查看: 3473|回復: 3
求單片機電子音樂盒的設計
ID:199559 發表于 2017-5-12 18:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
10黑幣
電子音樂盒的設計
設計任務:
1、查閱資料,了解單片機控制單音喇叭發聲原理
2、設計一款基于單片機的音樂盒
3、通過按鈕可以選擇不同的音樂(點擊按鈕切換下一首)
ID:199559 發表于 2017-5-12 18:44 | 只看該作者
#include<reg52.h>                 //庫文件
#define uchar unsigned char//宏定義無符號字符型
#define uint unsigned int  //宏定義無符號整型
uchar Count;
sbit Key=P3^4;//P3.4控制T0口中斷
sbit _Speak =P2^0 ; //訊響器控制腳  //定義一個位變量_Speak
unsigned char code SONG[] ={
//路邊的野華不要采
0xFF,0x20,0x30,0x1C,0x10,0x18,0x20,
0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
0x30,0x80,0xFF,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,0x00,
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00,};
void Time0_Init()//初始化函數
        TMOD = 0x01;//定時器中斷地工作狀態為1
        IE = 0x82;  //p127 中斷允許寄存器,82=10000010,IE.7位為1表示CPU開放中斷,IE.1表示允許定時器T0溢出中斷
        TH0 = 0xD8;   //為T0計數器付初值,高位TH0=0XD8,低位TL0=0XF0,65536-55536=10000,表明T0計數器計數10000個計數周期后溢出
        TL0 = 0xF0; //12MZ晶振,10ms
void Time0_Int() interrupt 1    //定時計數器T0中斷p128
        TH0 = 0xD8;  //重裝初值
        TL0 = 0xF0;
        Count++; //長度加1,執行一次,中斷計數器加一
void Delay_xMs(unsigned int x) //1MS 延時子程序
        unsigned int i,j;
        for( i =0;i < x;i++ )
                for( j =0;j<3;j++ );
void Play_Song(unsigned char i) //:歌曲播放子程序i 為播放哪一段曲目
        unsigned char Temp1,Temp2;
        unsigned int Addr=0;
        Count = 0; //中斷計數器清0
    Addr=i*165;
                Temp1 = SONG[Addr++];
                if ( Temp1 == 0xFF ) //休止符
                                TR0 = 0; Delay_xMs(100);
        else if ( Temp1 == 0x00 ) //歌曲結束符
                        return;
        Temp2 = SONG[Addr++];
        TR0 = 1;
        _Speak = ~_Speak;   //按位取反指令
        Delay_xMs(Temp1);
        if ( Temp2 == Count )
                        Count = 0;
                        break;
void main() //主程序
        Time0_Init(); //定時器0 中斷初始化
      if(Key==0){
                Play_Song(0);
                if(Key==0){
                Play_Song(1);}}else{
TR0=0;
        } //播放
這是目前的代碼,我想知道怎么通過點擊P3.4的按鈕實現切換到下一首歌曲的功能
ID:199559 發表于 2017-5-12 18:45 | 只看該作者
對了,main函數那里是錯的,并不能實現切換歌曲
ID:637659 發表于 2019-11-12 19:46 | 只看該作者
代碼:
#include <reg51.h>
sbit speaker = P3^1;
sbit key0 = P2^0;
sbit key1 = P2^1;
sbit key2 = P2^2;
sbit key3 = P2^3;
unsigned char k, i;
unsigned char timer0h, timer0l, time ,num ,tempi,tempstop,tempan,temptime;
unsigned char code table[]={//我做的數碼管 數字顯示
        0x3f,0x30,0xed,0x79,
        0x72,0x5b,0x5f};
unsigned char code table[]={                //數碼管 數字顯示
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71};
//---------------------------------1 2 3 4 5 6 7音調
code unsigned char FREQH[] = {        //TH0部分
    0xF2, 0xF3, 0xF5, 0xF5, 0xF6, 0xF7, 0xF8,                            //低音1234567
    0xF9, 0xF9, 0xFA, 0xFA, 0xFB, 0xFB, 0xFC, 0xFC,                        //中
    0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE,                            //高
    0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF                                //超高
code unsigned char FREQL[] = {        //TL0部分
    0x42, 0xC1, 0x17, 0xB6, 0xD0, 0xD1, 0xB6,
    0x21, 0xE1, 0x8C, 0xD8, 0x68, 0xE9, 0x5B, 0x8F,
    0xEE, 0x44, 0x6B, 0xB4, 0xF4, 0x2D,
    0x47, 0x77, 0xA2, 0xB6, 0xDA, 0xFA, 0x16
code unsigned char song[][150]={                                //歌曲
{3,2,2, 3,2,2, 3,2,2, 1,2,1, 3,2,2,        0,0,0, 5,2,2, 0,0,0,
5,1,2,        0,0,0, 1,2,1,        0,0,0, 5,1,1,        0,0,0, 3,1,2,        0,0,0,
6,1,2, 7,1,2, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 5,2,1, 6,2,1,
0,0,0, 4,2,1, 5,2,1, 0,0,0, 3,2,1, 0,0,0, 1,2,1, 2,2,1,
7,1,2, 0,0,0, 1,2,2, 0,0,0, 5,1,1, 0,0,0, 0,0,0, 3,1,1,
0,0,0, 6,1,2, 7,1,2, 0,0,0, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 0,0,100
{6, 2, 3,  5, 2, 1,  3, 2, 2,  5, 2, 2,  1, 3, 2,  6, 2, 1,  5, 2, 1,
//一個音符有三個數字。前為第幾個音、中為第幾個八度、后為時長(以半拍為單位)。
//6, 2, 3 分別代表:6, 中音, 3個半拍;
//5, 2, 1 分別代表:5, 中音, 1個半拍;
//3, 2, 2 分別代表:3, 中音, 2個半拍;
//5, 2, 2 分別代表:5, 中音, 2個半拍;
//1, 3, 2 分別代表:1, 高音, 2個半拍;
6, 2, 4, 3, 2, 2, 5, 2, 1, 6, 2, 1, 5, 2, 2, 3, 2, 2, 1, 2, 1,
6, 1, 1, 5, 2, 1, 3, 2, 1, 2, 2, 4, 2, 2, 3, 3, 2, 1, 5, 2, 2,
5, 2, 1, 6, 2, 1, 3, 2, 2, 2, 2, 2, 1, 2, 4, 5, 2, 3, 3, 2, 1,
2, 2, 1, 1, 2, 1, 6, 1, 1, 1, 2, 1, 5, 1, 6, 0, 0, 100},
{6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 0,0,100},
{0,0,1, 0,0,100},
void delay(unsigned char t)     //節拍
        unsigned char t1;
        unsigned long t2;
        for(t1 = 0; t1 < t; t1++)
                for(t2 = 0; t2 < 8000; t2++);
        TR0 = 0;
void delaya(unsigned char t)     //節拍
        unsigned char t1;
        unsigned long t2;
                for(t2 = 0; t2 < 2000; t2++);
        TR0 = 0;
void delay1(int z)                        //延遲z ms
        int i,j;
        for(i=0;i<110;i++)
                for(j=0;j<z;j++);
void an()                //按鍵檢測
        P2=0xff;
        if(key1==0||key2==0||key3==0)
                delay1(10);
                if(key1==0)
                        num++;
                        if(num==4)
                                        num=0;
                        i=0;
                        time=0;
                if(key2==0)
                        num--;
                        if(num==-1)
                                        num=3;
                        i=0;
                        time=0;
                if(key3==0)
                        tempstop=!tempstop;
                while(!key1||!key2||!key3);
                delay1(5);
void an()                //按鍵檢測
        P2=0xff;
        tempan=P2;
        tempan=tempan&0x0f;
        while(tempan!=0x0f)
                delay1(5);
                tempan=P2;
                tempan=tempan&0x0f;
                while(tempan==0x0f);
                switch(tempan)
                        case 0x0e:
                                num++;
                                if(num==4)
                                                num=0;
                                i=0;
                                time=0;
                                break;
                        case 0x0d:
                                num--;
                                if(num==-1)
                                                num=3;
                                i=0;
                                time=0;
                                break;
                        case 0x0b:
                                tempstop=!tempstop;
                                break;
                        case 0x07:
                                temptime=!temptime;
                                break;
                while(tempan!=0x0f)
                        tempan=P2;
                        tempan=tempan&0x0f;
                        delay1(5);
void main(void)
        tempi=1;
        TMOD = 1;
        ET0 = 1;
        EA = 1;
                if(song[num][i+2]==100)
                        i=0;
                k = song[num][i]+7*(song[num][i + 1]-1);
                timer0h = FREQH[k];
                timer0l = FREQL[k];
                time = song[num][i + 2];
                if(tempi==1)
                i += 3;
                TH0 = timer0h;
                TL0 = timer0l;
                TR0 = 1;
                if(!temptime)
                        delay(time);
                        delaya(time);
                P1=table[num+1];
                while(tempstop)
                        an();
void t0int() interrupt 1
    TR0 = 0;
    speaker = !speaker;
    TH0 = timer0h;
    TL0 = timer0l;
    TR0 = 1;
                an();
