調(diào)試通過的RC522驅(qū)動源碼,使用IO模擬spi接口。測試后能正常讀到M1卡
單片機源程序:
- #include "MFRC522.h"
- #include "nrf_delay.h"
- #include "nrf_gpio.h"
- #include <stdint.h>
- #include <string.h>
- #include <stdio.h>
- //#include "simple_uart.h"
- extern uint32_t *p_spi_base_address;
- typedef uint8_t u8;
- typedef uint16_t u16;
- #define _MFRC_SOFT_SPI
- #define Set_MFRC_CS(x) x ? nrf_gpio_pin_set(SPI_PSELSS0):nrf_gpio_pin_clear(SPI_PSELSS0)
- #define Set_MFRC_SCK(x) x ? nrf_gpio_pin_set(SPI_PSELSCK0):nrf_gpio_pin_clear(SPI_PSELSCK0)
- #define Set_MFRC_MOSI(x) x ? nrf_gpio_pin_set(SPI_PSELMOSI0):nrf_gpio_pin_clear(SPI_PSELMOSI0)
- #define MFRC_MISO_STATUS() nrf_gpio_pin_read(SPI_PSELMISO0)
- //#define Set_MFRC_RST(x) x ? HAL_GPIO_WritePin(GPIOC, GPIO_PIN_1, GPIO_PIN_SET):HAL_GPIO_WritePin(GPIOC, GPIO_PIN_1, GPIO_PIN_RESET);
- void MFRC_Delay(u16 Delay_Time)
- u16 i, j;
- for (i = 40; i > 0; i--)
- for (j = Delay_Time; j > 0; j--);
- #ifndef _MFRC_SOFT_SPI
- void SPI_TxByte(u8 Dat)
- uint8_t state;
- state = spi_master_tx(p_spi_base_address, Dat);
- if(state != true)
- state = true;
- u8 SPI_RxByte(void)
- uint8_t state;
- state = spi_master_rx(p_spi_base_address) ;
- return state;
- #endif
- //? ?:?RC632???
- //????:Address[IN]:?????
- unsigned char ReadRawRC(unsigned char Address)
- unsigned char ucResult=0;
- uint8_t ucAddr;
- uint8_t tx_data[2]={0x00,0x00};
- uint8_t rx_data[2]={0x00,0x00};
- ucAddr = ((Address << 1) & 0x7E) | 0x80;
- tx_data[0] = ucAddr;
- spi_master_tx_rx(p_spi_base_address, 1, tx_data, rx_data);
- ucResult = rx_data[0];
- return ucResult;
- //? ?:?RC632???
- // value[IN]:????
- void WriteRawRC(unsigned char Address, unsigned char value)
- uint8_t ucAddr;
- ucAddr = ((Address << 1) & 0x7E);
- tx_data[1] = value;
- spi_master_tx_rx(p_spi_base_address, 2, tx_data, rx_data);
- //功 能:讀RC632寄存器
- //參數(shù)說明:Address[IN]:寄存器地址
- //返 回:讀出的值
- static u8 ReadRawRC(u8 Address)
- u8 ucAddr;
- u8 ret = 0;
- #ifdef _MFRC_SOFT_SPI
- u8 i;
- Set_MFRC_SCK(0);
- #endif
- Set_MFRC_CS(0);
- for(i=8; i>0; i--)
- Set_MFRC_MOSI((ucAddr & 0x80) == 0x80);
- Set_MFRC_SCK(1);
- ucAddr <<= 1;
- Set_MFRC_SCK(0);
- Set_MFRC_SCK(1);
- ret <<= 1;
- ret |= MFRC_MISO_STATUS();
- Set_MFRC_SCK(0);
- #else
- SPI_TxByte(ucAddr);
- ret = SPI_RxByte();
- #endif
- Set_MFRC_CS(1);
- Set_MFRC_SCK(1);
- #endif
- printf("REG ADDR:0x%x Val: 0x%02x\r\n",Address,ret);
- return ret;
- //功 能:寫RC632寄存器
- // value[IN]:寫入的值
- void WriteRawRC(u8 Address, u8 value)
- u8 ucAddr;
- u8 i;
- Set_MFRC_SCK(0);
- #endif
- Set_MFRC_CS(0);
- printf("---write---REG ADDR:0x%x Val: 0x%02x\r\n",Address,value);
- Set_MFRC_SCK(1);
- ucAddr <<= 1;
- Set_MFRC_SCK(0);
- Set_MFRC_MOSI((value & 0x80) == 0x80);
- Set_MFRC_SCK(1);
- value <<= 1;
- Set_MFRC_SCK(0);
- #else
- SPI_TxByte(value);
- printf("---write---REG ADDR:0x%x Val: 0x%x\r\n",Address,value);
- #endif
- Set_MFRC_CS(1);
- Set_MFRC_SCK(1);
- #endif
- //功 能:清RC522寄存器位
- //參數(shù)說明:reg[IN]:寄存器地址
- // mask[IN]:清位值
- static void ClearBitMask(u8 reg, u8 mask)
- u8 tmp = 0x0;
- tmp = ReadRawRC(reg);
- WriteRawRC(reg, tmp & ~mask); // clear bit mask
- //功 能:置RC522寄存器位
- // mask[IN]:置位值
- static void SetBitMask(u8 reg, u8 mask)
- u8 tmp = 0x0;
- WriteRawRC(reg, tmp | mask); // set bit mask
- //開啟天線
- //每次啟動或關(guān)閉天險發(fā)射之間應(yīng)至少有1ms的間隔
- void PcdAntennaOn(void)
- u8 i;
- i = ReadRawRC(TxControlReg);
- if (!(i & 0x03))
- SetBitMask(TxControlReg, 0x03);
- //關(guān)閉天線
- void PcdAntennaOff(void)
- ClearBitMask(TxControlReg, 0x03);
- //功 能:通過RC522和ISO14443卡通訊
- //參數(shù)說明:Command[IN]:RC522命令字
- // pIn [IN]:通過RC522發(fā)送到卡片的數(shù)據(jù)
- // InLenByte[IN]:發(fā)送數(shù)據(jù)的字節(jié)長度
- // pOut [OUT]:接收到的卡片返回數(shù)據(jù)
- // *pOutLenBit[OUT]:返回數(shù)據(jù)的位長度
- #define MAXRLEN 18
- static char PcdComMF522(unsigned char Command,
- unsigned char *pInData,
- unsigned char InLenByte,
- unsigned char *pOutData,
- unsigned int *pOutLenBit)
- char status = MI_ERR;
- unsigned char irqEn = 0x00;
- unsigned char waitFor = 0x00;
- unsigned char lastBits;
- unsigned char n;
- unsigned int i;
- switch (Command)
- case PCD_AUTHENT:
- irqEn = 0x12;
- waitFor = 0x10;
- break;
- case PCD_TRANSCEIVE:
- irqEn = 0x77;
- waitFor = 0x30;
- break;
- default:
- break;
- WriteRawRC(ComIEnReg, irqEn | 0x80);
- ClearBitMask(ComIrqReg, 0x80);
- WriteRawRC(CommandReg, PCD_IDLE);
- SetBitMask(FIFOLevelReg, 0x80);
- for (i = 0; i < InLenByte; i++)
- WriteRawRC(FIFODataReg, pInData[i]);
- WriteRawRC(CommandReg, Command);
- if (Command == PCD_TRANSCEIVE)
- SetBitMask(BitFramingReg, 0x80);
- i = 3000;//800;
- do
- n = ReadRawRC(ComIrqReg);
- i--;
- } while ((i != 0) && !(n & 0x01) && !(n & waitFor));
- ClearBitMask(BitFramingReg, 0x80);
- if (i != 0)
- if (!(ReadRawRC(ErrorReg) & 0x1B))
- status = MI_OK;
- if (n & irqEn & 0x01)
- status = MI_NOTAGERR;
- n = ReadRawRC(FIFOLevelReg);
- lastBits = ReadRawRC(ControlReg) & 0x07;
- if (lastBits)
- *pOutLenBit = (n - 1) * 8 + lastBits;
- else
- *pOutLenBit = n * 8;
- if (n == 0)
- n = 1;
- if (n > MAXRLEN)
- n = MAXRLEN;
- for (i = 0; i < n; i++)
- pOutData[i] = ReadRawRC(FIFODataReg);
- else
- status = MI_ERR;
- SetBitMask(ControlReg, 0x80); // stop timer now
- return status;
- //功 能:復(fù)位RC522
- //返 回: 成功返回MI_OK
- char PcdReset(void)
- nrf_gpio_pin_set(SPI_RST);
- MFRC_Delay(10);
- nrf_gpio_pin_clear(SPI_RST);
- MFRC_Delay(60000);
- MFRC_Delay(500);
- WriteRawRC(CommandReg, PCD_RESETPHASE);
- MFRC_Delay(2000);
- WriteRawRC(ModeReg, 0x3D);
- WriteRawRC(TReloadRegL, 30);
- WriteRawRC(TReloadRegH, 0);
- WriteRawRC(TModeReg, 0x8D);
- WriteRawRC(TPrescalerReg, 0x3E);
- WriteRawRC(TxAutoReg, 0x40);
- ClearBitMask(TestPinEnReg, 0x80); //off MX and DTRQ out
- return MI_OK;
- //用MF522計算CRC16函數(shù)
- void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
- unsigned char i,n;
- ClearBitMask(DivIrqReg,0x04);
- WriteRawRC(CommandReg,PCD_IDLE);
- SetBitMask(FIFOLevelReg,0x80);
- for (i=0; i<len; i++)
- WriteRawRC(FIFODataReg, *(pIndata+i));
- WriteRawRC(CommandReg, PCD_CALCCRC);
- i = 0xFF;
- do
- n = ReadRawRC(DivIrqReg);
- i--;
- while ((i!=0) && !(n&0x04));
- pOutData[0] = ReadRawRC(CRCResultRegL);
- pOutData[1] = ReadRawRC(CRCResultRegM);
- //設(shè)置RC522的工作方式
- signed char M500PcdConfigISOType(unsigned char type)
- if('A' == type)
- ClearBitMask(Status2Reg,0x08);
- WriteRawRC(ModeReg,0x3D);
- WriteRawRC(RxSelReg,0x86);
- WriteRawRC(RFCfgReg,0x7F);
- WriteRawRC(TReloadRegL,30);
- WriteRawRC(TReloadRegH,0);
- WriteRawRC(TModeReg,0x8D);
- WriteRawRC(TPrescalerReg,0x3E);
- MFRC_Delay(10000);
- PcdAntennaOn();
- else
- return -1;
- return MI_OK;
- 初始化RC522
- void MFRC522_Init(void)
- // MFRC_GPIOConfigure();
- PcdReset();
- PcdAntennaOff();
- MFRC_Delay(2000);
- PcdAntennaOn();
- M500PcdConfigISOType('A');
- //功 能:尋卡
- //參數(shù)說明: req_code[IN]:尋卡方式
- // 0x52 = 尋感應(yīng)區(qū)內(nèi)所有符合14443A標(biāo)準(zhǔn)的卡
- // 0x26 = 尋未進(jìn)入休眠狀態(tài)的卡
- // pTagType[OUT]:卡片類型代碼
- // 0x4400 = Mifare_UltraLight
- // 0x0400 = Mifare_One(S50)
- // 0x0200 = Mifare_One(S70)
- // 0x0800 = Mifare_Pro(X)
- // 0x4403 = Mifare_DESFire
- //返 回: 成功返回MI_OK
- char PcdRequest(u8 req_code, u8 *pTagType)
- char status;
- unsigned int unLen;
- unsigned char ucComMF522Buf[MAXRLEN];
- ClearBitMask(Status2Reg, 0x08);
- WriteRawRC(BitFramingReg, 0x07);
- ucComMF522Buf[0] = req_code;
- status = PcdComMF522(PCD_TRANSCEIVE, ucComMF522Buf, 1, ucComMF522Buf,
- &unLen);
- // UART_send_byte(status);
- if ((status == MI_OK) && (unLen == 0x10))
- *pTagType = ucComMF522Buf[0];
- *(pTagType + 1) = ucComMF522Buf[1];
- else
- status = MI_ERR;
- return status;
- //功 能:防沖撞
- //參數(shù)說明: pSnr[OUT]:卡片序列號,4字節(jié)
- //返 回: 成功返回MI_OK
- char PcdAnticoll(unsigned char *pSnr)
- char status;
- unsigned char i,snr_check=0;
- WriteRawRC(BitFramingReg,0x00);
- ClearBitMask(CollReg,0x80);
- ucComMF522Buf[0] = PICC_ANTICOLL1;
- ucComMF522Buf[1] = 0x20;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
- if (status == MI_OK)
- for (i=0; i<4; i++)
- *(pSnr+i) = ucComMF522Buf[i];
- snr_check ^= ucComMF522Buf[i];
- if (snr_check != ucComMF522Buf[i])
- { status = MI_ERR; }
- SetBitMask(CollReg,0x80);
- return status;
- //功 能:選定卡片
- //參數(shù)說明: pSnr[IN]:卡片序列號,4字節(jié)
- //返 回: 成功返回MI_OK
- char PcdSelect(unsigned char *pSnr)
- char status;
- unsigned char i;
- ucComMF522Buf[1] = 0x70;
- ucComMF522Buf[6] = 0;
- ucComMF522Buf[i+2] = *(pSnr+i);
- ucComMF522Buf[6] ^= *(pSnr+i);
- CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x18))
- { status = MI_OK; }
- else
- return status;
- //功 能:命令卡片進(jìn)入休眠狀態(tài)
- //返 回: 成功返回MI_OK
- char PcdHalt(void)
- // int status;
- ucComMF522Buf[0] = PICC_HALT;
- ucComMF522Buf[1] = 0;
- CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
- //status =
- PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
- return MI_OK;
- //功 能:驗證卡片密碼
- //參數(shù)說明: auth_mode[IN]: 密碼驗證模式
- // 0x60 = 驗證A密鑰
- // 0x61 = 驗證B密鑰
- // addr[IN]:塊地址
- // pKey[IN]:密碼
- // pSnr[IN]:卡片序列號,4字節(jié)
- //返 回: 成功返回MI_OK
- char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
- char status;
- unsigned char i,ucComMF522Buf[MAXRLEN];
- ucComMF522Buf[0] = auth_mode;
- ucComMF522Buf[1] = addr;
- for (i=0; i<6; i++)
- { ucComMF522Buf[i+2] = *(pKey+i); }
- { ucComMF522Buf[i+8] = *(pSnr+i); }
- // memcpy(&ucComMF522Buf[2], pKey, 6);
- // memcpy(&ucComMF522Buf[8], pSnr, 4);
- status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
- if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
- return status;
- //功 能:讀取M1卡一塊數(shù)據(jù)
- //參數(shù)說明: addr[IN]:塊地址
- // pData[OUT]:讀出的數(shù)據(jù),16字節(jié)
- //返 回: 成功返回MI_OK
- char PcdRead(unsigned char addr,unsigned char *pData)
- char status;
- ucComMF522Buf[0] = PICC_READ;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x90))
- // { memcpy(pData, ucComMF522Buf, 16); }
- for (i=0; i<16; i++)
- { *(pData+i) = ucComMF522Buf[i]; }
- else
- return status;
- //功 能:寫數(shù)據(jù)到M1卡一塊
- // pData[IN]:寫入的數(shù)據(jù),16字節(jié)
- //返 回: 成功返回MI_OK
- char PcdWrite(unsigned char addr,unsigned char *pData)
- char status;
- ucComMF522Buf[0] = PICC_WRITE;
- if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
- //memcpy(ucComMF522Buf, pData, 16);
- { ucComMF522Buf[i] = *(pData+i); }
- CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
- return status;
- //功 能:扣款和充值
- //參數(shù)說明: dd_mode[IN]:命令字
- // 0xC0 = 扣款
- // 0xC1 = 充值
- // addr[IN]:錢包地址
- // pValue[IN]:4字節(jié)增(減)值,低位在前
- //返 回: 成功返回MI_OK
- char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
- char status;
- ucComMF522Buf[0] = dd_mode;
- memcpy(ucComMF522Buf, pValue, 4);
- // for (i=0; i<16; i++)
- // { ucComMF522Buf[i] = *(pValue+i); }
- CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
- unLen = 0;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
- if (status != MI_ERR)
- ucComMF522Buf[0] = PICC_TRANSFER;
- return status;
- //功 能:備份錢包
- //參數(shù)說明: sourceaddr[IN]:源地址
- // goaladdr[IN]:目標(biāo)地址
- //返 回: 成功返回MI_OK
- char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
- char status;
- ucComMF522Buf[0] = PICC_RESTORE;
- ucComMF522Buf[1] = sourceaddr;
- ucComMF522Buf[0] = 0;
- ucComMF522Buf[2] = 0;
- ucComMF522Buf[3] = 0;
完整代碼下載:
MFRC522.zip
(5.95 KB, 下載次數(shù): 81)
2017-5-9 14:17 上傳
RC522驅(qū)動源碼
