x00,
  69. /*--  文字:  轉(zhuǎn)  --*/
  70. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  71. 0xC8,0xA8,0x9C,0xEB,0x88,0x88,0x88,0x40,0x48,0xF8,0x4F,0x48,0x48,0x48,0x40,0x00,
  72. 0x08,0x08,0x04,0xFF,0x04,0x04,0x00,0x02,0x0B,0x12,0x22,0xD2,0x0E,0x02,0x00,0x00,
  73. /*--  文字:  彎  --*/
  74. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  75. 0x02,0x42,0x62,0x5A,0x52,0x42,0x7E,0x43,0x42,0x7E,0x42,0x4A,0xD2,0x32,0x02,0x00,
  76. 0x00,0x00,0x00,0x0F,0x09,0x09,0x09,0x09,0x09,0x09,0x49,0x89,0x49,0x38,0x00,0x00,
  77. /*--  文字:  向  --*/
  78. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  79. 0x00,0x00,0xFC,0x04,0x04,0xE6,0x25,0x24,0x24,0x24,0xE4,0x04,0x04,0xFC,0x00,0x00,
  80. 0x00,0x00,0x7F,0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x0F,0x20,0x40,0x3F,0x00,0x00,
  81. /*--  文字:  左  --*/
  82. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  83. 0x08,0x08,0x08,0x08,0x08,0xC8,0x3F,0x0A,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,
  84. 0x40,0x20,0x50,0x4C,0x43,0x41,0x41,0x41,0x7F,0x41,0x41,0x41,0x41,0x40,0x40,0x00,
  85. /*--  文字:  轉(zhuǎn)  --*/
  86. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  87. 0xC8,0xA8,0x9C,0xEB,0x88,0x88,0x88,0x40,0x48,0xF8,0x4F,0x48,0x48,0x48,0x40,0x00,
  88. 0x08,0x08,0x04,0xFF,0x04,0x04,0x00,0x02,0x0B,0x12,0x22,0xD2,0x0E,0x02,0x00,0x00,
  89. /*--  文字:  彎  --*/
  90. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  91. 0x02,0x42,0x62,0x5A,0x52,0x42,0x7E,0x43,0x42,0x7E,0x42,0x4A,0xD2,0x32,0x02,0x00,
  92. 0x00,0x00,0x00,0x0F,0x09,0x09,0x09,0x09,0x09,0x09,0x49,0x89,0x49,0x38,0x00,0x00,
  93. /*--  文字:  全  --*/
  94. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  95. 0x00,0x80,0x40,0x60,0x50,0x48,0x44,0xC3,0x44,0x48,0x50,0x70,0x60,0x20,0x00,0x00,
  96. 0x00,0x40,0x40,0x44,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x46,0x44,0x60,0x40,0x00,
  97. /*--  文字:  速  --*/
  98. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  99. 0x40,0x42,0xCC,0x00,0x04,0xE4,0x24,0x24,0xFF,0x24,0x24,0x24,0xE4,0x04,0x00,0x00,
  100. 0x40,0x20,0x1F,0x20,0x48,0x49,0x45,0x43,0x7F,0x41,0x43,0x45,0x4D,0x40,0x40,0x00,
  101. /*--  文字:  前  --*/
  102. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  103. 0x08,0x08,0xE8,0xA8,0xA9,0xAE,0xEA,0x08,0x08,0xC8,0x0C,0x0B,0xEA,0x08,0x08,0x00,
  104. 0x00,0x00,0x7F,0x04,0x24,0x44,0x3F,0x00,0x00,0x1F,0x40,0x80,0x7F,0x00,0x00,0x00,
  105. /*--  文字:  進(jìn)  --*/
  106. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  107. 0x80,0x82,0x9C,0x88,0x00,0x88,0x88,0xFF,0x88,0x88,0x88,0xFF,0x88,0x88,0x80,0x00,
  108. 0x00,0x40,0x20,0x1F,0x20,0x50,0x4C,0x43,0x40,0x40,0x40,0x5F,0x40,0x40,0x40,0x00,
  109. /*--  文字:  巍  --*/
  110. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  111. 0x40,0x50,0xD6,0xF4,0xD4,0x54,0x44,0xF7,0x5C,0x54,0xF4,0x54,0x54,0xF6,0x00,0x00,
  112. 0x84,0x4D,0x36,0x15,0x2C,0xC5,0x00,0x83,0x62,0x1E,0x03,0x7E,0x52,0x5F,0x70,0x00,
  113. /*--  文字:  巍  --*/
  114. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  115. 0x40,0x50,0xD6,0xF4,0xD4,0x54,0x44,0xF7,0x5C,0x54,0xF4,0x54,0x54,0xF6,0x00,0x00,
  116. 0x84,0x4D,0x36,0x15,0x2C,0xC5,0x00,0x83,0x62,0x1E,0x03,0x7E,0x52,0x5F,0x70,0x00,
  117. /*--  文字:  機(jī)  --*/
  118. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  119. 0x08,0x08,0xC8,0xFF,0x48,0x88,0x08,0x00,0xFE,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,
  120. 0x04,0x03,0x00,0xFF,0x00,0x41,0x30,0x0C,0x03,0x00,0x00,0x00,0x3F,0x40,0x78,0x00,
  121. /*--  文字:  器  --*/
  122. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  123. 0x40,0x40,0x4F,0x49,0x49,0xC9,0xCF,0x70,0xC0,0xCF,0x49,0x59,0x69,0x4F,0x00,0x00,
  124. 0x02,0x02,0x7E,0x45,0x45,0x44,0x7C,0x00,0x7C,0x44,0x45,0x45,0x7E,0x06,0x02,0x00,
  125. /*--  文字:  人  --*/
  126. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  127. 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0xC2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  128. 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x01,0x06,0x0C,0x18,0x30,0x60,0x20,0x00,
  129. /*--  文字:  歡  --*/
  130. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  131. 0x14,0x24,0x44,0x84,0x64,0x1C,0x20,0x18,0x0F,0xE8,0x08,0x08,0x28,0x18,0x08,0x00,
  132. 0x20,0x10,0x4C,0x43,0x43,0x2C,0x20,0x10,0x0C,0x03,0x06,0x18,0x30,0x60,0x20,0x00,
  133. /*--  文字:  迎  --*/
  134. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  135. 0x40,0x41,0xCE,0x04,0x00,0xFC,0x04,0x02,0x02,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
  136. 0x40,0x20,0x1F,0x20,0x40,0x47,0x42,0x41,0x40,0x5F,0x40,0x42,0x44,0x43,0x40,0x00,
  137. /*--  文字:  您  --*/
  138. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  139. 0x80,0x40,0x30,0xFC,0x03,0x90,0x68,0x06,0x04,0xF4,0x04,0x24,0x44,0x8C,0x04,0x00,
  140. 0x00,0x20,0x38,0x03,0x38,0x40,0x40,0x49,0x52,0x41,0x40,0x70,0x00,0x09,0x30,0x00,
  141. /*--  文字:  的  --*/
  142. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  143. 0x00,0xF8,0x8C,0x8B,0x88,0xF8,0x40,0x30,0x8F,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,
  144. 0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x03,0x26,0x40,0x20,0x1F,0x00,0x00,
  145. /*--  文字:  使  --*/
  146. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  147. 0x40,0x20,0xF0,0x1C,0x07,0xF2,0x94,0x94,0x94,0xFF,0x94,0x94,0x94,0xF4,0x04,0x00,
  148. 0x00,0x00,0x7F,0x00,0x40,0x41,0x22,0x14,0x0C,0x13,0x10,0x30,0x20,0x61,0x20,0x00,
  149. /*--  文字:  用  --*/
  150. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  151. 0x00,0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,
  152. 0x80,0x40,0x30,0x0F,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x42,0x82,0x7F,0x00,0x00,
  153. };
  154. void delay_1ms(void)//1ms延時函數(shù)
  155. {
  156.         unsigned int i;
  157.         for (i=0;i<500;i++)          ;
  158. ;
  159. }
  160. /*--------------------------------------------
  161. LCD_write_byte: 使用SPI接口寫數(shù)據(jù)到LCD
  162. 輸入?yún)?shù):dt:寫入的數(shù)據(jù);
  163. command :寫數(shù)據(jù)/命令選擇;
  164. 編寫日期:20080918
  165. ----------------------------------------------*/
  166. void LCD_write_byte(unsigned char dt, unsigned char command)
  167. {
  168.         unsigned char i;
  169.         sce=0;
  170.         dc=command;
  171.         for(i=0;i<8;i++)
  172.         {
  173.                 if(dt&0x80)
  174.                         sdin=1;
  175.                 else
  176.                         sdin=0;
  177.                 dt=dt<<1;
  178.                 sclk=0;
  179.                 sclk=1;
  180.         }
  181.         dc=1;
  182.         sce=1;
  183.         sdin=1;
  184. }
  185. /*---------------------------------------
  186. LCD_init: 3310LCD初始化
  187. 編寫日期:20080918
  188. -----------------------------------------  */
  189. void LCD_init(void)
  190. {
  191.         res=0;
  192.           delay_1ms();
  193.           res=1;
  194.         LCD_write_byte(0x21,0);//初始化Lcd,功能設(shè)定使用擴(kuò)充指令
  195.         LCD_write_byte(0xd0,0);//設(shè)定液晶偏置電壓
  196.         LCD_write_byte(0x20,0);//使用基本指令
  197.         LCD_write_byte(0x0C,0);//設(shè)定顯示模式,正常顯示
  198. }
  199. /*-------------------------------------------
  200. LCD_set_XY: 設(shè)置LCD坐標(biāo)函數(shù)
  201. 輸入?yún)?shù):X:0-83  Y:0-5
  202. 編寫日期:20080918
  203. ---------------------------------------------*/
  204. void LCD_set_XY(unsigned char X, unsigned char Y)
  205. {
  206.         LCD_write_byte(0x40 | Y, 0);// column
  207.         LCD_write_byte(0x80 | X, 0);// row
  208. }
  209. /*------------------------------------------
  210. LCD_clear: LCD清屏函數(shù)
  211. 編寫日期:20080918
  212. --------------------------------------------*/
  213. void LCD_clear(void)
  214. {
  215.         unsigned char t;
  216.         unsigned char k;
  217.         LCD_set_XY(0,0);
  218.         for(t=0;t<6;t++)
  219.         {
  220.                 for(k=0;k<84;k++)
  221.                 {
  222.                         LCD_write_byte(0x00,1);
  223.
  224.                 }
  225.         }
  226. }
  227. /*---------------------------------------------
  228. LCD_write_shu: 顯示8(寬)*16(高)點陣列數(shù)字字母符號等半角類
  229. 輸入?yún)?shù):c:顯示的字符;
  230. 編寫日期:20080918
  231. -----------------------------------------------*/
  232. void LCD_write_shu(unsigned char row, unsigned char page,unsigned char c) //row:列 page:頁 dd:字符
  233. {
  234.         unsigned char i;
  235.
  236.         LCD_set_XY(row*8, page);// 列,頁
  237.         for(i=0; i<8;i++)
  238.         {
  239.                 LCD_write_byte(shuzi[c*16+i],1);
  240.         }
  241.
  242.     LCD_set_XY(row*8, page+1);// 列,頁
  243.         for(i=8; i<16;i++)
  244.         {
  245.                 LCD_write_byte(shuzi[c*16+i],1);
  246.         }
  247. }
  248. /*---------------------------------------------
  249. LCD_write_hanzi: 顯示16(寬)*16(高)點陣列漢字等半角類
  250. 輸入?yún)?shù):c:顯示的字符;
  251. 編寫日期:20080918
  252. -----------------------------------------------*/
  253. void LCD_write_hanzi(unsigned char row, unsigned char page,unsigned char c) //row:列 page:頁 dd:字符
  254. {
  255.         unsigned char i;
  256.
  257.         LCD_set_XY(row*8, page);// 列,頁
  258.         for(i=0; i<16;i++)
  259.         {
  260.                 LCD_write_byte(hanzi[c*32+i],1);
  261.         }
  262.
  263.     LCD_set_XY(row*8, page+1);// 列,頁
  264.         for(i=16; i<32;i++)
  265.         {
  266.                 LCD_write_byte(hanzi[c*32+i],1);
  267.         }
  268. }
  269. main()
  270. {
  271.     unsigned int k;
  272.     for(k=0;k<25000;k++);
  273.         res=0;
  274.         ledd=0;
  275.         res=1;
  276.           LCD_init();  //初始化LCD模塊
  277.         LCD_clear(); //清屏幕
  278.         LCD_write_hanzi(0,0,17);  //巍
  279.         LCD_write_hanzi(2,0,18);  //巍
  280.         LCD_write_hanzi(4,0,19);  //機(jī)
  281.         LCD_write_hanzi(6,0,20);  //器
  282.         LCD_write_hanzi(8,0,21);  //人
  283.         LCD_write_hanzi(0,2,22);  //歡
  284.         LCD_write_hanzi(2,2,23);  //迎
  285.         LCD_write_hanzi(4,2,24);  //您
  286.         LCD_write_hanzi(6,2,25);  //的
  287.         LCD_write_hanzi(8,2,26);  //使
  288.         LCD_write_hanzi(0,4,27);  //用
  289.         for(k=0;k<25000;k++);
  290.         for(k=0;k<25000;k++);
  291.         for(k=0;k<25000;k++);
  292.         for(k=0;k<25000;k++);
  293.         for(k=0;k<25000;k++);
  294.         for(k=0;k<25000;k++);
  295.     LCD_clear(); //清屏幕
  296.         LCD_write_hanzi(0,0,0);  //系
  297.         LCD_write_hanzi(2,0,1);  //統(tǒng)
  298.         LCD_write_hanzi(4,0,3);  //起
  299.         LCD_write_hanzi(6,0,4);  //動
  300.         for(k=0;k<25000;k++);
  301.     for(k=0;k<25000;k++);
  302.         for(k=0;k<25000;k++);
  303.         for(k=0;k<25000;k++);
  304.     for(k=0;k<25000;k++);
  305.         LCD_clear(); //清屏幕
  306.         LCD_write_shu(4,2,2);  //3
  307.         for(k=0;k<25000;k++);
  308.     for(k=0;k<25000;k++);
  309.         for(k=0;k<25000;k++);
  310.         for(k=0;k<25000;k++);
  311.     for(k=0;k<25000;k++);
  312.         LCD_clear(); //清屏幕
  313.         LCD_write_shu(4,2,1);  //2
  314.         for(k=0;k<25000;k++);
  315.     for(k=0;k<25000;k++);
  316.         for(k=0;k<25000;k++);
  317.     for(k=0;k<25000;k++);
  318.     for(k=0;k<25000;k++);
  319.         LCD_clear(); //清屏幕
  320.         LCD_write_shu(4,2,0);  //1
  321.         for(k=0;k<25000;k++);
  322.     for(k=0;k<25000;k++);
  323.         for(k=0;k<25000;k++);
  324.         while(1)
  325.         {
  326.         for(k=0;k<25000;k++);
  327.         for(k=0;k<25000;k++);
  328.         for(k=0;k<25000;k++);
  329. m11 = 1;
  330. m12 = 1;
  331. m21 = 1;
  332. m22 = 1;
  333.
  334.         if((!RightSenser) && LeftSenser)   // 如果右邊假,左邊真
  335.                       {
  336.
  337.                           m11 = 0;
  338.                  m12 = 1;
  339.                     LCD_clear(); //清屏幕
  340.         LCD_write_hanzi(0,0,5);  //向
  341.         LCD_write_hanzi(2,0,6);  //右
  342.         LCD_write_hanzi(4,0,7);  //轉(zhuǎn)
  343.         LCD_write_hanzi(6,0,8);  //彎
  344.                 for (k=0; k<100; k++);   // 延時
  345.                     }
  346.            if(RightSenser && (!LeftSenser))  // 如果左邊假,右邊真
  347.                      {
  348.                  m21 = 0;
  349. ……………………
  350. …………限于本文篇幅 余下代碼請從51黑下載附件…………
小車液晶實時顯示(尋跡或避障).zip (671.27 KB, 下載次數(shù): 12)
