查看: 3576|回復: 1
求大神看下STC12C5A60S2單片機串口程序
ID:114987 發表于 2017-5-19 14:46 | 顯示全部樓層 |閱讀模式
編譯之后的提示
Build target 'Target 1'
linking...
Program Size: data=117.0 xdata=121 code=1707
creating hex file from "gps2"...
"gps2" - 0 Error(s), 0 Warning(s).
我想知道為什么在串口助手里連我標紅的那兩行串口測試的兩串字符也不顯示
  1. #include<STC12C5A60S2.h>
  2. #include <stdio.h>
  3. #include <stdlib.h>
  4. #include <string.h>
  5. #define false 0
  6. #define true 1
  7. //定義數組長度
  8. #define GPS_Buffer_Length 80
  9. #define UTCTime_Length 11
  10. #define latitude_Length 11
  11. #define N_S_Length 2
  12. #define longitude_Length 12
  13. #define E_W_Length 2
  14. #define gpsRxBufferLength  76
  15. char idata gpsRxBuffer[gpsRxBufferLength];
  16. unsigned char RX_Count;
  17. //函數或者變量聲明
  18. void Delay_ms(unsigned int n);
  19. void printGpsBuffer();
  20. void parseGpsBuffer();
  21. void errorLog(int num);
  22. void Uart_Init();
  23. void UartPrintf(unsigned char *p);
  24. void UartPrintASCII(unsigned char c);
  25. void Uart_Init();
  26. void UartPrintf(unsigned char *p);
  27. void UartPrintASCII(unsigned char c);
  28. extern void clrStruct();
  29. struct SaveData
  30. {
  31.         char GPS_Buffer[GPS_Buffer_Length];
  32.         char isGetData;                //是否獲取到GPS數據
  33.         char isParseData;        //是否解析完成
  34.         char UTCTime[UTCTime_Length];                //UTC時間
  35.         char latitude[latitude_Length];                //緯度
  36.         char N_S[N_S_Length];                //N/S
  37.         char longitude[longitude_Length];                //經度
  38.         char E_W[E_W_Length];                //E/W
  39.         char isUsefull;                //定位信息是否有效
  40. } xdata Save_Data;
  41. #define gpsRxBufferLength  76
  42. char idata gpsRxBuffer[gpsRxBufferLength];
  43. unsigned char RX_Count=0;
  44. void main()
  45. {
  46.         unsigned char i = 0;
  47.         Uart_Init();
  48.         Delay_ms(10);
  49.         [color=#ff0000]UartPrintf("Welcome to use!");                                             //測試串口是正確[/color]
  50. [color=#ff0000]        UartPrintf("ILoveMCU.taobao.com");[/color]
  51.         clrStruct();        //清空緩存數組
  52.         while(1)
  53.         {
  54.                 parseGpsBuffer();
  55.                 printGpsBuffer();
  56.         }
  57. }
  58. void Uart_Init()
  59. {
  60.         SCON = 0X50;  //UART方式1;8位UART
  61.         REN  = 1;     //允許串行口接收數據
  62.         PCON = 0x00;  //SMOD=0;波特率不加倍
  63.         TMOD = 0x20;  //T1方式2,用于產生波特率
  64.         TH1  = 0xFD;  //裝初值
  65.         TL1  = 0xFD;
  66.         TR1  = 1;     //啟動定時器1
  67.         EA   = 1;     //打開全局中斷控制
  68.         ES   = 1;     //打開串行口中斷
  69. }
  70. void UartPrintf(unsigned char *p)                                //發送字符串
  71. {
  72.          while(*p)
  73.          {
  74.                  SBUF=*(p++);
  75.                 while(TI==0)
  76.                 {
  77.                 };
  78.                 TI=0;
  79.         }
  80. }
  81. void UartPrintASCII(unsigned char c)                                //發送一個字符
  82. {
  83.     TI=0;
  84.     SBUF=c;
  85.     while(TI==0);
  86.     TI=0;
  87. }
  88. void RECEIVE_DATA(void) interrupt 4 using 3
  89. {
  90.         unsigned char temp = 0;
  91.         char i = 0;
  92.         ES=0;
  93.         temp = SBUF;
  94.         RI = 0;
  95.
  96.         if(temp == ')
  97.         {
  98.                 RX_Count = 0;
  99.         }
  100.
  101.         if(RX_Count <= 5)
  102.         {
  103.            gpsRxBuffer[RX_Count++] = temp;
  104.         }
  105.         else if(gpsRxBuffer[0] == ' &gpsRxBuffer[4] == 'M' && gpsRxBuffer[5] == 'C')                        //確定是否收到"GPRMC/GNRMC"這一幀數據
  106.         {
  107.                 gpsRxBuffer[RX_Count++] = temp;
  108.                 if(temp == '\n')
  109.                 {
  110.                         memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length);      //清空
  111.                         memcpy(Save_Data.GPS_Buffer, gpsRxBuffer, RX_Count);         //保存數據
  112.                         Save_Data.isGetData = true;
  113.                         RX_Count = 0;
  114.                         memset(gpsRxBuffer, 0, gpsRxBufferLength);      //清空
  115.                 }
  116.
  117.                 if(RX_Count >= 75)
  118.                 {
  119.                         RX_Count = 75;
  120.                         gpsRxBuffer[RX_Count] = '\0';//添加結束符
  121.                 }
  122.         }
  123.         ES=1;
  124. }
  125. void clrStruct()
  126. {
  127.         Save_Data.isGetData = false;
  128.         Save_Data.isParseData = false;
  129.         Save_Data.isUsefull = false;
  130.         memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length);      //清空
  131.         memset(Save_Data.UTCTime, 0, UTCTime_Length);
  132.         memset(Save_Data.latitude, 0, latitude_Length);
  133.         memset(Save_Data.N_S, 0, N_S_Length);
  134.         memset(Save_Data.longitude, 0, longitude_Length);
  135.         memset(Save_Data.E_W, 0, E_W_Length);
  136.
  137. }
  138. void errorLog(int num)
  139. {
  140.
  141.         while (1)
  142.         {
  143.                   UartPrintf("ERROR");
  144.                 UartPrintASCII(num+0x30);
  145.                 UartPrintf("\r\n");
  146.         }
  147. }
  148. void parseGpsBuffer()
  149. {
  150.         char *subString;
  151.         char *subStringNext;
  152.         char i = 0;
  153.         if (Save_Data.isGetData)
  154.         {
  155.                 Save_Data.isGetData = false;
  156.                 UartPrintf("**************\r\n");
  157.                 UartPrintf(Save_Data.GPS_Buffer);
  158.
  159.                 for (i = 0 ; i <= 6 ; i++)
  160.                 {
  161.                         if (i == 0)
  162.                         {
  163.                                 if ((subString = strstr(Save_Data.GPS_Buffer, ",")) == NULL)
  164.                                         errorLog(1);        //解析錯誤
  165.                         }
  166.                         else
  167.                         {
  168.                                 subString++;
  169.                                 if ((subStringNext = strstr(subString, ",")) != NULL)
  170.                                 {
  171.                                         char usefullBuffer[2];
  172.                                         switch(i)
  173.                                         {
  174.                                                 case 1:memcpy(Save_Data.UTCTime, subString, subStringNext - subString);break;        //獲取UTC時間
  175.                                                 case 2:memcpy(usefullBuffer, subString, subStringNext - subString);break;        //獲取UTC時間
  176.                                                 case 3:memcpy(Save_Data.latitude, subString, subStringNext - subString);break;        //獲取緯度信息
  177.                                                 case 4:memcpy(Save_Data.N_S, subString, subStringNext - subString);break;        //獲取N/S
  178.                                                 case 5:memcpy(Save_Data.longitude, subString, subStringNext - subString);break;        //獲取經度信息
  179.                                                 case 6:memcpy(Save_Data.E_W, subString, subStringNext - subString);break;        //獲取E/W
  180.                                                 default:break;
  181.                                         }
  182.                                         subString = subStringNext;
  183.                                         Save_Data.isParseData = true;
  184.                                         if(usefullBuffer[0] == 'A')
  185.                                                 Save_Data.isUsefull = true;
  186.                                         else if(usefullBuffer[0] == 'V')
  187.                                                 Save_Data.isUsefull = false;
  188.                                 }
  189.                                 else
  190.                                 {
  191.                                         errorLog(2);        //解析錯誤
  192.                                 }
  193.                         }
  194.                 }
  195.         }
  196. }
  197. void printGpsBuffer()
  198. {
  199.         if (Save_Data.isParseData)
  200.         {
  201.                 Save_Data.isParseData = false;
  202.
  203.                 UartPrintf("Save_Data.UTCTime = ");
  204.                 UartPrintf(Save_Data.UTCTime);
  205.                 UartPrintf("\r\n");
  206.                 if(Save_Data.isUsefull)
  207.                 {
  208.                         Save_Data.isUsefull = false;
  209.                         UartPrintf("Save_Data.latitude = ");
  210.                         UartPrintf(Save_Data.latitude);
  211.                         UartPrintf("\r\n");
  212.                         UartPrintf("Save_Data.N_S = ");
  213.                         UartPrintf(Save_Data.N_S);
  214.                         UartPrintf("\r\n");
  215.                         UartPrintf("Save_Data.longitude = ");
  216.                         UartPrintf(Save_Data.longitude);
  217.                         UartPrintf("\r\n");
  218.                         UartPrintf("Save_Data.E_W = ");
  219.                         UartPrintf(Save_Data.E_W);
  220.                         UartPrintf("\r\n");
  221.                 }
  222.                 else
  223.                 {
  224.                         UartPrintf("GPS DATA is not usefull!\r\n");
  225.                 }
  226.
  227.         }
  228. }
  229. //****************************************************
  230. //MS延時函數
  231. //****************************************************
  232. void Delay_ms(unsigned int n)
  233. {
  234.         unsigned int  i,j;
  235.         for(i=0;i<n;i++)
  236.                 for(j=0;j<123;j++);
  237. }
ID:76181 發表于 2018-6-15 22:40 | 顯示全部樓層
SUBF被占用了,沒清空
