查看: 6188|回復: 8
基于ADC0804的1602顯示電壓仿真和單片機代碼
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint  unsigned int
  5.
  6. uchar code table1[]="0123456789";
  7. uchar code table2[]="DianYa:0.00V";
  8. uchar code table3[]="made  by  JCLong";
  9. uchar num,x,adval,wen,dy,date;
  10. sbit lcden=P3^2;
  11. sbit lcdrs=P3^0;
  12. sbit lcdrw=P3^1;
  13. sbit lcds1=P3^3;
  14. sbit lcds2=P3^4        ;
  15. sbit adwr=P3^6;
  16. sbit adrd=P3^7;
  17. sbit adcs=P3^5;
  18. void  delay(uint z)
  19. {
  20.    uint x,y;
  21.    for(x=z;x>0;x--)
  22.      for(y=110;y>0;y--);
  23. }
  24. void write_com(uchar com)
  25. {
  26.    lcdrs=0;
  27.    P2=com;
  28.    delay(5);
  29.    lcden=1;
  30.    delay(5);
  31.    lcden=0;
  32. }
  33. void write_date(uchar date)
  34. {
  35.    lcdrs=1;
  36.    P2=date;
  37.    delay(5);
  38.    lcden=1;
  39.    delay(5);
  40.    lcden=0;
  41. }
  42. void init()
  43. {
  44.
  45.   adcs=0;
  46.   lcdrw=0;
  47.   lcden=0;
  48.    write_com(0x38);        //
  49.    write_com(0x0c);
  50.    write_com(0x06);
  51.    write_com(0x01);
  52.     write_com(0x80);
  53.   while(table3[num]!='\0')
  54.     {
  55.         write_date(table3[num++]);
  56.         delay(100);
  57.         }
  58.         lcden=1;
  59.         delay(1000);
  60.         lcden=0;
  61.
  62.         write_com(0x80+0x40);
  63.         num=0;//很重要!
  64.         while(table2[num]!='\0')
  65.            {
  66.                     write_date(table2[num++]);
  67.
  68.            }
  69. }
  70.
  71. void set_shu(uchar  add,uchar date)
  72.    {
  73.      uchar shu,bai,shi,ge;
  74.          //date=date/225;
  75.          /*bai=date/100;
  76.          shi=date/100%10;
  77.          ge=date%10;
  78.          write_com(0x80+0x40+add);                //將電壓值轉換為0~225的值
  79.          write_date(table1[bai]);
  80.          write_date(table1[shi]);
  81.          write_date(table1[ge])  ;        */
  82.          bai=date/45;
  83.          //shi=bai*10/45;
  84.          shi=((date%45)*10/45);
  85.          ge=((date%45)*10%45)*10/45;
  86.          write_com(0x80+0x40+add);
  87.              {
  88.                  write_date(table1[bai]);
  89.                  }                                                         //將值轉換成具體數
  90.          write_com(0x80+0x40+add+2);
  91.              {
  92.                  write_date(table1[shi]);
  93.                  }
  94.           write_com(0x80+0x40+add+3);
  95.              {
  96.                  write_date(table1[ge]) ;
  97.         }          }
  98. void st_ad() //開AD
  99. {
  100.    adwr=1;
  101.    _nop_();
  102.    adwr=0;
  103.    _nop_();
  104.    adwr=1;
  105. }
  106. void red_ad()//讀AD
  107. {
  108.    adrd=1;
  109.    _nop_();
  110.    adrd=0;
  111.    _nop_();
  112.    adrd=0;
  113. }
  114. void main()
  115. {
  116.
  117.         init();
  118.
  119.
  120.          while(1)
  121.          {
  122. ……………………
  123. …………限于本文篇幅 余下代碼請從51黑下載附件…………
基于ADC0804的1602顯示電壓.zip (17.06 KB, 下載次數: 169)
收藏收藏2 分享淘帖 頂 踩
ID:218728 發表于 2017-7-11 20:13 | 只看該作者
bai=date/45;           //shi=bai*10/45;          shi=((date%45)*10/45);                   ge=((date%45)*10%45)*10/45; 樓主能給這段代碼解釋一下嗎,我不太懂,謝了
bai=date/45;
         //shi=bai*10/45;
ID:443783 發表于 2019-3-18 14:10 | 只看該作者
應該是百位=date/45//數據除以45,45應該是最總數據的算法
ID:345989 發表于 2019-6-22 17:57 | 只看該作者
C語言剛學沒多久,單片機也是剛入門,所以想下載樓主的完整程序看一下
ID:713781 發表于 2020-4-23 12:56 | 只看該作者
所以為什么除以45啊
ID:730449 發表于 2020-4-23 17:55 來自觸屏版 | 只看該作者
8位的電壓數據,有255個點,基準電壓是5V,平均每個等份的電壓為5/255 V,而單片機得到的0~255的數乘上5/255 就是電壓值!即,(date*5)/255=date/45
ID:347629 發表于 2020-5-31 15:00 | 只看該作者
馬永練 發表于 2020-4-23 17:55
8位的電壓數據,有255個點,基準電壓是5V,平均每個等份的電壓為5/255 V,而單片機得到的0~255的數乘上5/2 ...
5和255約分之后是51,也就是data/51  ,45怕是不對吧
ID:292460 發表于 2020-6-10 11:00 | 只看該作者
感謝樓主
