查看: 2712|回復: 0
模擬光柵測速裝置的程序
ID:195503 發表于 2017-5-2 11:06 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
uint temp,tt,qian,bai,shi,ge;
sbit key2 = P1^1;
sbit key3 = P1^2;
sbit deng1=P1^3;
sbit deng2=P1^4;
sbit guang=P1^5;
sbit beepIO=P1^6;
int t1=(65536-10000)/256;
int        t2=(65536-10000)%256;
uchar table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void keyscan();
void display();
void init();
void delay(uint z);
void shengyin();
                Ö÷oˉêy
        init();//3õê¼»ˉ×ó3ìDò
                if(tt==1)
                        tt=0;
                        if(++temp>=9999)
                                        ET0=0;
                                        shengyin ();   //μ÷óÃéùòô
                        qian=temp/1000;
                        bai=temp%1000/100;
                        shi=temp%100/10;
                        ge=temp%10;
                 keyscan();
                display();
                                shengyin
void shengyin()
uchar i,j;
for(j=5;j>0;j--)
for(i=0;i<50;i++)
beepIO=~beepIO;
delay(2);
                                °′¼ü¿ØÖÆ
void keyscan()
        if(key2==0||guang==1)         //ÔYí£¼Æê±
        deng1=1;
        deng2=0;
        TR0=0;
        if(key3==0||guang==0)         //¿aê¼¼Æê±
        deng2=1;
        deng1=0;
        TR0=1;
                                ÏÔê¾
void display()
      P2=0x08;
          P0=table[qian];
          delay(1);
          P2=0x04;
          P0=table[bai]+0x80;
          delay(1);
          P2=0x02;
          P0=table[shi];
          delay(1);
      P2=0x01;
          P0=table[ge];
          delay(1);
                                Ñóê±
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
                        3õê¼»ˉ
void init()
    P2=0x00;
        P0=0xc0;
        temp=0;
        TMOD=0x01;
        TH0=t1;
        TL0=t2;
        EA=1;
        ET0=1;
        TR0=1;
                        ÖD¶Ï
void t0() interrupt 1
        TH0=t1;
        TL0=t2;
        tt++;
