51的舵機小代碼:
51控制舵機.docx
(11.49 KB, 下載次數(shù): 20)
2017-5-18 21:18 上傳
- #include<reg52.h>
- typedef unsigned int uint;
- typedef unsigned char uchar;
- sbit pwm=P1^0;//輸出PWM信號
- uchar count=0;
- uint pwm_value=1500;//初值為1.5ms
- uint value[]={1500,1000,1500,2000,1500};//
- void delay_ms(uint x)
- uint i;
- while(x--)for(i=0;i<125;i++);
- void InitTimer(void)
- TMOD=0x11;//開定時器0,1
- TH0=-20000/256;//定時20MS,20MS為一個周期
- TL0=-20000%256;
- TH1=-1500/256;//定時1.5MS,這時舵機處于0度
- TL1=-1500%256;
- EA=1;//開總斷
- TR0=1;//開定時器0
- ET0=1;
- TR1=1;//開定時器1
- ET1=1;
- void timer0(void) interrupt 1//定時器0中斷函數(shù)
- pwm=1;
- TH0=-20000/256;
- TL0=-20000%256;
- TR1=1;
- count++;
- void timer1(void) interrupt 3//定時器1中斷函數(shù)
- pwm=0;
- TH1=-pwm_value/256;
- TL1=-pwm_value%256;
- TR1=0;
- void main(void)//主函數(shù)
- uchar i;
- InitTimer();
- pwm_value=1500;
- while(1)
- for(i=0;i<5;i++)
- pwm_value=value[i];//通過數(shù)組就可以改變舵機的轉(zhuǎn)角度
- delay_ms(1000);
