AD0832設計的電壓表仿真圖:
32X16點陣顯示
單片機源程序:
- #include <intrins.h>
- #include <reg52.h>
- #include <stdio.h>
- #define ulong unsigned long
- #define uint unsigned int
- #define uchar unsigned char
- uchar k,i,j;
- float l;
- sbit sw=P3^0; //159選通開關
- sbit ADCS =P3^1; //ADC0832 chip seclect
- sbit ADDI =P3^3; //ADC0832 k in
- sbit ADDO =P3^3; //ADC0832 k out
- sbit ADCLK =P3^2; //ADC0832 clock signal
- uchar dsw[20]; //存放sprintf轉換字符
- uchar idata value[149]; //點陣字符儲存
- uchar code table[]={ //字符查表
- 0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*".",0*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0xE0,0x0F,0x10,0x10,0x08,0x20,0x08,0x20,0x10,0x10,0xE0,0x0F,0x00,0x00,/*"0",1*/
- 0x00,0x00,0x10,0x20,0x10,0x20,0xF8,0x3F,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,/*"1",2*/
- 0x00,0x00,0x70,0x30,0x08,0x28,0x08,0x24,0x08,0x22,0x88,0x21,0x70,0x30,0x00,0x00,/*"2",3*/
- 0x00,0x00,0x30,0x18,0x08,0x20,0x88,0x20,0x88,0x20,0x48,0x11,0x30,0x0E,0x00,0x00,/*"3",4*/
- 0x00,0x00,0x00,0x07,0xC0,0x04,0x20,0x24,0x10,0x24,0xF8,0x3F,0x00,0x24,0x00,0x00,/*"4",5*/
- 0x00,0x00,0xF8,0x19,0x08,0x21,0x88,0x20,0x88,0x20,0x08,0x11,0x08,0x0E,0x00,0x00,/*"5",6*/
- 0x00,0x00,0xE0,0x0F,0x10,0x11,0x88,0x20,0x88,0x20,0x18,0x11,0x00,0x0E,0x00,0x00,/*"6",7*/
- 0x00,0x00,0x38,0x00,0x08,0x00,0x08,0x3F,0xC8,0x00,0x38,0x00,0x08,0x00,0x00,0x00,/*"7",8*/
- 0x00,0x00,0x70,0x1C,0x88,0x22,0x08,0x21,0x08,0x21,0x88,0x22,0x70,0x1C,0x00,0x00,/*"8",9*/
- 0x00,0x00,0xE0,0x00,0x10,0x31,0x08,0x22,0x08,0x22,0x10,0x11,0xE0,0x0F,0x00,0x00,/*"9",10*/
- 0x08,0x00,0x78,0x00,0x88,0x07,0x00,0x38,0x00,0x0E,0xC8,0x01,0x38,0x00,0x08,0x00,/*"V",11*/
- void delay(int c) //延時,C不能小于5
- int i,j;
- for(i=0;i<c;i++)
- for(j=0;j<10;j++)
- 讀ADC0832函數(shù)
- //采集并返回
- unsigned int Adc0832(unsigned char channel) //AD轉換,返回結果
- uchar i=0;
- uchar j;
- uint dat=0;
- uchar ndat=0;
- if(channel==0)channel=2;
- if(channel==1)channel=3;
- ADDI=1;
- _nop_();
- _nop_();
- ADCS=0;//拉低CS端
- _nop_();
- _nop_();
- ADCLK=1;//拉高CLK端
- ADDI=channel&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿2
- _nop_();
- _nop_();
- ADDI=(channel>>1)&0x1;
- _nop_();
- _nop_();
- ADCLK=0;//拉低CLK端,形成下降沿3
- ADDI=1;//控制命令結束
- _nop_();
- _nop_();
- dat=0;
- for(i=0;i<8;i++)
- dat|=ADDO;//收數(shù)據(jù)
- ADCLK=1;
- _nop_();
- _nop_();
- dat<<=1;
- if(i==7)dat|=ADDO;
- for(i=0;i<8;i++)
- j=0;
- j=j|ADDO;//收數(shù)據(jù)
- ADCLK=1;
- _nop_();
- _nop_();
- ADCLK=0;//形成一次時鐘脈沖
- _nop_();
- _nop_();
- j=j<<7;
- ndat=ndat|j;
- if(i<7)ndat>>=1;
- ADCS=1;//拉低CS端
- ADCLK=0;//拉低CLK端
- ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
- dat<<=8;
- dat|=ndat;
- return(dat); //return ad k
- 點陣字符采集函數(shù)
- void tra(uchar *p) //數(shù)組dsp[]里面的字符查詢后,再儲儲存到另一個顯示數(shù)組value[]
- { for(i=0;i<5;i++)
- if(i<4) //i=2時查的是句號,其他3個是電壓值
- for(j=0;j<16;j++)
- value[(i+1)*16+j]=table[(*p-0x2e)*16+j];
- else
- { for(j=0;j<16;j++) //電壓符號V
- value[(i+1)*16+j]=table[12*16+j];
- p++;
- for(i=0;i<16;i++) //前16個和后21個消隱作用,不顯示
- for(i=128;i<149;i++)
- value[i]=0;
- void main()
- unsigned int b=0,i,j;
- unsigned char a;
- while(1)
- l=k/255.0*5.0;
- sprintf(dsw,"%2.3f",l); //電壓值轉換成字符方式儲存,不明白的人上百度查一下sprintf函數(shù)的運用就清楚的,俺也是查的
- tra(dsw);
- j=0;
- if(a>2) //移動間隔時間;越大移動越慢
- a=0;
- b+=2;
- if(b>=85) //顯示到最后一個字,回頭顯示
- b=0;
- sw=1; //顯示字符,順序是從左掃到右,有16列,數(shù)據(jù)電平是從左1到左16,由低到高
- for(i=0;i<16;i++) //sw是154選通開關。
- P1=i;
- P0=value[j+b];
- P2=value[j+b+1];
- delay(5);
- P0=0x00;
- P2=0x00;
- j+=2;
- sw=0;
仿真工程文件和源碼下載:
AD0832設計的電壓表32X16點陣顯示.zip
(78.84 KB, 下載次數(shù): 23)
2017-4-30 12:48 上傳
