查看: 4520|回復: 0
LCD1602在51單片機中的簡單程序應用
ID:202738 發表于 2017-5-20 00:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
LCD1602基本顯示 12345
#include <reg52.h>
typedef unsigned char uchar;
typedef unsigned int uint;
sbit EN = P3^4;//使能信號
sbit RS = P3^5;//數據/命令選擇端
sbit RW = P3^6;//讀/寫選擇端
//判斷液晶忙,如果忙則等待
void Read_Busy()
        uchar busy;
        P0 = 0xff;//復位P0
        RS = 0;
        RW = 1;
        do
                EN = 1;//         RS = 0;        RW = 1;EN = 1;讀狀態,輸出P0=D0~D7狀態字
                busy = P0;//P0是啥?busy=0x80才跳出來
                EN = 0;
        }while(busy & 0x80);
//寫LCD1602命令一個字節
void Write_Cmd(uchar cmd)
        Read_Busy();//判斷忙
        RS = 0;
        RW = 0;
        P0 = cmd;//cmd是變量
        EN = 1;//這是高脈沖?**寫指令無輸出
        EN = 0;
//寫一個字節數據
void Write_Dat(uchar dat)
        Read_Busy();
        RS = 1;
        RW = 0;
        P0 = dat;
        EN = 1;        //寫數據,高脈沖。。。D0~D7=P0
        EN = 0;
        Write_Cmd(0x38);//設置16*2顯示
        Write_Cmd(0x0f);//開顯示 顯示光標,光標閃爍
        Write_Cmd(0x01);//清屏
        Write_Cmd(0x06);//地址指針移位命令
        Write_Cmd(0x80 | 0x06);//顯示地址
        //80H按位與地址碼,這里是從第六位之后顯示
        Write_Dat(1 + '0');
        Write_Dat(2 + '0');
        Write_Dat(3 + '0');
        Write_Dat(4 + '0');
        Write_Dat(5 + '0');
        while(1);
