查看: 2385|回復: 1
電機運轉代碼
ID:200161 發表于 2017-5-13 02:07 | 顯示全部樓層 |閱讀模式
#include "motor.h"
#include "uart.h"
#include "timer.h"
#include "mem.h"
uchar Cruising_Flag =0x00;
uchar  Robots_Run_Status;
uchar Pre_Cruising_Flag = 0x00;
extern uint16 se_timer[8];
/**電機初始化**/
void Motor_Init(void)
        MOTOR_A_EN=1;
        MOTOR_B_EN=1;
        MOTOR_GO_STOP;
//跟隨模式
void Follow_Track(void)
                  switch(Robots_Run_Status)
                        case 0x01:MOTOR_GO_RIGHT;     break;
                        case 0x02:MOTOR_GO_LEFT;     break;
                        case 0x03:MOTOR_GO_FORWARD;  break;
                        case 0x04:MOTOR_GO_STOP;  break;
             if(Input_Detect1 == 1)        //中間傳感器OK
                           if((Input_Detect0 == 0)&& (Input_Detect2 == 0)) //兩邊同時探測到障礙物
                                 Robots_Run_Status=0x04;//停止
                        if((Input_Detect0 == 0)&& (Input_Detect2 == 1))//左側障礙物
                                Robots_Run_Status=0x01;//右轉
                        if((Input_Detect0 == 1)&& (Input_Detect2 == 0))//右側障礙物
                                Robots_Run_Status=0x02;//左轉
                        if((Input_Detect0 == 1)&& (Input_Detect2 == 1))//無任何障礙物
                                Robots_Run_Status=0x03;//直行
//巡線模式
void FollowLine(void)
                           if((Input_Detect_LEFT == 0)&& (Input_Detect_RIGHT == 0))//兩邊同時探測到障礙物
                        if((Input_Detect_LEFT == 0)&& (Input_Detect_RIGHT == 1))//右側遇到障礙
                        if((Input_Detect_LEFT == 1)&& (Input_Detect_RIGHT == 0))//左側遇到障礙
                        if((Input_Detect_LEFT == 1)&& (Input_Detect_RIGHT == 1))//左右都檢測到,就如視頻中的那樣遇到一道橫的膠帶
//避障模式
void Avoiding(void)
                        case 0x05:MOTOR_GO_BACK; break;
                           if((Input_Detect_LEFT == 1) || (Input_Detect_RIGHT == 1) || (Input_Detect1==0))
                        else //否則電機執行前進動作
//手臂動作展示
void ARMShow(void)
        se_timer[0]=100;
        Delay_Ms(1000);
        se_timer[1]=70;
        Delay_Ms(1000);
        se_timer[2]=60;
        Delay_Ms(1000);
        se_timer[3]=50;
        Delay_Ms(1000);
        se_timer[3]=81;
        Delay_Ms(1000);
        se_timer[2]=160;
        Delay_Ms(1000);
        se_timer[1]=120;
        Delay_Ms(1000);
        se_timer[0]=140;
        Delay_Ms(1000);
//手臂動作展示
void HeadShow(void)
         Beep=~Beep;
        se_timer[7]=170;
        Delay_Ms(1000);
        se_timer[7]=0;
        Delay_Ms(1000);
//發送超聲波
void Send_wave(void)
    uint16 i;
        Trig = 1;
        for(i=0;i<150;i++);
        Trig = 0;
//獲得距離值
uchar Get_Distance(void)
    uint32 Distance = 0;
    Send_wave();
    TH1 = 0;
    TL1 = 0;
        while(TH1<250 && Echo!= 1);
        if(TH1 <= 250)        //測距范圍<0.5M
           TH1 = 0;
           TL1 = 0;
           while(Echo == 1);
           Distance = TH1;
           Distance = Distance*256;
           Distance = Distance + TL1;
           Distance = Distance * 17;
           Distance = Distance / 22118;
           return (uchar)(Distance&0xFF);
//通過雷達避障
void AvoidByRadar(void)
   if(Get_Distance()<0x0A)//如果雷達回波數據小于10厘米觸發
                 MOTOR_GO_STOP;
          MOTOR_GO_FORWARD;
void Send_Distance(void)
           UART_send_byte(0xFF);
           UART_send_byte(0x03);
           UART_send_byte(0x00);
           UART_send_byte(Get_Distance());
           Delay_Ms(1000);
//模式執行子函數,根據標志位進行判斷
void Cruising_Mod(void)
         if(Pre_Cruising_Flag != Cruising_Flag)
             if(Pre_Cruising_Flag != 0)
                     MOTOR_GO_STOP;
             Pre_Cruising_Flag =  Cruising_Flag;
        switch(Cruising_Flag)
           case 0x01:Follow_Track(); break;//跟隨模式
           case 0x02:FollowLine(); break;//巡線模式
           case 0x03:Avoiding(); break;//避障模式
           case 0x04:AvoidByRadar();break;//超聲波壁障模式
           case 0x05:ARMShow();break;
           case 0x06:HeadShow();break;
           default:break;
void Delay_ForBarrier(uint32 t)
    uint16 i;
        while(t--)
           for(i=0;i<1050;i++);
ID:699251 發表于 2020-3-25 23:59 | 顯示全部樓層
return (uchar)(Distance&0xFF);這句為啥會報錯
