- 讀取卡號(ID),以及Block1的前8個字節的內容(Str),如兩者都符合就觸發繼電器(Relay)。
- Block1的前8個字節的內容(Str),可以通過《RFID522_Serial_write_block.ino》寫入。
- * 文 件 名:RFID522_READ_Comp_ID_Str_Relay.ino
- * 修 改 者:mc.six
- * 功能描述:Mifare1 尋卡→防沖突→選卡→讀卡→觸發繼電器
- // the sensor communicates using SPI, so include the library:
- #include <SPI.h>
- #define uchar unsigned char
- #define uint unsigned int
- //數組最大長度
- #define MAX_LEN 16
- //set the pin
- const int chipSelectPin = 10;//如果控制板為UNO,328,168
- //const int chipSelectPin = 53; //如果控制板為mega 2560,1280
- const int NRSTPD = 9;
- //MF522命令字
- #define PCD_IDLE 0x00 //NO action;取消當前命令
- #define PCD_AUTHENT 0x0E //驗證密鑰
- #define PCD_RECEIVE 0x08 //接收數據
- #define PCD_TRANSMIT 0x04 //發送數據
- #define PCD_TRANSCEIVE 0x0C //發送并接收數據
- #define PCD_RESETPHASE 0x0F //復位
- #define PCD_CALCCRC 0x03 //CRC計算
- //Mifare_One卡片命令字
- #define PICC_REQIDL 0x26 //尋天線區內未進入休眠狀態
- #define PICC_REQALL 0x52 //尋天線區內全部卡
- #define PICC_ANTICOLL 0x93 //防沖撞
- #define PICC_SElECTTAG 0x93 //選卡
- #define PICC_AUTHENT1A 0x60 //驗證A密鑰
- #define PICC_AUTHENT1B 0x61 //驗證B密鑰
- #define PICC_READ 0x30 //讀塊
- #define PICC_WRITE 0xA0 //寫塊
- #define PICC_DECREMENT 0xC0
- #define PICC_INCREMENT 0xC1
- #define PICC_RESTORE 0xC2 //調塊數據到緩沖區
- #define PICC_TRANSFER 0xB0 //保存緩沖區中數據
- #define PICC_HALT 0x50 //休眠
- //和MF522通訊時返回的錯誤代碼
- #define MI_OK 0
- #define MI_NOTAGERR 1
- #define MI_ERR 2
- //------------------MFRC522寄存器---------------
- //Page 0:Command and Status
- #define Reserved00 0x00
- #define CommandReg 0x01
- #define CommIEnReg 0x02
- #define DivlEnReg 0x03
- #define CommIrqReg 0x04
- #define DivIrqReg 0x05
- #define ErrorReg 0x06
- #define Status1Reg 0x07
- #define Status2Reg 0x08
- #define FIFODataReg 0x09
- #define FIFOLevelReg 0x0A
- #define WaterLevelReg 0x0B
- #define ControlReg 0x0C
- #define BitFramingReg 0x0D
- #define CollReg 0x0E
- #define Reserved01 0x0F
- //Page 1:Command
- #define Reserved10 0x10
- #define ModeReg 0x11
- #define TxModeReg 0x12
- #define RxModeReg 0x13
- #define TxControlReg 0x14
- #define TxAutoReg 0x15
- #define TxSelReg 0x16
- #define RxSelReg 0x17
- #define RxThresholdReg 0x18
- #define DemodReg 0x19
- #define Reserved11 0x1A
- #define Reserved12 0x1B
- #define MifareReg 0x1C
- #define Reserved13 0x1D
- #define Reserved14 0x1E
- #define SerialSpeedReg 0x1F
- //Page 2:CFG
- #define Reserved20 0x20
- #define CRCResultRegM 0x21
- #define CRCResultRegL 0x22
- #define Reserved21 0x23
- #define ModWidthReg 0x24
- #define Reserved22 0x25
- #define RFCfgReg 0x26
- #define GsNReg 0x27
- #define CWGsPReg 0x28
- #define ModGsPReg 0x29
- #define TModeReg 0x2A
- #define TPrescalerReg 0x2B
- #define TReloadRegH 0x2C
- #define TReloadRegL 0x2D
- #define TCounterValueRegH 0x2E
- #define TCounterValueRegL 0x2F
- //Page 3:TestRegister
- #define Reserved30 0x30
- #define TestSel1Reg 0x31
- #define TestSel2Reg 0x32
- #define TestPinEnReg 0x33
- #define TestPinValueReg 0x34
- #define TestBusReg 0x35
- #define AutoTestReg 0x36
- #define VersionReg 0x37
- #define AnalogTestReg 0x38
- #define TestDAC1Reg 0x39
- #define TestDAC2Reg 0x3A
- #define TestADCReg 0x3B
- #define Reserved31 0x3C
- #define Reserved32 0x3D
- #define Reserved33 0x3E
- #define Reserved34 0x3F
- #define Relay 2
- //4字節卡序列號,第5字節為校驗字節
- uchar serNum[5];
- uchar writeDate[16] ={'\0'};
- //扇區A密碼,16個扇區,每個扇區密碼6Byte
- uchar sectorKeyA[16][16] = {{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
- {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
- uchar sectorNewKeyA[16][16] = {{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
- {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xff,0x07,0x80,0x69, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
- void setup() {
- Serial.begin(9600); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
- // start the SPI library:
- SPI.begin();
- pinMode(chipSelectPin,OUTPUT); // Set digital pin 10 as OUTPUT to connect it to the RFID /ENABLE pin
- digitalWrite(chipSelectPin, LOW); // Activate the RFID reader
- pinMode(NRSTPD,OUTPUT); // Set digital pin 10 , Not Reset and Power-down
- digitalWrite(NRSTPD, HIGH);
- MFRC522_Init();
- void loop()
- uchar i,tmp;
- uchar status;
- uchar str[MAX_LEN];
- uchar RC_size;
- uchar blockAddr; //選擇操作的塊地址0~63
- //尋卡,返回卡類型
- status = MFRC522_Request(PICC_REQIDL, str);
- if (status == MI_OK)
- //防沖撞,返回卡的序列號 4字節
- status = MFRC522_Anticoll(str);
- memcpy(serNum, str, 5);
- Serial.println("The card's number is : ");
- Serial.print(serNum[0],HEX);
- Serial.print(serNum[1],HEX);
- Serial.print(serNum[2],HEX);
- Serial.print(serNum[3],HEX);
- Serial.print(serNum[4],HEX);
- Serial.println(" ");
- //選卡,返回卡容量
- RC_size = MFRC522_SelectTag(serNum);
- if (RC_size != 0)
- //讀卡
- blockAddr = 7; //數據塊7
- status = MFRC522_Auth(PICC_AUTHENT1A, blockAddr, sectorNewKeyA[blockAddr/4], serNum); //認證
- //讀數據
- blockAddr = blockAddr - 3 ;
- status = MFRC522_Read(blockAddr, str);
- Serial.println("Read from the card ,the data is : ");
- for (i=0; i<16; i++)
- char aa=(char)str[i];
- Serial.print(aa);
- // Serial.println(" ");
- //////////////////////////////////////////////////// Check people associated with card ID
- unsigned char* id = serNum;
- if( id[0]==0xF1 && id[1]==0x9A && id[2]==0xD6 && id[3]==0x0E && str[0]=='a'&& str[1]=='u'&& str[2]=='g'&& str[3]=='u'&& str[4]=='s'&& str[5]=='t'&& str[6]=='0'&& str[7]=='1' ) //根據需要手動修改每個的內容
- digitalWrite(Relay,HIGH); //打開繼電器
- Serial.println("The Host 1!");
- else if(id[0]==0xCD && id[1]==0x83 && id[2]==0xFE && id[3]==0xC9) //根據需要手動修改每個的內容
- digitalWrite(Relay,LOW); //繼電器
- Serial.println("The Host 2!");
- else
- Serial.println("Stranger!");
- MFRC522_Halt(); //命令卡片進入休眠狀態
- * 函 數 名:Write_MFRC5200
- * 功能描述:向MFRC522的某一寄存器寫一個字節數據
- * 輸入參數:addr--寄存器地址;val--要寫入的值
- * 返 回 值:無
- void Write_MFRC522(uchar addr, uchar val)
- //地址格式:0XXXXXX0
- SPI.transfer((addr<<1)&0x7E);
- SPI.transfer(val);
- digitalWrite(chipSelectPin, HIGH);
- * 函 數 名:Read_MFRC522
- * 功能描述:從MFRC522的某一寄存器讀一個字節數據
- * 返 回 值:返回讀取到的一個字節數據
- uchar Read_MFRC522(uchar addr)
- uchar val;
- //地址格式:1XXXXXX0
- SPI.transfer(((addr<<1)&0x7E) | 0x80);
- val =SPI.transfer(0x00);
- return val;
- * 函 數 名:SetBitMask
- * 功能描述:置RC522寄存器位
- * 輸入參數:reg--寄存器地址;mask--置位值
- * 返 回 值:無
- void SetBitMask(uchar reg, uchar mask)
- uchar tmp;
- tmp = Read_MFRC522(reg);
- Write_MFRC522(reg, tmp | mask); // set bit mask
- * 函 數 名:ClearBitMask
- * 功能描述:清RC522寄存器位
- * 輸入參數:reg--寄存器地址;mask--清位值
- * 返 回 值:無
- void ClearBitMask(uchar reg, uchar mask)
- uchar tmp;
- Write_MFRC522(reg, tmp & (~mask)); // clear bit mask
- * 函 數 名:AntennaOn
- * 功能描述:開啟天線,每次啟動或關閉天險發射之間應至少有1ms的間隔
- * 輸入參數:無
- * 返 回 值:無
- void AntennaOn(void)
- uchar temp;
- temp = Read_MFRC522(TxControlReg);
- if (!(temp & 0x03))
- SetBitMask(TxControlReg, 0x03);
- * 函 數 名:AntennaOff
- * 功能描述:關閉天線,每次啟動或關閉天險發射之間應至少有1ms的間隔
- * 輸入參數:無
- * 返 回 值:無
- void AntennaOff(void)
- ClearBitMask(TxControlReg, 0x03);
- * 函 數 名:ResetMFRC522
- * 功能描述:復位RC522
- * 輸入參數:無
- * 返 回 值:無
- void MFRC522_Reset(void)
- Write_MFRC522(CommandReg, PCD_RESETPHASE);
- * 函 數 名:InitMFRC522
- * 功能描述:初始化RC522
- * 輸入參數:無
- * 返 回 值:無
- void MFRC522_Init(void)
- digitalWrite(NRSTPD,HIGH);
- MFRC522_Reset();
- //Timer: TPrescaler*TreloadVal/6.78MHz = 24ms
- Write_MFRC522(TModeReg, 0x8D); //Tauto=1; f(Timer) = 6.78MHz/TPreScaler
- Write_MFRC522(TPrescalerReg, 0x3E); //TModeReg[3..0] + TPrescalerReg
- Write_MFRC522(TReloadRegL, 30);
- Write_MFRC522(TReloadRegH, 0);
- Write_MFRC522(TxAutoReg, 0x40); //100%ASK
- Write_MFRC522(ModeReg, 0x3D); //CRC初始值0x6363 ???
- //ClearBitMask(Status2Reg, 0x08); //MFCrypto1On=0
- //Write_MFRC522(RxSelReg, 0x86); //RxWait = RxSelReg[5..0]
- //Write_MFRC522(RFCfgReg, 0x7F); //RxGain = 48dB
- AntennaOn(); //打開天線
- * 函 數 名:MFRC522_Request
- * 功能描述:尋卡,讀取卡類型號
- * 輸入參數:reqMode--尋卡方式,
- * TagType--返回卡片類型
- * 0x4400 = Mifare_UltraLight
- * 0x0400 = Mifare_One(S50)
- * 0x0200 = Mifare_One(S70)
- * 0x0800 = Mifare_Pro(X)
- * 0x4403 = Mifare_DESFire
- * 返 回 值:成功返回MI_OK
- uchar MFRC522_Request(uchar reqMode, uchar *TagType)
- uchar status;
- uint backBits; //接收到的數據位數
- Write_MFRC522(BitFramingReg, 0x07); //TxLastBists = BitFramingReg[2..0] ???
- TagType[0] = reqMode;
- status = MFRC522_ToCard(PCD_TRANSCEIVE, TagType, 1, TagType, &backBits);
- if ((status != MI_OK) || (backBits != 0x10))
- status = MI_ERR;
- return status;
- * 函 數 名:MFRC522_ToCard
- * 功能描述:RC522和ISO14443卡通訊
- * 輸入參數:command--MF522命令字,
- * sendData--通過RC522發送到卡片的數據,
- * sendLen--發送的數據長度
- * backData--接收到的卡片返回數據,
- * backLen--返回數據的位長度
- * 返 回 值:成功返回MI_OK
- uchar MFRC522_ToCard(uchar command, uchar *sendData, uchar sendLen, uchar *backData, uint *backLen)
- uchar status = MI_ERR;
- uchar irqEn = 0x00;
- uchar waitIRq = 0x00;
- uchar lastBits;
- uchar n;
- uint i;
- switch (command)
- case PCD_AUTHENT: //認證卡密
- irqEn = 0x12;
- waitIRq = 0x10;
- break;
- case PCD_TRANSCEIVE: //發送FIFO中數據
- irqEn = 0x77;
- waitIRq = 0x30;
- break;
- default:
- break;
- Write_MFRC522(CommIEnReg, irqEn|0x80); //允許中斷請求
- ClearBitMask(CommIrqReg, 0x80); //清除所有中斷請求位
- SetBitMask(FIFOLevelReg, 0x80); //FlushBuffer=1, FIFO初始化
- Write_MFRC522(CommandReg, PCD_IDLE); //NO action;取消當前命令 ???
- //向FIFO中寫入數據
- for (i=0; i<sendLen; i++)
- Write_MFRC522(FIFODataReg, sendData[i]);
- //執行命令
- Write_MFRC522(CommandReg, command);
- if (command == PCD_TRANSCEIVE)
- SetBitMask(BitFramingReg, 0x80); //StartSend=1,transmission of data starts
- //等待接收數據完成
- i = 2000; //i根據時鐘頻率調整,操作M1卡最大等待時間25ms ???
- do
- //CommIrqReg[7..0]
- //Set1 TxIRq RxIRq IdleIRq HiAlerIRq LoAlertIRq ErrIRq TimerIRq
- n = Read_MFRC522(CommIrqReg);
- i--;
- while ((i!=0) && !(n&0x01) && !(n&waitIRq));
- ClearBitMask(BitFramingReg, 0x80); //StartSend=0
- if (i != 0)
- if(!(Read_MFRC522(ErrorReg) & 0x1B)) //BufferOvfl Collerr CRCErr ProtecolErr
- status = MI_OK;
- if (n & irqEn & 0x01)
- status = MI_NOTAGERR; //??
- n = Read_MFRC522(FIFOLevelReg);
- lastBits = Read_MFRC522(ControlReg) & 0x07;
- if (lastBits)
- *backLen = (n-1)*8 + lastBits;
- else
- *backLen = n*8;
- if (n == 0)
- n = 1;
- if (n > MAX_LEN)
- n = MAX_LEN;
- //讀取FIFO中接收到的數據
- for (i=0; i<n; i++)
- backData[i] = Read_MFRC522(FIFODataReg);
- else
- status = MI_ERR;
- //SetBitMask(ControlReg,0x80); //timer stops
- //Write_MFRC522(CommandReg, PCD_IDLE);
- return status;
- * 函 數 名:MFRC522_Anticoll
- * 功能描述:防沖突檢測,讀取選中卡片的卡序列號
- * 輸入參數:serNum--返回4字節卡序列號,第5字節為校驗字節
- * 返 回 值:成功返回MI_OK
- uchar MFRC522_Anticoll(uchar *serNum)
- uchar status;
- uchar i;
- uchar serNumCheck=0;
- uint unLen;
- //ClearBitMask(Status2Reg, 0x08); //TempSensclear
- //ClearBitMask(CollReg,0x80); //ValuesAfterColl
- Write_MFRC522(BitFramingReg, 0x00); //TxLastBists = BitFramingReg[2..0]
- serNum[0] = PICC_ANTICOLL;
- serNum[1] = 0x20;
- status = MFRC522_ToCard(PCD_TRANSCEIVE, serNum, 2, serNum, &unLen);
- //校驗卡序列號
- for (i=0; i<4; i++)
- serNumCheck ^= serNum[i];
- if (serNumCheck != serNum[i])
- status = MI_ERR;
- //SetBitMask(CollReg, 0x80); //ValuesAfterColl=1
- return status;
- * 函 數 名:CalulateCRC
- * 功能描述:用MF522計算CRC
- * 輸入參數:pIndata--要讀數CRC的數據,len--數據長度,pOutData--計算的CRC結果
- * 返 回 值:無
- void CalulateCRC(uchar *pIndata, uchar len, uchar *pOutData)
- uchar i, n;
- ClearBitMask(DivIrqReg, 0x04); //CRCIrq = 0
- SetBitMask(FIFOLevelReg, 0x80); //清FIFO指針
- //向FIFO中寫入數據
- for (i=0; i<len; i++)
- Write_MFRC522(FIFODataReg, *(pIndata+i));
- Write_MFRC522(CommandReg, PCD_CALCCRC);
- //等待CRC計算完成
- i = 0xFF;
- do
- n = Read_MFRC522(DivIrqReg);
- i--;
- while ((i!=0) && !(n&0x04)); //CRCIrq = 1
- //讀取CRC計算結果
- pOutData[0] = Read_MFRC522(CRCResultRegL);
- pOutData[1] = Read_MFRC522(CRCResultRegM);
- * 函 數 名:MFRC522_SelectTag
- * 功能描述:選卡,讀取卡存儲器容量
- * 輸入參數:serNum--傳入卡序列號
- * 返 回 值:成功返回卡容量
- uchar MFRC522_SelectTag(uchar *serNum)
- uchar i;
- uchar status;
- uchar size;
- uint recvBits;
- uchar buffer[9];
- buffer[0] = PICC_SElECTTAG;
- buffer[1] = 0x70;
- for (i=0; i<5; i++)
- buffer[i+2] = *(serNum+i);
- CalulateCRC(buffer, 7, &buffer[7]); //??
- status = MFRC522_ToCard(PCD_TRANSCEIVE, buffer, 9, buffer, &recvBits);
- if ((status == MI_OK) && (recvBits == 0x18))
- size = buffer[0];
- else
- size = 0;
- return size;
- * 函 數 名:MFRC522_Auth
- * 功能描述:驗證卡片密碼
- * 輸入參數:authMode--密碼驗證模式
- 0x60 = 驗證A密鑰
- 0x61 = 驗證B密鑰
- BlockAddr--塊地址
- Sectorkey--扇區密碼
- serNum--卡片序列號,4字節
- * 返 回 值:成功返回MI_OK
- uchar MFRC522_Auth(uchar authMode, uchar BlockAddr, uchar *Sectorkey, uchar *serNum)
- uchar status;
- uint recvBits;
- uchar i;
- uchar buff[12];
- //驗證指令+塊地址+扇區密碼+卡序列號
- buff[0] = authMode;
- buff[1] = BlockAddr;
- for (i=0; i<6; i++)
- buff[i+2] = *(Sectorkey+i);
- buff[i+8] = *(serNum+i);
- status = MFRC522_ToCard(PCD_AUTHENT, buff, 12, buff, &recvBits);
- if ((status != MI_OK) || (!(Read_MFRC522(Status2Reg) & 0x08)))
- status = MI_ERR;
- return status;
- * 函 數 名:MFRC522_Read
- * 功能描述:讀塊數據
- * 輸入參數:blockAddr--塊地址;recvData--讀出的塊數據
- * 返 回 值:成功返回MI_OK
- uchar MFRC522_Read(uchar blockAddr, uchar *recvData)
- uchar status;
- uint unLen;
- recvData[0] = PICC_READ;
- recvData[1] = blockAddr;
- CalulateCRC(recvData,2, &recvData[2]);
- status = MFRC522_ToCard(PCD_TRANSCEIVE, recvData, 4, recvData, &unLen);
- if ((status != MI_OK) || (unLen != 0x90))
- status = MI_ERR;
- return status;
- * 函 數 名:MFRC522_Write
- * 功能描述:寫塊數據
- * 輸入參數:blockAddr--塊地址;writeData--向塊寫16字節數據
- * 返 回 值:成功返回MI_OK
- uchar MFRC522_Write(uchar blockAddr, uchar *writeData)
- uchar status;
- uint recvBits;
- uchar i;
- uchar buff[18];
- buff[0] = PICC_WRITE;
- buff[1] = blockAddr;
- CalulateCRC(buff, 2, &buff[2]);
- status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff, &recvBits);
- if ((status != MI_OK) || (recvBits != 4) || ((buff[0] & 0x0F) != 0x0A))
- status = MI_ERR;
- for (i=0; i<16; i++) //向FIFO寫16Byte數據
- buff[i] = *(writeData+i);
- CalulateCRC(buff, 16, &buff[16]);
- status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 18, buff, &recvBits);
- status = MI_ERR;
- return status;
- * 函 數 名:MFRC522_Halt
- * 功能描述:命令卡片進入休眠狀態
- * 輸入參數:無
- * 返 回 值:無
- void MFRC522_Halt(void)
- uchar status;
- uint unLen;
- uchar buff[4];
- buff[0] = PICC_HALT;
- buff[1] = 0;
- status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff,&unLen);
復制代碼 |
