- //四位數(shù)碼管電子鐘
- //應(yīng)用程序 C
- //neo
- //V1.1
- //MCS-51 12MHZ C語言
- //接口說明: DS1302、DS18B20
- #include <reg52.h>
- #include <intrins.h>
- #define uint8 unsigned char
- #define uchar unsigned char
- #define uint unsigned int
- uchar Disp_Buff[4];
- char SB=4; // clock set time bit
- //bit Set_Flag; // set time flag
- bit T=0; // display Temperature and Time flag
- bit TT=0; // 10S Auto change display Temperature and Time flag
- //#define T0_H 0xf0 // 4ms
- //#define T0_L 0x60
- #define T0_H 0xf5 // 2666us
- #define T0_L 0x96
- #define ST 20
- #define T1_H 0xb1 //20ms
- #define T1_L 0xe0
- #define NumLed_Bit P2
- #define Disp P1
- #define Key P3
- #define Key1 1
- #define Key2 2
- #define Key3 3
- #define Key4 4
- #define Key_NULL 0
- sbit Beep=P0^7;
- void Play(uchar t);
- sbit Red_Led=P3^7;
- // Driver DS1302
- sbit RST=P0^0;
- sbit IO=P0^1;
- sbit SCLK=P0^2;
- #define second_write 0x80
- #define minute_write 0x82
- #define hour_write 0x84
- #define week_write 0x8a
- #define day_write 0x86
- #define month_write 0x88
- #define year_write 0x8c
- #define second_read 0x81
- #define minute_read 0x83
- #define hour_read 0x85
- #define week_read 0x8b
- #define day_read 0x87
- #define month_read 0x89
- #define year_read 0x8d
- #define sclk_high SCLK=1;
- #define sclk_low SCLK=0;
- #define io_high IO=1;
- #define io_low IO=0;
- #define io_read IO
- #define rst_high RST=1;
- #define rst_low RST=0;
- struct {uint8 second;
- uint8 minute;
- uint8 hour;
- uint8 day;
- uint8 week;
- uint8 month;
- uint8 year; } current_time;
- static void ds1302write(uint8 content)
- uint8 i;
- for(i=8;i>0;i--) { if(content&0x01) io_high
- else io_low
- content>>=1; sclk_high sclk_low
- static uint8 ds1302read(void)
- uint8 i,readvalue;
- io_high
- for(i=8;i>0;i--) { readvalue>>=1; if(io_read) readvalue|=0x80;
- else readvalue&=0x7f;
- sclk_high sclk_low }
- return readvalue;
- void ds1302write_byte (uint8 address,uint8 content)
- rst_low sclk_low rst_high ds1302write(address);
- ds1302write(content); rst_low sclk_high
- uint8 ds1302read_byte(uint8 address)
- uint8 readvalue;
- ds1302write(address);
- readvalue=ds1302read();
- rst_low sclk_high
- return readvalue;
- void Clock_Init(void)
- uchar R;
- if(ds1302read_byte(0xc1)!=0xf0) {
- ds1302write_byte(0x8e,0x00);
- ds1302write_byte(year_write,0x11);
- ds1302write_byte(week_write,0x06);
- ds1302write_byte(month_write,0x04);
- ds1302write_byte(day_write,0x09);
- ds1302write_byte(hour_write,0x23);
- ds1302write_byte(minute_write,0x59);
- ds1302write_byte(second_write,0x30);
- ds1302write_byte(0x90,0xa5);
- ds1302write_byte(0xc0,0xf0);
- for (R=0;R<10;R+=2)
- ds1302write_byte(0xc2+R,0);
- ds1302write_byte(0x8e,0x80);
- void Clock_Updata(void)
- current_time.second=ds1302read_byte(second_read);
- current_time.minute=ds1302read_byte(minute_read);
- current_time.hour= ds1302read_byte(hour_read);
- current_time.day= ds1302read_byte(day_read);
- current_time.month= ds1302read_byte(month_read);
- current_time.week= ds1302read_byte(week_read);
- current_time.year= ds1302read_byte(year_read);
- void Write_Time(void)
- ds1302write_byte(0x82,((Disp_Buff[2]<<4)|Disp_Buff[3]));
- ds1302write_byte(0x84,((Disp_Buff[0]<<4)|Disp_Buff[1]));
- void Write_Alarm(void)
- ds1302write_byte(0xca,((Disp_Buff[2]<<4)|Disp_Buff[3])); // alarm minute
- ds1302write_byte(0xc8,((Disp_Buff[0]<<4)|Disp_Buff[1])); // alarm hour
- ds1302write_byte(0xc6,1);
- void Alarm(void)
- if(ds1302read_byte(0xc7)==1&&
- current_time.minute==ds1302read_byte(0xcb)&&
- current_time.hour==ds1302read_byte(0xc9) )
- ds1302write_byte(0xc6,0);
- Play(3);
- // DS18B20 driver
- sbit io_DQ=P0^6;
- #define DQ_HIGH io_DQ=1;
- #define DQ_LOW io_DQ=0;
- #define DQ_READ io_DQ
- unsigned char Temperature[4];
- void Delay_10Us (unsigned int Count)
- while(--Count)
- _nop_();
- unsigned char Ds18b20_Init(void)
- unsigned char Flag;
- DQ_HIGH Delay_10Us(3);
- DQ_LOW Delay_10Us(80);
- DQ_HIGH Delay_10Us(15);
- Flag=DQ_READ;
- return Flag;
- void Write_f(unsigned char cmd)
- unsigned char i;
- EA=0;
- DQ_LOW
- DQ_READ=cmd&0x01;
- Delay_10Us(5);
- DQ_HIGH
- EA=1;
- cmd>>=1;
- unsigned char Read_f(void)
- unsigned char Read_Value,i;
- for (i=8;i>0;i--) {
- EA=0;
- DQ_LOW
- Read_Value>>=1;
- DQ_HIGH
- if (DQ_READ==1) Read_Value|=0x80;
- EA=1;
- Delay_10Us(3);
- return Read_Value;
- unsigned int Read_Temp(void)
- unsigned char Temp_H, Temp_L;
- unsigned int Return_Temp;
- EA=0; // close interrupt;
- Ds18b20_Init();
- Write_f(0xcc);
- Write_f(0x44);
- Ds18b20_Init();
- Write_f(0xcc);
- Write_f(0xbe);
- Temp_L=Read_f();
- Temp_H=Read_f();
- EA=1;
- Return_Temp=Temp_H;
- Return_Temp<<=8;
- Return_Temp|=Temp_L;
- return Return_Temp;
- void Temperature_Update(void)
- unsigned char T_flag=0;
- unsigned int Temp_Dat;
- float Temp;
- Temp_Dat=Read_Temp();
- if(Temp_Dat&0xf000) {T_flag=1; Temp_Dat=~Temp_Dat+1; }
- Temp=Temp_Dat*0.0625;
- Temp_Dat=Temp*10;
- Temperature[0]=T_flag;
- Temperature[1]=Temp_Dat/100;
- Temperature[2]=Temp_Dat%100/10;
- Temperature[3]=Temp_Dat%10;
- void Timer0_Init(void)
- TMOD|=0x01;
- TH0=T0_H;
- TL0=T0_L;
- EA=1;
- ET0=1;
- TR0=1;
- bit T_10S,T_1S;
- bit S; // shining flag
- bit pp=1; // open or close :
- unsigned int ms1,ms2,ms3;
- uchar Bit;// Number Led select
- uchar code Disp_NumCode[]={0x3F,0x06,0x5B,0x4F,
- 0x66,0x6D,0x7D,0x07,
- 0x7F,0x6F, // dp-a P07-P00 0-9,
- 0x39, //c 10
- 0x37,0x79,0x3F, //NEO 11-13
- 0x6D,0x39,0x77, // S,C,A 14-16
- 0x5E,0x73,0x71, // d,p,F 17-19
- 0x00, // " " 20
- 0x38,0x08 // L 21 _ 22
- uchar code Open_Logo[]={11,12,13,20};
- uchar code S_C[]={14,22,15,20};
- uchar code S_A[]={14,22,16,20};
- uchar code d_p[]={17,22,18,20};
- uchar code BELL[]={17,12,21,21};
- uchar code ON[]= {20,13,11,20};
- uchar code OFF[]={20,13,19,19};
- void Put_In(uchar *P)
- uchar a;
- for (a=0;a<4;a++)
- Disp_Buff[a]=P[a];
- void Timer0_Isr(void) interrupt 1
- TH0=T0_H; //4ms
- TL0=T0_L;
- Disp=0x00;
- switch(Bit) {
- case 0 : NumLed_Bit=0xfe; break;
- case 1 : NumLed_Bit=0xfd; break;
- case 2 : NumLed_Bit=0xfb; break;
- case 3 : NumLed_Bit=0xf7; break;
- case 4 : NumLed_Bit=0xf3; break; // display :
- default : break;
- switch(Bit) {
- case 0 : {
- if(SB==0)
- if (S) NumLed_Bit=0xfe;
- if(S==0) NumLed_Bit=0x00;
- else NumLed_Bit=0xfe;
- }break;
- case 1 : {
- if(SB==1)
- if (S) NumLed_Bit=0xfd;
- else NumLed_Bit=0xfd;
- }break;
- case 2 : {
- if(SB==2)
- if (S) NumLed_Bit=0xfb;
- else NumLed_Bit=0xfb;
- } break;
- case 3 : {
- if(SB==3)
- if (S) NumLed_Bit=0xf7;
- else NumLed_Bit=0xf7;
- } break;
- case 4 : {
- if(T==0||TT==0) NumLed_Bit=0xf3; // display :
- if( T || TT ) NumLed_Bit=0xfb; // display .
- } break;
- default : break;
- if(Bit<4) {
- Disp=Disp_NumCode[Disp_Buff[Bit]];
- else
- if(pp==1)
- if (T==0||TT==0)
- if(current_time.second%2) Disp=0x80;
- else Disp=0x00;
- if( T || TT ) Disp=0x80;
- else Disp=0x00; // close :
- if(++Bit>4) Bit=0;
- void Timer1_Init(void)
- TMOD|=0x10;
- TH1=T1_H; //20ms
- TL1=T1_L;
- EA=1;
- ET1=1;
- TR1=1;
- uchar Key_Time;
- void Timer1_Isr(void) interrupt 3
- TH1=T1_H;
- TL1=T1_L;
- if(Key!=0xff) Key_Time++;
- if(++ms1>ST) { ms1=0; S=~S; } //when set time Shining bit
- if(++ms2>=50) { ms2=0; T_1S=1; }
- if(++ms3>500) { ms3=0; T_10S=1;}
- void DelayM(unsigned int a){//-延時函數(shù) 1MS/次
- unsigned char i;
- while(a--)
- for(i = 0; i < 125; i++)
- } //i 從0加到125,CPU大概就耗時1毫秒
- uchar i;
- switch(t) {
- case 1:
- Beep=0;
- DelayM(100);
- } break;
- case 2:
- Beep=0;
- DelayM(400);
- Beep=1;
- DelayM(500);
- Beep=0;
- DelayM(100);
- } break;
- case 3:
- for(i=0;i<20;i++)
- Beep=0;
- DelayM(100);
- Beep=1;
- DelayM(100);
- Beep=0;
- DelayM(100);
- Beep=1;
- DelayM(500);
- } break;
- default : break;
- Beep=1;
- uchar Key_Scan(void)
- static bit Key_Down;
- static uchar K;
- uchar K_Value=0;
- if(Key_Time>250) Key_Time=3;
- if(Key_Time>=3&&Key_Down==0)
- Key_Time=0;
- Key_Down=1;
- switch(Key)
- case 0xfe : K=1; break;
- case 0xfd : K=2; break;
- case 0xfb : K=3; break;
- case 0xf7 : K=4; break;
- default : K=0; break;
- if(Key==0xFF&&Key_Down==1)
- Key_Down=0;
- K_Value=K;
- Play(1);
- return K_Value;
- void Disp_Time(void)
- Disp_Buff[3]=current_time.minute%16;
- Disp_Buff[2]=current_time.minute/16;
- Disp_Buff[1]=current_time.hour%16;
- Disp_Buff[0]=current_time.hour/16;
- void Disp_Temperature_3bit(void)
- Disp_Buff[3]=20;
- Disp_Buff[2]=10; // display 'c'
- Disp_Buff[1]=Temperature[2];
- Disp_Buff[0]=Temperature[1];
- void Disp_Temperature_4bit(void)
- Disp_Buff[3]=Temperature[3];
- Disp_Buff[2]=10; // display c
- uchar Select_M=4;
- void MENU (void)
- uchar K;
- char Menu=0;
- pp=0; // close ':'
- while(Menu!=4)
- K=Key_Scan();
- switch (Menu)
- case 0 : { Put_In(S_C); } break;
- case 1 : { Put_In(S_A); } break;
- case 2 : { Put_In(d_p); } break;
- case 3 : { Put_In(BELL);}
- default : break;
- if(K==Key3) Menu=4;
- if(K==Key2) Menu=(Menu+1)%4;
- if(K==Key1) {
- Select_M=Menu; Menu=4;
- pp=1;
- void Set_Time(void)
- bit Set_Flag=1; // set time flag
- uchar K;
- SB=0;
- Disp_Time();
- T=0;
- TT=0;
- while(Set_Flag)
- K=Key_Scan();
- if(K==Key1)
- switch(SB)
- case 0 : {
- if(Disp_Buff[1]>3)
- Disp_Buff[0]=(Disp_Buff[0]+1)%2;
- else
- Disp_Buff[0]=(Disp_Buff[0]+1)%3;
- } break;
- case 1 : {
- if(Disp_Buff[0]==2)
- Disp_Buff[1]=(Disp_Buff[1]+1)%4;
- else
- Disp_Buff[1]=(Disp_Buff[1]+1)%10;
- } break;
- case 2 : {
- Disp_Buff[2]=(Disp_Buff[2]+1)%6;
- } break;
- case 3 : {
- Disp_Buff[3]=(Disp_Buff[3]+1)%10;
- } break;
- default : break;
- if(K==Key2) { SB= (SB+1)%4; }
- if(K==Key3) { Set_Flag=0; SB=4; }
- if(K==Key4) {
- Set_Flag=0; SB=4; Write_Time(); T_10S=0;
- void Write_Ds1302Ram(uchar address,uchar dat)
- ds1302write_byte(address,dat);
- uchar dp; // display modle select bit
- void Set_Dp(void)
- bit dp_Set=1;
- uchar K;
- //dp=ds1302read_byte(0xc3);
- while(dp_Set)
- K=Key_Scan();
- switch(dp)
- case 1 : Put_In(ON); break;
- case 0 : Put_In(OFF); break;
- default : break;
- if(K==Key3) dp_Set=0;
- if(K==Key2) dp=(dp+1)%2;
- if(K==Key1) { dp_Set=0; Write_Ds1302Ram(0xc2,dp); T=0; TT=0; T_10S=0; }
- pp=1;
- uchar Bell_State;
- void Set_Bell(void)
- bit Bell_Set=1;
- uchar K;
- pp=0;
- //Bell_State=ds1302read_byte(0xc5);
- while(Bell_Set)
- K=Key_Scan();
- switch(Bell_State)
- default : break;
- if(K==Key3) Bell_Set=0;
- if(K==Key2) Bell_State=(Bell_State+1)%2;
- if(K==Key1) {
- Write_Ds1302Ram(0xc4,Bell_State); Bell_Set=0; T=0; TT=0; T_10S=0;
- pp=1;
- void Set_Alarm(void)
- static bit First_Alarm_Set=0;
- uchar K;
- SB=0;
- T=0;
- TT=0;
- if(First_Alarm_Set)
- Disp_Buff[0]=ds1302read_byte(0xc9)/16; //alarm hour
- Disp_Buff[1]=ds1302read_byte(0xc9)%16;
- Disp_Buff[2]=ds1302read_byte(0xcb)/16; //alarm minute
- Disp_Buff[3]=ds1302read_byte(0xcb)%16;
- else Disp_Time();
- while(Set_Flag)
- K=Key_Scan();
- if(K==Key1)
- switch(SB)
- case 0 : {
- else
- } break;
- case 1 : {
- else
- } break;
- case 2 : {
- } break;
- case 3 : {
- } break;
- default : break;
- if(K==Key4) {
- Set_Flag=0; SB=4;
- First_Alarm_Set=1;
- Write_Alarm(); T_10S=0;
- void Ds1302Ram_Init(void)
- uchar i;
- //for(i=0xc3;i<0xc7;i+=2)
- i=ds1302read_byte(0xc3);
- if(i!=0||i!=1)
- Write_Ds1302Ram(0xc2,0);
- i=ds1302read_byte(0xc5);
- if(i!=0||i!=1)
- Write_Ds1302Ram(0xc4,0);
- void main()
- uchar K;
- Key=0xff;
- Timer0_Init();
- Timer1_Init();
- Clock_Init();
- //Ds1302Ram_Init();
- Put_In(Open_Logo);
- Play(1);
- DelayM(3000);
- dp=ds1302read_byte(0xc3);
- Bell_State=ds1302read_byte(0xc5);
- Clock_Updata();
- while(1)
- //if(T_1S) { T_1S=0; Clock_Updata(); Temperature_Update(); }
- Clock_Updata();
- if(current_time.minute==0&&
- current_time.second==0&&
- Bell_State==1)
- { DelayM(1000); Play(2); }
- K=Key_Scan();
- if(K==4) MENU();
- if(K==1&&dp==0) T=~T;
- switch (Select_M)
- case 0 : { Set_Time(); Select_M=4; } break;
- case 1 : { Set_Alarm(); Select_M=4; } break;
- case 2 : { Set_Dp(); Select_M=4; } break;
- case 3 : { Set_Bell(); Select_M=4; };break;
- default : break;
- if(T_10S==1&&dp) { TT=~TT; T_10S=0; }
- if(TT==0&&dp)
- Disp_Time();
- if(TT&&dp)
- Temperature_Update();
- Disp_Temperature_3bit();
- if(T==0&&dp==0)
- Disp_Time();
- if(T&&dp==0)
- Alarm();
復(fù)制代碼 |
